Våga Vägra 8V
![]() Hi,
does anyone have experience with this stuff from retroturbo? http://www.retroturbo.com/?product=r...-pu-set-700900 |
unbalanced chemical
![]() Join Date: Jun 2002
![]() While I have not used those bushings I can recommend that if you go that route over solid arms I would recommend welding up the subframe to make it stronger. Maybe even the same thing for the arms. We added some 1/4" aluminum to the arms when i used to run them with just new stock bushings and a welded frame and they held up to the abuse.
![]() More improvement was to weld subframe and double sway bar than this.
#4 |
Våga Vägra 8V
![]() Thanks tlao.. subframe is for shure to be welded
![]() @ wujek, so you have them installed? |
#5 |
Våga Vägra 8V
![]() i could think of these bushings make the driving like because racecar :D
#6 | |
der Junge
![]() Quote:
- 1989 745 16v - 1991 744 (SE) 16v Turbo |
#7 |
Våga Vägra 8V
![]() yeah.. but you cant tell if my popometer would say the same.. tzhe 16v is gonna be a streetracer.. not that i want to go for a holidayride nor is it a drive to work car, you know ;)
I believe homer uses his 255 as dailybitch.. Never had polybushes so far.. i could think of i would like the stiff handling and would turn the radio louder when its rumbly but.. you never know :D Last edited by MadDog_945; 06-20-2018 at 06:43 AM.. |
#8 |
Våga Vägra 8V
![]() haha.. found also aluminum bushings.. meh.. i will give them a try.. 90 bucks isnt that bad for a complete kit.. over at skandix the do cost 120 without the trailingarm body bushing which comes on top..
#9 |
![]() The thing with polyurethane bushings is that they only work ideally in applications where they experience forces that move in-line with the through bolt.
As in differential bushings, engine torque mounts, etc. Most suspension bushings experience movement on multiple axes which is not ideal for a material as stiff as poly as they can bind if the durometer is too stiff. The best race-y solution would be spherical links as they can move freely without binding on multiple axes, however, I haven't seen any options available. This full rear suspension solution is available although I don't have any personal experience with it: https://www.l-m-r.se/p/volvo/740-760...o-740-940.html Last edited by bmos; 06-27-2018 at 06:22 PM.. |
#10 |
![]() That is pretty cool. Those clamshell bushings are usually shot to **** in 740's. Even the new ones are silly soft and cost $$$. On my cars these bushings always caused a lot of axle movement.
88' 740 GLE Wagon - B230FT, T5 Trans, MSII-extra, G80, 3" T->T Exhaust - - > Project Thread < - - My new project - 1990 740 SE Wagon |
#11 |
Våga Vägra 8V
![]() i ordered them.. will post some pics of the install and make something like a review.
But i cant really compare, because i have never had new ones :D But since this is my saturday evening hooncar it doesnt matter if its stiff and uncomfy.. Hauptsache es ballert ! :D |
#12 |
der Junge
![]() Ohhhhh it's sure to ballern!
#13 |
Våga Vägra 8V
![]() has anyone seen the forward bushing as a replacement? skandix, ipd and all the others dont have this one in their shops??
#14 |
![]() Ähem
https://www.skandix.de/en/search/?q=1001278 https://www.skandix.de/en/search/?q=1042413 https://www.skandix.de/en/search/?q=1001279 https://www.skandix.de/en/search/?q=1001281 nach welcher suchst Du denn Krister? nimm beim Längslenker vorne kein PU, außer Du hast 500+PS, und die wird dein Elch nicht haben ![]() Beste Grüße Kay |
#15 |
Våga Vägra 8V
![]() ahjo, als wenn du erfahrung haettest mit 500hp+ 9ern ;)
im talking about the single forward bushing from the subframe.. |
#16 |
![]() letzter link
und 635PS, aber das ist eine ganz andere Geschichte und schon lange her, nix Volvo Motor, dafür legal, fährt mit holländischen Kennzeichen ![]() Es werden keine Bilder gepostet, weil....... und es ist echt lange her. |
#17 |
Våga Vägra 8V
![]() ahjo, falsch klug geschissen.. das sind die doppelten buchsen fuer hinten und nicht die einzelne, die im quertraeger sitzt :b
#18 |
