Old 07-07-2018, 08:32 PM   #1
profall
Default 2.3L Ecoboost Swap, Possible?
I've been finding a lot of wrecked Mustang's with the 2.3L Ecoboost motor for cheap. A few thousand for the entire wreck. They make good numbers stock, there is quite a bit of aftermarket components for the 2.3L Ecoboost and an inline 4 is truer to the nature of a 240 anyway.
There is T5 transmission mounting kits out there for the 2.3L Ecboost, would just need to figure out if it could work when mounted in a 240 trans tunnel.
I can find the external dimensions for the Ecoboost motor everywhere online, but I have not been able to find the external dimensions for a redblock. Passing that info along would be much appreciated if anyone has it.
Please let me know your thoughts or if anyone else has done this before. Looking to start a new project.
profall is offline   Reply With Quote
Old 07-07-2018, 08:45 PM   #2
thelostartof
unbalanced chemical
thelostartof's Avatar
Are not the new 2.3l engines direct injection? Does that have any kinds of special requirements for a fuel system?
thelostartof is offline   Reply With Quote
Old 07-07-2018, 09:02 PM   #3
centason
Knipex=welfare queen
centason's Avatar
Probably a fuel pump and fuel lines.
You can get 400hp all day on those.
Member: TBCCS
"The kind of man who wants the government to adopt and enforce his ideas is always the kind of man whose ideas are idiotic." -H. L. Mencken
You sons of bitches are the biggest thread de-railers in forum history. Any forums history.
Old 07-07-2018, 09:26 PM   #4
permavirgin777
permavirgin777 is offline   Reply With Quote
Old 07-08-2018, 12:48 AM   #5
GTJordan
Been here for too long
GTJordan's Avatar
I believe Ford motorsport sells a wiring harness to drop this engine into pretty much anything. You can buy them from them also.
Go for it
Old 07-08-2018, 03:53 AM   #6
jjona5
Yup let us know. It would be awesome. Might have to move the engine forward just a bit because of the high pressure fuel pump but that engine weighs 340 lbs complete so it shouldn't hurt the balance too much. 300 hp out of the box.
Old 07-08-2018, 09:04 AM   #7
tryingbe
Boosting along.
tryingbe's Avatar
Go for it
Yup, my buddy put a ford Ecotech 2.3 in his sandrail.
85 GLH 367whp
00 Insight mpg > yours.
Old 07-08-2018, 10:54 AM   #8
CAPT_BLOTTO
#Crush It
CAPT_BLOTTO's Avatar
Probably good filter but they use a normal fuel pump to get up near the engine then a cam driven pump raises the pressure up high enough for in the rail.
Hello My Glorious!
CAPT_BLOTTO is offline   Reply With Quote
Old 07-08-2018, 11:25 AM   #9
M.H. Yount
M.H. Yount's Avatar
In GM's D.I. engines, the tank-mounted pressure requirement is 72 psig, vs the 58 psig for normal efi. Don't know what the Ford requirement is -- easy to confirm and adjust I'd think.
Old 07-08-2018, 04:00 PM   #10
Biggest issue is the high pressure fuel pump sitting off the back of the head, you’ll have to clearance the firewall for it.
For fuel supply, I do know that the 2.0 needs 50psi fed into the high pressure pump. Walbro 255 seems to work just fine.
For transmission, t5 will definitely work. I used a Quad4 bellhousing and Tilton hydraulic TO bearing. It works, but it’s a ton of money to make a t5 work.
I’d try and make the 2.3 6spd work out.
Buy the ecoboost controls pack from Ford, and the rwd install kit, makes life way easier. The RWD swap parts weren’t around when I did the 2.0 ecoboost swap into a merkur.
Old 07-13-2018, 10:50 PM   #11
BassGuy
BassGuy's Avatar
Just checked the Mustang 2.3L service manual. Low side pressure spec is 50.8-75.4 psi
2003 Volvo XC70
1991 945GLE - 16v Wagon! (in pieces)
1990 245 - DD, Pepper-thing (car, wagon, boat, mobile) - K-cam'd and Dale-gear'd - now an actual fridge, probably
1987 760 Turbo Intercooler - dead 07/14/2011
Feedback Thread
BassGuy is offline   Reply With Quote
Old 07-13-2018, 11:02 PM   #12
centason
centason's Avatar
Only problem I see with the MT-82 6speed is the horrendous gearing. Probably would need a 3.31 or 3.54 just to make it palatable.
Old 07-14-2018, 01:26 PM   #13
pat244ti
pat244ti's Avatar
Paging Culberro.
He helps out Dave Clark with his 2.0 Ecoboost Merkur
https://www.autocar.co.uk/opinion/mo...lly-car-podium
- Patrick
83 244ti - road race
83 244ti - rally
73 1800es - resto
08 c30 T5 6spd - daily
97 dakota 5.2 4x4 single cab short bed - apocalypse mobile
pat244ti is offline   Reply With Quote
Old 07-14-2018, 02:46 PM   #14
mck1117
Yep, the fuel pressure requirements for the low pressure (yes, 50-75psi is low pressure) pump are pretty generous, because the high pressure (2000psi) system runs in closed loop with a fuel pressure sensor. So long as you can supply enough volume and pressure to prevent cavitation in the pump inlet, it'll behave itself.
mck1117 is offline   Reply With Quote
