Old 07-10-2018, 03:27 PM   #1
Magnanimous
Default Improving/upgrading 1987 A/C system
My wagon has a bad compressor that needs to be replaced, but seeing as I live in South Florida, and that we're moving into the hottest part of our already sweltering summers, I was wondering if there was anything that I could do to improve or upgrade the A/C system to be as cold as possible.
Are there newer and more efficient compressors that could be swapped in, for example?
The previous owner already converted the car over to r134, for what it's worth.
1987 740 GLE Wagon with M46
2003 Ducati ST4S
1994 Honda Magna
Magnanimous is offline   Reply With Quote
Old 07-10-2018, 03:48 PM   #2
Cwazywazy
Cwazywazy's Avatar
Envirosafe or Duracool refrigerants should get it plenty chilly. Parallel flow condenser is a good upgrade too, from what I've read.
I don't know what I have
Old 07-10-2018, 03:58 PM   #3
2manyturbos
Charge the system with Envirosafe ES12 industrial refrigerant and add a pusher fan in front of the condenser and it will get plenty cold.
Old 07-10-2018, 05:09 PM   #4
Magnanimous
Are there any drop in replacements available on the market?
Old 07-10-2018, 06:22 PM   #5
DET17
Reformed SAABaholic
By the 93+ 9 series condenser, which was factory R134a. Might not be drop in, but best available stocker.
Old 07-10-2018, 08:30 PM   #6
jjona5
I used a universal parallel condenser from ebay and it was only 54 bucks. I cut off the old mounting brackets and riveted them onto the new one and had two custom hoses made. I also used industrial es12 and got down to 40 degrees at idle. I actually left it idling in the driveway the other day and had condensation on the windows I have a 1990 with the crappy evaporator too. All in all including the new blower motor and resistor block I only have I think about 200-250(I replaced all the hoses, resealed my original compressor, and replaced the drier also) in it.
jjona5 is offline   Reply With Quote
Old 07-10-2018, 08:31 PM   #7
jjona5
https://www.ebay.com/itm/CNFP1623-AC...72.m2749.l2649
This was in a 240 though.
Old 07-10-2018, 09:45 PM   #8
Cwazywazy
Cwazywazy's Avatar
Originally Posted by jjona5 View Post
Can you post a pic of that in the car/the lines?
Old 07-11-2018, 02:25 AM   #9
jjona5
I'll try to find some tomorrow. I put a transmission cooler in front of the lines now so I'll need to find the old pictures
