Old 07-11-2018, 10:43 AM   #1
GeneralBurrito
GeneralBurrito's Avatar
Default Speedometer shuts off every now and then along with the odometer.
So almost every time I drive, the speedo needle would just drop to 0 and I noticed a few days ago that the odometer/trip meter weren't counting miles as well when the speedo drops. Would it have something to do with the L-plug that connects to the little circuit board behind the cluster or something power related? Every other cluster works perfectly except for the speedo. It would start working again sometimes by itself, with a small tap on the dash board, or sometimes with a few hard smacks. It's getting pretty annoying.
Old 07-11-2018, 11:12 AM   #2
http://forums.turbobricks.com/showpo...8&postcount=12
Old 07-11-2018, 11:23 AM   #3
Khrrck
Professional Amateur
Check the wiring at the differential housing too, sometimes they get rotten.
'87 240 budget wagon.
Old 07-11-2018, 12:47 PM   #4
283SD
The wires from the diff where they enter the body a prone to breaking.
Old 07-11-2018, 12:52 PM   #5
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
Diff wiring going south, bad/cold solder joints on the board, L shaped connectors getting loose, lots of things to start diagnosing for intermittent speedo operation.
1980 242 Turbo
2004 V70R
Old 07-11-2018, 08:12 PM   #6
GeneralBurrito
The solder looks pretty clean, my dad even inspected them up close and he though they were fine too. I checked the diff wire and the ones going into the plug we're stripped, I separated the wires so they don't touch and wrapped them up with e-tape. I think it could be the L shaped plug, I'll try adjusting the connectors for a tighter clamp in the circuit board and see how it goes tomorrow. That back plate shown in the link above has me interested too.
Old 07-11-2018, 08:13 PM   #7
GeneralBurrito
One time use? So once it's removed, it can't be put back on?
Old 07-11-2018, 08:18 PM   #8
The tabs are designed to break when it's removed. If you're really careful, you may be able to unbend them enough to get it off without breaking them.
Old 07-11-2018, 08:24 PM   #9
GeneralBurrito
That sucks, is that Volvo's way of preventing us from tampering with the cluster?
Old 07-11-2018, 08:31 PM   #10
Old 07-12-2018, 10:22 AM   #11
Uncleknucklez
bruspeed
I have NEVER seen one of these before. Is this not a 240 part?
Old 07-12-2018, 01:23 PM   #12
The late 240 speedometer is set up to accept the clip, so I imagine it's supposed to have it.
You've probably never come across a cluster that hasn't been removed before.
Old 07-12-2018, 03:57 PM   #13
GeneralBurrito
http://imgur.com/gallery/uzPSN04
Does the clip screw into where the red arrows are?
Old 07-12-2018, 04:06 PM   #14
No, the tabs on the clip fit into the rectangular holes in the circuit board. It just snaps into place.
Old 07-12-2018, 05:08 PM   #15
GeneralBurrito
Ah, I see now. Thanks for showing me.
Old 07-14-2018, 04:34 PM   #16
GeneralBurrito
So I squeezed together each connection in the L shaped plug and it holds on to the circuit board tighter, I aslo secured the plug in place as much as I can with some electrical tape, but it still has intermittent power cuts. It seems to be somewhere in the dash because just a simple tap cuts the power, while I have to smack the crap out of the dash to get it going again. Could loose/finely cracked solder be the culprit?
Old 07-14-2018, 04:40 PM   #17
bobxyz
bobxyz's Avatar
There's a flex fuse shown just to the left of the white speedo housing in the above picture. It supplies 12volts from the 3-pin connector to the speedo and console. Try removing and cleaning the connections carefully (I don't know how fragile they are after 20+ years).
Edit: See http://www.cleanflametrap.com/speedo5/ or http://www.cleanflametrap.com/speedoDiag.html
(Thanks Art!)
bobxyz is online now   Reply With Quote
Old 07-14-2018, 05:24 PM   #18
GeneralBurrito
Okay I'll try doing that. What would be recommended to clean it, isopropyl alcohol?
Old 07-18-2018, 08:00 AM   #19
XxJenoxX
Skin Suit
XxJenoxX's Avatar
Gonna wanna do a proper fix on that diff wiring before you can rule it out. It's accessible up top through the gas tank hatch (even easier if you have a wagon), so just splice it back and put a new connector on it. There are a couple places to rob them from parts cars, though you're better off buying new wiring with the proper boots for the bullet connectors.
I just went through this. The wiring doesn't have to be broken to make it work like sh1t, and smacking the dash did affect things for whatever reason, even though the diff wiring was the issue. The wires don't just break, they corrode up the length of it, so electrical tape is not a great fix.
It's the same connector as the side marker lights:
https://www.fcpeuro.com/products/vol...ll-amber-1-1-1
AND THEN THERE WERE TWO (and a half)
2008 XC70 3.2: Stubborn sensor on wheels
1992 M47 240 Wagon: Why did anyone let me have anything this nice?
1990 240 DL: Parts car
1983 242 TIC +M46: Ticket to the 242 Crush Club
I have no idea what's going on, but I think I can fit more 8====D in my mouth than 240240
Originally Posted by Wilford Brimley View Post
Mmmmmm curvy girls and cock excess
XxJenoxX is offline   Reply With Quote
Old 07-18-2018, 09:13 AM   #20
GeneralBurrito
This sounds promising. I have a sedan, but I think I know where the little box the diff wiring goes into, the one that goes up the left side of the trunk right? So I'll just have to get that new wiring set and replace the wiring up to the box?
Old 07-18-2018, 09:19 AM   #21
centason
Knipex=welfare queen
centason's Avatar
I had the same issue. It was loose connections on the back of the cluster. Make sure everything is double checked. I had to pull it twice until I found the connection that was doing it.
Member: TBCCS
"The kind of man who wants the government to adopt and enforce his ideas is always the kind of man whose ideas are idiotic." -H. L. Mencken
Old 07-18-2018, 09:34 AM   #22
GeneralBurrito
The connections that press onto the circuitboard behind the speedo? I've pulled it and squeezed each connector so it clamps onto the circuit board firmly. It's on there tight and I taped it in place to reduce any movement from vibrations. After a few days of driving, the speedo seems to fail more during the morning when it's cold and rarely during the day when it's hotter outside.
Old 07-18-2018, 10:01 AM   #23
XxJenoxX
Skin Suit
XxJenoxX's Avatar
Yup, you'll have to pry that open. You can also use that test method in the clean flametrap link someone posted above. You don't have to replace that whole harness, usually just cutting back and splicing into a good section of wire is fine. I did make myself a separate harness further down, though. Used a 2-pin connector from the power windows on my parts car to make a shorter harness with new wire. I didn't have time to wait for new wire and clips in the mail, so I used some rubber booted bullet connectors from somewhere else on the parts car, too.
It acted up a 2nd time and when I pulled the clip off, it was full of water. So it's worth buying new wiring with rubber boots that are in good shape. That wiring is subject to the elements more than most.
Old 07-18-2018, 10:01 AM   #24
XxJenoxX
Skin Suit
XxJenoxX's Avatar
I had that issue, too. Moisture in the morning was getting into the diff connector and making it worse.
Old 07-18-2018, 10:26 AM   #25
GeneralBurrito
Alright, I'll check out the diff wiring as soon as I can.
