Old 07-09-2018, 12:30 PM   #1
turbopop23
Default 2005 xc70 front end issue
I was hoping someone could help me out with this. My 2005 xc70 has recently had new control arm bushings new front coil springs and new struts put in. The alignment has been done twice, but still I have this issue. Ever since they did the front end, the steering is very loose. If you turn the wheel sharp when going into a parking place, its almost like the wheel takes off by itself half way into the turn. The car feels extremely loose on the highway to, sometimes following cracks in the pavement if your not holding on to the wheel firmly. I have had it back to the shop numerous times, originally the struts were the wrong ones and were too long, so they redid the front end again, at no charge of course. The shop I use is a good honest shop, but they can't find anything wrong. Balljoints and tierods are all good. Any help would be greatly appreciated. This is my wifes car and I hear about it alot. Thanks
1996 850 turbo wagon.Totally stock.
turbopop23 is offline   Reply With Quote
Old 07-09-2018, 02:50 PM   #2
EivlEvo
What do your alignment specs look like? This sounds like either a toe or camber issue and you just aren't used to the alignment changes they made.
Do you have your before and after numbers?
Old 07-09-2018, 03:16 PM   #3
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
x2, a different alignment spec can make it feel like a completely different car.
#79WDP
Old 07-09-2018, 03:25 PM   #4
turbopop23
Do you think it would be wise to bring it to a Volvo dealership to get it aligned again? It never handled like this after previous times getting it aligned.
Old 07-09-2018, 03:27 PM   #5
turbopop23
The shop showed me the numbers and said they look correct. I have no clue though.
Old 07-10-2018, 01:22 PM   #6
EivlEvo
Truthfully no. If you had a shop do an alignment and it doesn't feel good to you that doesn't mean it's wrong, it just means you both aren't speaking the same language.
Taking it to Volvo will just be expensive. I would either go back to the shop and tell them what you're feeling and ask if they can tune it out for you (fair warning... they might not know stuff about alignments) for not much money OR... what I do is I get the Firestone lifetime alignments on all my cars. This is also because I know about the geometries and change stuff often enough that I don't want to pay every time. So I can just go in, tell them I need another degree of camber on this side, and roll out (it's a poor mans racing alignment because they sure as hell aren't corner weighting or any of that... and lord knows how accurate their equipment really is)
BUT... they'll give you the printouts and if you tell them your issue and they CAN'T tune it out... if you can get the numbers from them (or anyone) and post them here... we can plausibly suggest changes. But we need some reference.
Old 07-10-2018, 02:17 PM   #7
turbopop23
Thank You, I will bring it back and tell them about the alignment issue I have and get a printout too.
Old 07-13-2018, 05:52 PM   #8
GTJordan
Been here for too long
GTJordan's Avatar
Could it just be how it should be now? You know, you were running on bagged out crap for how long? All of a sudden its new and back to how it should be?
Old 07-15-2018, 11:25 PM   #9
ovlov760
ovlov760's Avatar
My local dealer charges about $70 for a four wheel alignment... same as the tire store chains. Volvo frequently sends out coupons for those types of basic service.
I'd be weary of the fact they put in the wrong struts myself. Are you sure no other mistakes were made?
2009 XC70 T6
2011 XC90 R-design
1998 V70 AWD
1966 M-B 230
2006 V70R GT
2011 C30 T5M
2006 XC70
1997 850 T5
1988 760 Turbo
