Old 07-01-2018, 06:14 PM   #1
papsimagoo
Delicious Boost! Nom nom
papsimagoo's Avatar
Default Another Cometic MLS Gasket Thread / Dished Piston Measurement
Heads off, this is my first cometic replacement. Don't know what thickness originally was used. If they print any ID/PN on them let me know, I didn't see any.
Piston to deck measurements- ~ 0mm-.4mm below block deck height on cylinders 1 and 4 averaged out...
So I believe it goes .003" for every 1000 rpm, redline 7k so 7x.003=.021 +.003" for safety puts me at ordering around a .030" compressed....BUT i have waveguide/large valve relief pistons..want/wanted to make sure I am doing this right before trashing a motor. Do the pros factor reliefs/dished pistons into their CRs?
BTW going to use real hylomar.
Engine Specs:
2.5l B230F + T by RSI
RSI 86mm Billet Stroker Crank
RSI 158mm H-Beam Connecting Rods
RSI Waveguide 8v Turbo Pistons
Cometic MLS Head Gasket
RSI Stage 2+ Cylinder Head Prototype
RSI Race Valvetrain Kit
RSI Stage 3 Turbo Cam Prototype
RSI Square Tooth Adjustable Cam Gear
RSI Twin Scrool SS Turbo Header
RSI Poly Engine Mounts
Twin Tial MVS 38mm External Wastegates
Greddy Type S Blowoff Valve
Holset HX40/Garrett Hybrid Turbo
Isuzu NPR Intercooler
NIW Motoring Intake Manifold
Megasquirt 2 EMS
Mitsubishi Coils
Injector Dynamics 1600cc Fuel Injectors
Head off1
89' RSI 245
Delicious BOOST! Nom Nom Nom
papsimagoo is offline   Reply With Quote
Old 07-02-2018, 11:25 AM   #2
shoestring
shoestring's Avatar
Yes, you must factor piston dish volume.
The formula is:
(Cylinder volume + combustion chamber volume + head gasket volume + piston dish volume (whether positive or negative) + piston deck volume + ring land volume)/(combustion chamber volume + head gasket volume + piston dish volume (whether positive or negative) + piston deck volume + ring land volume)=compression ratio
Any machinist will tell you that both the block deck and head deck need to be cleaned up to use an mls gasket, but I have gotten away with just doing the head every time in N/A applications.
Old 07-02-2018, 12:24 PM   #3
DET17
Reformed SAABaholic
Been running a MLS gasket for 20K miles with a planed and polished head, block just wet sanded with 400 and 800 grit on a flat steel plate. Remember, the head being aluminium is what needs to expand with its 2.5x thermal expansion rate vs. steel/iron (or thereabouts ).
Below .036" there is negligible gain per the SAE.
Old 07-04-2018, 01:48 AM   #4
papsimagoo
papsimagoo's Avatar
Went with .030" cometic, old looks like a .027”. Will report back. If anyone reads this and knows a hylomar source in PDX... I'd like to know.
Old 07-04-2018, 06:47 PM   #5
Stiggy Pop
Stiggy Pop's Avatar
Why do you think you need hylomar? Properly prepped and cleaned surfaces make an MLS gasket happy.
'79 242
943 pickup
Old 07-05-2018, 08:19 AM   #6
chirish1234
chirish1234's Avatar
where do you guys source your MLS gaskets?
1989 Volvo 245-GO FAST DRIFT CAR!
1988 Volvo 245/ B230FT, 16T @ 13PSI, G80, M46+Craving boost short shifter, Battery relocation, 15x7 ARES, Ecodes, Euro front end, 25/21 sways, too much to list Sold
1971 Volvo 144/ project
CoconutLeah:~Hes not afraid to hang out the window with a camera while passing you on the right at 70mph
chirish1234 is offline   Reply With Quote
Old 07-05-2018, 08:26 AM   #7
GTJordan
Been here for too long
GTJordan's Avatar
Cometic. Jegs sells them cheaper than the home site. Atleast when I ordered mine they did.
Old 07-05-2018, 12:29 PM   #8
DET17
Reformed SAABaholic
Because StealthFTi recommends it. Just use a light coat of hylomar.
Old 07-05-2018, 01:09 PM   #9
GTJordan
GTJordan's Avatar
From Cometic
WHY DOES COMETIC RECOMMEND MLS GASKETS TO BE INSTALLED DRY?
Cometic Multi-Layer Steel (MLS) head gaskets go on dry because they are coated with a sealant. Each MLS head gasket is coated with a .001" thick Viton rubber that is bonded to the outer stainless steel layers. Adding an additional sealer can hinder the performance of an MLS head gasket.
