Old 10-01-2018, 11:14 PM   #1
955IsAlive
Default How can I (temporarily) make the AW30-43 in a 960 hold a gear.
1st is too short, and 3rd is too long for skids in this thing, even in the snow.
Is there is a way I can "trick" the solenoids into holding second gear via a switch?
I'm not too bothered if it pisses off the TCU and throws codes as long as the car doesn't go into some lame limp home mode within seconds.
I've seen one guy built a paddle shifter, but I'm wondering if I can simply make a switch that I can use to hold second gear, until the switch is turned off.
955IsAlive is offline   Reply With Quote
Old 10-02-2018, 01:24 PM   #2
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
winter mode and manual 2?
Megasquirt Tuning!
Old 10-02-2018, 02:34 PM   #3
Broke4speed
Broke4speed's Avatar
Well, if you unplug the TCU, it will allow you to hold 1, 2, and 4, if you move the shifter into the appropriate location, I believe.
Or, if you want a bit more complicated, you can find the wires for the shift solenoids and run 12v on a switch to both SOL1 and SOL2 (12v to the solenoids, NOT the ecu pins). That would give you 2nd gear.
1984 B6304S/AW30-40 w/Poi-Shift.
Old 10-02-2018, 04:01 PM   #4
955IsAlive
The only options I have on the selector are D N 3 and L.
L locks it in first which is a bit more revvy than I'd like.
* 3 locks it in third and then upshifts to fourth
* W locks in third
* I'll have to verify these.
Old 10-02-2018, 05:59 PM   #5
lummert
lummert's Avatar
Paddle shifters?
Old 10-02-2018, 11:14 PM   #6
955IsAlive
Paddle shifters?
yessir
https://forums.turbobricks.com/showthread.php?t=47229
Old 10-02-2018, 11:19 PM   #7
955IsAlive
So what you’re saying is that the transmission will hold certain gears based on the position of the PNP switch... if the signals from the TCU are missing?
Sounds like it would be wise to lock the torque converter along with the solenoids.
Thinking out loud.... I wonder how much effort it would take to retrofit a shifter that has a “manual” mode when you move it to one side. AKA “geartronic” from a P2 ��
Old 10-03-2018, 08:20 AM   #8
Broke4speed
Yes, although maybe I am wrong in thinking it will give 2nd. It could be 1-3-4. The AW30-40 is the same transmission as the Jeep AW4 and the Toyota A340 (and A341), give or take a few things. The early Toyota versions (on the 1JZ engines) used a cable at the throttle body to handle transmission pressure, like the Volvo AW70 and AW71. There is tons of info out there about modifying the AW30-40 if you google it by it's different names
Don't do this. The lockup is NOT strong, and is basically only good for use 4th/OD for cruising. Some of the other companies that use the AW3x have it lock in 3rd as well, but only for cruising purposes.
It is possible. The Volvo shifter inside the car (for the RWD ones anyway) uses a rod linkage to the box, and the P2 cars all use a cable. You'd need to experiment with cables and such in order to see whether or not the P2 shifter uses the same detents as the RWD AW30-40.
Here's what I've done:
A terrible picture:
I built the paddle shift controller that you've referenced above (it's pretty easy), and instead of using paddles, I'm using a joystick from an arcade cabinet. The AW30-40 is hydraulic for the P/R/N gears, so when I shift to D, it starts off in 1st and I shift it up/down using the joystick. It'd be pretty simple to run the paddle controller in tandem with the stock TCU, all you'd need is a switch and some creative wiring.
Old 10-03-2018, 09:48 PM   #9
hikerguy
hikerguy's Avatar
I dig the joy stick
+1/2 million miles of white block sitting in the drive way
hikerguy is offline   Reply With Quote
Old 10-04-2018, 04:29 PM   #10
lummert
lummert's Avatar
Arduino based AW30-40 / AW4 transmission control. Part 1: Figuring it all out.
http://blog.nsfabrication.com/2015/1...ng-it-all-out/
Old 10-04-2018, 08:16 PM   #11
Broke4speed
An arduino controller would be cool, but the POI box does everything I need it to do .
