Old 07-09-2018, 11:09 PM   #1
1rockhead
Default fuel injectors leaking test?
I suspect that my injectors are leaking fuel into the cylinders when my 90 240 sits overnight. Is there an easy way to test this?
1rockhead is offline   Reply With Quote
Old 07-10-2018, 08:25 AM   #2
TestPoint
TestPoint's Avatar
Baby Bottles.
Ford V8 Conversion Manual -
TestPoint is online now   Reply With Quote
Old 07-10-2018, 09:32 AM   #3
RacerX
Default Testing
I took mine off and had a local machine shop test, clean, and then replace the seals. One of them was a leaker.
RacerX is offline   Reply With Quote
Old 07-10-2018, 03:53 PM   #4
1rockhead
would leaking injectors cause a hard start after sitting overnight? The first couple of spins of the starter it acts like it has no compression (fuel washed cylinders?) then it gains compression and starts to fire only if I WOT then runs rough for about 10 seconds then runs fine.
Old 07-15-2018, 05:57 PM   #5
lummert
lummert's Avatar
Have you ruled out the issue being caused by the coolant temp sensor?
Old 07-15-2018, 07:07 PM   #6
Dirty Rick
Dirty Rick's Avatar
Does the oil smell like gas?
Id change it now.
Old 07-15-2018, 11:39 PM   #7
1rockhead
the last 5 days it has not done it. I will diagnose it if it comes back.
Old 07-16-2018, 09:22 AM   #8
c1800
if fuel was leaking into the cylinders, you should consider changing the oil
