Old 07-10-2018, 12:49 PM   #1
15A
World's Oldest Brewery
15A's Avatar
Default 240 Front Door Speakers w/Crank Windows
Anyone here installed the later 5 1/4" speaker/grills in the front doors of a 240 with crank windows? Do they interfere with the larger grills?
Not really interested in 'extending' the handles......but would love to use the larger setups if possible.
TIA
(IF YOU WANT ME TO LEAVE YOU FB AFTER THE FACT, JUST SAY)
I didn't sleep well last night so I made my coffee this morning with Red Bull instead of water.
I got halfway to work before I realized I forgot my car.
15A is offline   Reply With Quote
Old 07-10-2018, 01:54 PM   #2
speedn_j
speedn_j's Avatar
TIA
I got a speaker to fit but it took alot of hacking and still couldn't get a grill to fit. Im just gonna put 6x9s down at the bottom.
i'm too sexy for RWD
2000 ducati 748 45k miles
2004 jeep grand Cherokee overland
1994 Mercedes e320
1995 Mercedes e320
speedn_j is offline   Reply With Quote
Old 07-10-2018, 02:12 PM   #3
15A
15A's Avatar
So the crank handle did interfere?
Old 07-10-2018, 04:56 PM   #4
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
It's a tight fit, but a buddy of mine used the HT-204 grilles on his '80 242GT. There's almost no clearance between the back of the crank and the grille, but they're still useable.
Old 07-10-2018, 05:08 PM   #5
15A
15A's Avatar
Saw this pic and kind of figured that.
A customer's resto (actually identical colors to the one in the pic).....was hoping to get 5-1/4 components as they're better and cheaper than 4" components.
Thanks for the input fellas.
Old 07-10-2018, 05:09 PM   #6
300+hp on the shelf club
With crank handles and a desire for a big speaker we put a 6" round coax in the bottom of the door. But that was an early 240 pre plastic door pocket. After that I just use the small 4" speakers but buy something like an infinity speaker so it sounds good.
Old 07-10-2018, 05:14 PM   #7
15A
15A's Avatar
The system in this car looks to be 4" components in the doors and 6 1/2" components in the rear deck.....then either 2 8's or 2 10's behind the back seat. Speakers - probably Focals (best I could find for a 4") and JL subs/amps. Will be fun. heh heh
Old 07-10-2018, 05:28 PM   #8
LOL sounds like you will rock your corner of the world. Enjoy!
I was using he infinity 4" coax in the doors with the crutchfield brackets that held the stock grills. Nothing too powerful.
Old 07-10-2018, 05:49 PM   #9
John242Ti
John242Ti's Avatar
Base model 1990 cars were equipped like that from the factory. Crank windows with the HT-204 grilles. So, apparently Volvo didn't find an issue with the clearance.
-J
Old 07-10-2018, 06:05 PM   #10
15A
15A's Avatar
I just might size it up before committing to one or the other. I've heard of people using extensions (?!) for some added clearance. I kind of wondered since EU had crank windows long after we did - would really like to use 5 1/4 components.
Fella said he wanted a world class paint job and a kick-ass stereo.....and thus he shall have them.
Now to decide on 8's or 10's.
Old 07-11-2018, 01:25 PM   #11
JW240
All idiot, no savant
JW240's Avatar
Yeah mine has 5 1/4 from the factory with crank windows. The stock early 90s grills don't have much space for speakers with a thick rim or that protrude a bit.
With the Grille mounted as it should, no interfere with the crank handle. Not much room tho.
240 | 1991 | 333K Km | B230F+T | Cosworth T3 60/63 | M90 | TrueTrack
Husaberg FE450 '12 mx/supermoto swapped
Old 07-11-2018, 03:29 PM   #12
speedn_j
speedn_j's Avatar
Yes. I had to add a spacers on the crank
Old 07-11-2018, 03:38 PM   #13
SlowRide
Cold War Crumple Zones
SlowRide's Avatar
Got some brackets to put over 4" pioneers to use the stock grilles.
45 minutes with some tin snips is all you need to get larger speakers into the lower corners.
Not that it helps you at all, just felt like sharing. And the window cranks clear them.
lose the knee biters?
- Justin
1980 242 DL
240 Junk for Sale
Feedback
SlowRide is offline   Reply With Quote
Old 07-13-2018, 08:50 PM   #14
Kjets On a Plane
Devoid of Luxury
Kjets On a Plane's Avatar
How PSI a stock can support?
Always Be Crushing!
Old 07-13-2018, 10:43 PM   #15
GeneralBurrito
GeneralBurrito's Avatar
The crank on mine clips the bottom of the speakers if I put in too much pressure, so I just made it a habit to pull a little while I crank the window and it's works fine.
