Old 04-06-2016, 06:18 AM   #1
tomasss
tomasss's Avatar
Default Any interest in AW30-43 / AW50-42 torque reduction delete?
I've been recently making the "magic box" that allows to remove the torque reduction "comfort" feature during the shifts of the AW30-40/AW30-43 auto transmission that is in the 960/960II/S90/V90 with 2.5/3.0 petrol engine, and I was wondering that maybe more people from here would like it.
The comfort feature originally decreases the torque of the engine during every shift, and according to my measurements
http://forums.turbobricks.com/showpo...26&postcount=6
it may in some cases reduce the power for second or so.
Using this box, the torque of the engine is not decreased at all, the smoothness of the shifts is the same with light throttle, but with throttle wide open, its nice quick shifts without the noticeable power decrease just before the shift occurs.
It can be used both for the older Motronic 1.8 (960 and some early 960II) and newer Motronic 4.4 (later 960II and all S90/V90), but it has to be specified before the order.
The installation is really simple, just cutting three wires, connecting them to the box and powering the box with switched +12V and ground.
http://forums.turbobricks.com/showpo...41&postcount=8
I've already installed it in my 960 with Motronic 1.8 and it works flawlessly, now I am awaiting feedback from one Finland guy as he is going to install it in his 960 with Motronic 4.4, to confirm the functionality.
Price would be $20 for the Motronic 4.4 and $25 for the Motronic 1.8, plus shipping (the box is really light so I would expect something around $5).
Will there be some interest at all?
Volvo 740 Turbo B204GT 1991
It's the oversteer that scares passengers. It's the understeer that scares the driver.
Originally Posted by Wren View Post
I would rather push a 240 than drive a V70.
lazy PRV engine? Check >this< out
tomasss is offline   Reply With Quote
Old 04-06-2016, 10:17 AM   #2
naterhater
naterhater's Avatar
If I had an automatic 960 I'd be all over this
"It's probably fine!"
"If you find yourself doing it a second time, do it right this time"
'93 940 Turbo thread:
http://forums.turbobricks.com/showthread.php?t=288116
naterhater is offline   Reply With Quote
Old 04-06-2016, 11:07 AM   #3
MrBill
fige=500Dollar Mistake
MrBill's Avatar
I always figured it was transmission longevity item.
It's just there for comfort?
Someone say crazy rays?
Old 04-06-2016, 11:44 AM   #4
740atl
educator monkey
740atl's Avatar
Isn't the 30-40 box the same as the a340 supra? Can't you just do the accumulator mod for the same effect?
Old 04-06-2016, 12:04 PM   #5
tomasss
tomasss's Avatar
Originally Posted by MrBill View Post
I always figured it was transmission longevity item. It's just there for comfort?
Don't think so, the weaker AW7x hadn't this feature at all and it wasn't problem, so why it should be in this stronger one.
This modification, in fact, is more about the engine performance than transmission. Sure you can do the accumulator mod to speedup the shifts, but still there will be a decrease of the engine torque during the shifting. If you want to eliminate it completely (and retain the original TCM), something similar like this has box must be used.
Old 04-06-2016, 02:28 PM   #6
MrBill
MrBill's Avatar
The 'weaker' AW7X was hydraulic though.
There are plenty of vehicles out there with torque management and all that other stuff that keeps transmissions from blowing apart. I just figured this was something like that.
The comfort thing does make sense. My mom had an m46 330, you couldn't even feel it shift.
Old 04-06-2016, 03:41 PM   #7
Ursan
الله الفول السوداني شطائر
Ursan's Avatar
So this is why those cars felt sluggish and mushy on acceleration?
how psi a stock can support?
I think this might be my chariot if I can jew the price down.
Old 04-07-2016, 02:08 AM   #8
tomasss
tomasss's Avatar
Yes, the transmission "brain" is hydraulic, but there is no restriction of the engine power output at all.
Partially. Improve the restrictive exhaust & intake, better cams, remove the comfort functions of the transmission, set the camshaft gears +4˚ advance on intake and +2˚ advance on exhaust and you have multiplied the fun factor by 100.
Old 04-09-2016, 06:46 AM   #9
tomasss
tomasss's Avatar
One thing I've forgot - as the electronic management is the same for the FWD AW50-42 as well (automatic transmissions in the 850's and first gen. of S/V70's), this thing may be used in these cars as well!
Old 07-11-2018, 09:15 AM   #10
Ghettobird
Ghettobird's Avatar
Hey Tomasss, Im interested in building a torque reduction delete box also.
Is there any chance of an explanation of the diagram & what parts to get if there is a better way of making one up?
Ghettobird is offline   Reply With Quote
Old 07-11-2018, 11:22 AM   #11
Might be useful for people who are manual swapping an auto 960!!!
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 07-12-2018, 11:19 AM   #12
HiSPL
HiSPL's Avatar
I'm interested in this. sending PM.
Beets taste like buttfeet.
Old 07-13-2018, 03:22 PM   #13
HiSPL
HiSPL's Avatar
FArk! I just noticed this was from 2 years ago......
