Old 07-11-2018, 08:12 PM   #1
autoloclys
Default wiring connector for M47 reverse switch
I have successfully manual swapped my 92 245, however the wiring for the reverse switch on the top of the trans is not staying connected. I followed advice found on another thread that yellow bullet connectors were a good fit, and they worked for a while but then fell off.
does anyone have a line on a better solution or the actual connector part needed? Is it available anywhere online or from volvo?
autoloclys is offline   Reply With Quote
Old 07-11-2018, 08:25 PM   #2
http://forums.turbobricks.com/showpo...99&postcount=5
Old 07-11-2018, 10:13 PM   #3
autoloclys
perfect! PM sent
