Old 06-22-2018, 08:55 AM   #26
JohnMc
JohnMc's Avatar
Originally Posted by J2_ View Post
And you get 5 rearward gears too! (They rotate anti-clockwise)
I remember a project thread here (I think?) where someone was swapping in some sort of zoomy Audi motor. I'm not sure when it dawned on them that the Audi motor turned the wrong way, but I want to say it was almost as late as the first drive.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 06-22-2018, 09:50 AM   #27
jvluntzel
HAHAHA WOW Everyone!
Loving the responses in this thread! Lots of great info!
Originally Posted by white855T View Post
2jz fits with the stock na intake.
did you install one in your 740? More info and pics please!
Originally Posted by 240wagonguy View Post
Do the B6304S! It'll be a 100% bolt in swap since you are staying auto, and I think your stock driveshaft might even work. I bought a complete S90 for $100 and tore it down for everything I needed. I suppose the junkyard route would work fine too.
Originally Posted by poulrais View Post
The electronics to run the B6304 on a Regina platform are hardly "bolt on"...
Originally Posted by Broke4speed View Post
Not exactly.
I'm in the middle of a B6 swap, with an AW30-40e, and the 'Homer' swap mounts. The stock AW70/71 driveshaft is too short. It's not possible to move the engine back any further to make up the slack either, since it would then mean cutting the firewall.
Then you need to sort out the coolant hoses, wiring, sensor placement (to have a working coolant gauge), throttle cable, transmission mount, etc etc. I was able to use the stock BW55 tranny mount bracket, but I had to add a 1-1.5" spacer to get it to bolt up to the transmission. I am in the process of making a spacer to allow the stock driveshaft to be used, but if it's thicker than an inch, I'm not going to risk it unless I can be 100% sure it spins true.
B6304S is bolt in for a 740, which is what the OP has. Can't tell you any specifics for the auto as I have a T5 manual I am using. Wiring will bolt in too if you disassemble most of the car.
Looks like some conflicting answers here....lets narrow it down:
1) I have an AW70. I would be open to grabbing the transmission with the B6304 seeing as how the AW70 isnt the strongest thing on earth. If I did, would my driveshaft work? or do I need to stay with the AW70/71 (I could grab an AW71 too) to have my driveshaft work.
2) Does anyone have pictures for fitment (or not) of the motor mounts, tranny mount, driveshaft yadda yadda.
3) I would be running the full electronics from the b6304s .... unless someone says rex can do it..lol
Lets keep this going!
Originally Posted by JerryJS8 View Post
Do a Honda B16, heard you can run massive turbos on doz dangs!
LULZ I need a vape first
jvluntzel is offline   Reply With Quote
Old 06-22-2018, 09:52 AM   #28
240wagonguy
i mean 960 is the same chassis as your 740...so yea, the engine mounts and trans crossmember bolt in.
Old 06-22-2018, 09:53 AM   #29
Broke4speed
Broke4speed's Avatar
You'll have to use the B6304 tranny, since the bellhousing pattern is different than the redblock AW70. It won't fit the whiteblock.
As far as driveshaft...no idea. I guess it depends on where the mounts put the engine vs. how much longer/shorter the AW30/40 is to the AW70.
Sorry for any confusion my post caused. I totally didn't see the part where you said 740.
1984 B6304S/AW30-40 w/Poi-Shift.
Old 06-22-2018, 10:10 AM   #30
poulrais
poulrais's Avatar
And the driveshaft from a 960 sedan with the independent rear suspension and a live axle 960 wagon might be different too. I would try to snatch a complete drive train from a live axle 960 wagon since it basically have the same rear end your car has.
1990, Volvo 740 16v +T
Old 06-22-2018, 10:11 AM   #31
jvluntzel
Seems like everyone wants me to go B6304s.....
Old 06-22-2018, 11:31 AM   #32
iLoveBeingTeaBagged
I donít
iLoveBeingTeaBagged is offline   Reply With Quote
Old 06-22-2018, 12:15 PM   #33
jvluntzel
Originally Posted by PromiseRing View Post
I donít
whats your recommendation?
Old 06-22-2018, 12:27 PM   #34
iLoveBeingTeaBagged
lh2.4 conversion with b230f+t (or ft). That will be easiest and quickest turn around time. Will still be slow though with stock parts lol
You could swap in an aw71 from a turbo car and I'm pretty sure it's a direct swap. Accumulator mod for quick hard shifts and you're good to go.
Old 06-22-2018, 12:31 PM   #35
poulrais
poulrais's Avatar
Go B230FT, swap your AW70 for a manual, keep the Regina and buy my Regina dog dish flywheel!
Old 06-22-2018, 12:55 PM   #36
jvluntzel
Thats a very serious contender here. Theres a 93 at my local yard....thats the best redblock right?
Maybe if you were local!
Old 06-22-2018, 02:58 PM   #37
iLoveBeingTeaBagged
Yeah a 93 will have the bigger rods and usually squirters too. Those aren’t necessary but may be beneficial.
Old 06-22-2018, 03:43 PM   #38
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
16v + Turbo would be a great way to go.
If someone forced my to stay redblock, that is what I would do.
#79WDP
Old 06-22-2018, 04:03 PM   #39
Jack
Banned
Jack's Avatar
B18
Old 06-22-2018, 04:49 PM   #40
poulrais
poulrais's Avatar
Don't cost that much to ship you know!
Old 06-22-2018, 07:33 PM   #41
Klaptrap24
Important questions that have not been asked: what is your budget, and what is your skillset like?
Klaptrap24 is offline   Reply With Quote
Old 06-23-2018, 09:28 AM   #42
240wagonguy
I mean, yea. If you can find a 16v head in good shape. People usually want good money for those. Then you gotta grind the pistons, do all sorts of other bs, upgrade the trans now because the m46 isn't going to take that abuse. $100 wrecked S90 donor gets to be very appealing at that point, and I prefer to have dirt common engine parts on a daily beater.
Old 06-23-2018, 09:39 AM   #43
oldschoolvolvo
oldschoolvolvo's Avatar
^^wise words.
-Mike
1998 V70 T5
|Feedback|
Old 06-23-2018, 02:45 PM   #44
bmos
bmos's Avatar
I'd honestly just get a used b230ft (and optionally freshen it up a bit) unless you're dead set on swapping it. If you are going to swap it the LS conversions are so well documented it seems like the obvious choice although I definitely hear you about the inline-preference.
Can Regina manage a turbo setup?
Easy, just put the whole Honda drivetrain in the trunk/hatch. Rear-engined VTEC Volvo?
bmos is offline   Reply With Quote
Old 06-23-2018, 03:24 PM   #45
J2_
J2_'s Avatar
There are guys here in the Netherlands that have developed parts so they can run honda motors clockwise.
Cool stuff. Made me think about a rwd honda swap for quite some time..
J2_ is offline   Reply With Quote
Old 06-25-2018, 12:30 PM   #46
jvluntzel
Hey everyone! Ill be going to the junkyard either this weekend or next week! I wish there was a turbobricks FB page or smth where I could live stream whats in there!
Old 06-25-2018, 12:46 PM   #47
GTJordan
Been here for too long
GTJordan's Avatar
There is. It's called Turbobricks
Old 06-25-2018, 05:56 PM   #48
John V, outside agitator
Banned
G'day Fred, as you're a noobie here you don't understand how it worksd yet.. See this is primarily a forum for young pups in their teens and 20s.. It is a requiremnt to NEVER ask about end use, budget, tools owned, experience or really anything before launching into suggestions on exactly what the other guy should do..So almost nobody ever does. The boys here get all pissed off and say your (what used to be you're) being "condensational" or a "know it all" if you ask questions...
So with that in mind I recommend you should be converting your car to one of those Foul-coon DOHC 24v inline 6s with minimum 2 turbos. Got it? Should be super easy and only cost the normal Turbobrick budget of $17.95..US dollars of course. See how it works, din't even ask what car you have..
Trust me, I've been reading here for more than 10 years and I getting the hang of how things work.
You do have a Volvo dontcha? Well never mind do it anyway.
And remember, everything everybody says here is fawkin brilliant...just some things are fawkin brilliant-er than others, but its all brilliant.
Old 06-25-2018, 06:00 PM   #49
Buy another cheap disposable euro-trash car that one's done.
Old 06-26-2018, 09:00 AM   #50
jvluntzel
This is perfect
