Old 07-10-2018, 02:15 PM   #1
Eviltwin
Default compressing coils on 245's strut assembly...imminent disaster
I'm using these widowmaker coil spring compressors on my 1983 245 wagon. They are about 3/4's if not more compressed and the top coil is showing no sign of separating from the top strut plate.
https://www.amazon.ca/OEMTOOLS-25550...l_5v8ounivzy_e
I'm nervous to keep winding on this imminent time bomb.
best to remove the brake line from the hardline and let a shop do it?
what does Turbobricks say?
1990 BMW Hartge H35
1983 Volvo 245 *now with LS power!*
Eviltwin is offline   Reply With Quote
Old 07-10-2018, 02:39 PM   #2
hackster
I have used similar ones on lots and lots of strut assemblies with zero issues.
The key to them is to get them as close to the top and bottom of the coils before starting. I even wedge them up in there towards the pigtail top and bottom and then hit it with the impact. Should be able to get tension off of the fronts pretty easy and do springs on the car, dont it on many 242's and a few 245's.
Best of luck and although they are kind of sketchy, they cannot go anywhere until you take the to nut off
Sean
hackster is offline   Reply With Quote
Old 07-10-2018, 02:41 PM   #3
Eviltwin
Sean
until I take the glad nut off the top of the strut right?
I would hope that the spring is fully compressed and the strut is full decompressed by the time I hit that...
Old 07-10-2018, 02:54 PM   #4
oldschoolvolvo
oldschoolvolvo's Avatar
I’d stop and reassess. I’ve had to loosen and readjust the clamps grab another coil or so if the spring wasn’t loose by the time the clamps were tightened down.
-Mike
1998 V70 T5
|Feedback|
Old 07-10-2018, 02:59 PM   #5
The small saddle on those compressors is sketchy. The Volvo tools have a double saddle.
Like most spring compressors of that type, they aren't long enough to completely relieve all the tension on the stock spring so there's another tool to do that once the spring is off.
Old 07-10-2018, 03:07 PM   #6
I use the same set of spring compressors, do what hackster says and you'll be fine.
Old 07-10-2018, 03:12 PM   #7
300+hp on the shelf club
As mentioned above. You have to grab five coils with the aftermarket spring compressors. You'll need a prybar to get the hook into the fifth coil. Then it compresses the whole spring without issue.
Old 07-10-2018, 03:16 PM   #8
Eviltwin
mmk fellas thanks for the tips
will try this evening.
Old 07-10-2018, 03:20 PM   #9
XxJenoxX
Skin Suit
XxJenoxX's Avatar
They can't really decompress, just slip over. Keep your fingers out of pinch points and the worst you'll get is a scare.
It's real fun on BMW springs. They don't have all that travel, so you just put the impact on the gland nut, keep your face out of the way, and let 'er rip.
AND THEN THERE WERE TWO (and a half)
2008 XC70 3.2: Stubborn sensor on wheels
1992 M47 240 Wagon: Why did anyone let me have anything this nice?
1990 240 DL: Parts car
1983 242 TIC +M46: Ticket to the 242 Crush Club
I have no idea what's going on, but I think I can fit more 8====D in my mouth than 240240
Originally Posted by Wilford Brimley View Post
Mmmmmm curvy girls and cock excess
XxJenoxX is offline   Reply With Quote
Old 07-10-2018, 06:44 PM   #10
Another tip for less pain is to rent or buy a clamshell type compressor. Made life a whole lot easier than the two long bolt version.
Old 07-10-2018, 07:52 PM   #11
DET17
Reformed SAABaholic
Lubricate the ACME thread (trapezoidal thread) to ease compression.
As stated, grab as many spring coils as possible to ease your labor; 4 minimum. Stock springs need much more compression that lowering springs which in my experience only require 3 coils to compress.
"clock the compressors" properly on the installed spring/strut. 180* apart, and look where the ACME thread will reach as you work..... there are optimum locations where you can extend further without impacting the strut tower.
Think SAFETY. There is enough energy in these springs to kill you; if you aren't afraid, watch some youtube video of spring work gone wrong......
Old 07-10-2018, 08:53 PM   #12
Rusty_ratchet
Rusty_ratchet's Avatar
Clamshell type compressors are awesome!
Rusty_ratchet is offline   Reply With Quote
Old 07-10-2018, 10:24 PM   #13
EivlEvo
For a margin of safety I also run ratchet straps through before I yank them out. And yes... even with good spring compressors just treat it like a bomb...
Old 07-11-2018, 04:11 AM   #14
buzz
To inspamity, and beyond!
buzz's Avatar
Eviltwin. RIP.
Originally Posted by Råda View Post
I usually don't get compliments on my penis from guys, but thanks!
I used to be indecisive. Now I'm not so sure.
The Phoenix
buzz is offline   Reply With Quote
Old 07-11-2018, 12:05 PM   #15
Eviltwin
Originally Posted by buzz View Post
Eviltwin. RIP.
LOL
I actually ended up throwing in the towel.
buttoned everything back up, and going to have a shop do it properly.
I simply didn't feel safe and knew my limits of reasonability where being pushed....
thanks for the advice regardless fellas!
