Old 07-03-2018, 12:36 AM   #1
LeedomtoFreedom
LeedomtoFreedom's Avatar
Default Boost in first?
Running an HX35, obviously very large.
Just checking to see if others with similar setups haven't been able to develop boost in first. I understand why it wouldn't build boost but I'm just gauging the audience.
If not, have any found ways of improving this, possibly manifold, wastegate, 16v im guessing.
Not running any ECU with anti-lag as well.
81 264 - Driveway ornament
90 245 - becoming 16v
Old 07-03-2018, 04:21 AM   #2
Lankku
Lankku's Avatar
I've had two redblocks with HX35 and both had boost on 1st gear. Other had only really quickly made exhaust manifold and mildly ported 531 on top of a B230F and the other was a stock B230FT. External 38mm wastegates with ~0.5bar spring and a boost control valve above the diaphragm.
HX35 isn't that big really.
444 -55, 145 Express -71,
242 DL -80 (was 4.6l)sold, 245 -88 "B6284T" sold, 245 -90 "B6284T", 945 Classic, 965 -93 B6304T
Old 07-03-2018, 09:11 AM   #3
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
depends on a lot of things. stock lh? auto or manual? what's the final drive? what engine? what cam?
Megasquirt Tuning!
Old 07-03-2018, 09:25 AM   #4
JohnMc
JohnMc's Avatar
With my m47 and an automatic trans rear axle (3.73) I rarely ever got into much boost in first gear, maybe a little, but then you'd gone 30 feet and needed to shift into second already. Occasionally you'd get luck (cold day, going uphill maybe) and get some good boost going, but then it would break a motor mount. This was before I put a ratchet strap on it.
Then I got a Mustang T5 with a significantly taller first gear and could routinely hit boost in 1st gear. But that would jsut spin the tires, not a lot of traction on a 240 wagon with a stiff-ish suspension.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 07-03-2018, 12:56 PM   #5
DET17
Reformed SAABaholic
AW71 with 3.73 final gearing, never have any issue getting boost in 1st.
Old 07-03-2018, 01:49 PM   #6
LeedomtoFreedom
Sorry let me clarify what I've got
lightly ported 90+
lh2.4
t-5 tranny (cant remember t-5 model to find first gear ratio)
3.55 rear end
IPD turbo cam (which is all up top in the range)
530 head
stock intercooler from 940(about to upgrade to large one)
Old 07-03-2018, 02:00 PM   #7
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
3.55 rear gears, should for sure make boost in first. I would suspect WGA stuffs if everything else is up to snuff. What PSI are you running?
1980 242 Turbo
2004 V70R
Old 07-05-2018, 01:40 PM   #8
LeedomtoFreedom
22psi. I paid closer attention and it seems to just barely build boost. I'm not sure if I'm just being naive and expecting boost build like the 15g.
Old 07-05-2018, 02:18 PM   #9
RoadRacer4Life
Owner: DeathWagon
RoadRacer4Life's Avatar
90 245GL Build thread 2JZ coming soon...
91 245GL Dumpin Doughnuts Battle Wagon Chumpcar
93 245GL Street Beater
Old 07-05-2018, 02:42 PM   #10
LeedomtoFreedom
Thanks chief
Old 07-05-2018, 02:59 PM   #11
linuxman51
linuxman51's Avatar
spraying it will get it up on the pipe faster
Old 07-06-2018, 02:45 AM   #12
ermit71
ermit71's Avatar
He351cw yes to first gear.
NPR intercooler
K cam
Mildly ported 530
Bondo Exhaust header
3" exhaust
15# of boost by 3200
42# injectors
LAO chips
3" AMM
1st os pistons
Squirters
Chevy T-5
4.10 rear end
Three stickers of various origin= an extra 15hp
Feedback
ermit71 is offline   Reply With Quote
Old 07-08-2018, 08:18 PM   #13
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
Yes.
Also will be pretty much an on/off switch and don't expect much below 4K.
Old 07-08-2018, 08:44 PM   #14
eabras
Not a hx35, but hy35 and the datalogs show positive pressure from about 2700rpm in first gear on my old b21. But at that rpm we are only talking 1-2psi... If I rev it in neutral it would almost hit 14psi @ 7000rpm.
eabras is offline   Reply With Quote
Old 07-11-2018, 10:09 PM   #15
aaron740gl
aaron740gl's Avatar
What turbine housing?
91' 744se with some stuff done to it
aaron740gl is offline   Reply With Quote
Old 07-12-2018, 11:39 AM   #16
LeedomtoFreedom
12cm housing with internal wastegate I believe. I just installed an ebay special intercooler and got rid of some small pinhole leaks, helped a little. It builds boost, but like you said, very little.
