![]() Hello, the rear suspension on my new to me 940 Turbo is sagging quite a bit. The back end sits noticeably lower than the front. I suspect the rear shocks are worn. Would replacing them solve this? The car is a 92 with a solid rear axle, sedan. I'm not sure if I need to be looking at replacement springs too, or if new shocks should be fine. Quite sure it doesn't have nivomats, those were only on IRS cars, right?
Also, I'm not looking for any performance mods, this is a daily driver and it's going to be as soft as possible. I actually don't mind the cushy ride for our bad Quebec roads. Thanks in advance. |
![]() Also, if I need to replace the springs, would it be advisable to get the wagon springs instead of the sedan version? I think I read somewhere here that someone recommended that since they were stiffer.
Reformed SAABaholic
![]() Unless you want a lowered stance, stock sedan/ saloon springs. Should be plenty of stock for OE rear springs. Wagon springs would probably provide too much elevation.
Project "cheap thrills" build thread: http://forums.turbobricks.com/showth...67#post4211467 Feedback thread: http://forums.turbobricks.com/showthread.php?t=198746 |
#4 |
![]() So you think that springs are the culprit?
#5 |
![]() Springs hold the car up off the ground.
Shocks are basically oil-filled tubes with a piston inside that, you know, "absorbs shocks", and after you hit a small bump, keeps the car from going boing-boing-boing-boing-boing.... When they're completely shot (or missing) you get this: https://www.youtube.com/watch?v=NExBgHbxGo8 https://www.youtube.com/watch?v=5Mr-UgWr8-s PS: Nivomats look like this (big rubber bellows): ![]()
![]() 1990 740GL, now in extra-small economy size. 467,000 km so far... Last edited by MasterBlaster; 07-09-2018 at 05:06 PM.. |
#6 |
300+hp on the shelf club
![]() IRS got the nivomats standard but they were available on solid axle cars too. Make sure you don't have them as suggested. If you do have nivomats it isn't abnormal for the car to sag if it isn't being driven. But after a short drive they should pump up and your height should be normal. if they are bad nivomats that you don't want to replace you'll need springs and shocks anyway.
#7 | |
![]() In England shocks are called stabilizers.
Desperate need of elf assistant for interior work - Cash/Beer option $ |
#8 |
![]() Here is a shot that may or may not help. It doesn't have the billows that nivomat pictures do.
![]() Here is how it sits. Notice the considerable gap difference between the front fender and the rear. ![]() |
