Old 07-03-2018, 12:39 AM   #1
940wagon
Default 1uz 7/900
Does anybody know someone or a forum member on here that has a 7/9 series with a 1uz in it? Would be cool to chat with them personally about the swap. I searched but only found like a dozen bench racing type posts, nobody who actually owned the motor let alone had it installed.
Picked up a 97 LS400 for $500, runs and drives but the guy bent up the front end pretty good. Just trying to figure out what to do with it now...
Thanks.
940wagon is offline   Reply With Quote
Old 07-03-2018, 01:54 AM   #2
Brotkasten
Jonas
Brotkasten's Avatar
http://forums.turbobricks.com/showthread.php?t=252028
91' 940 B230FB+T M90
Old 07-03-2018, 12:47 PM   #3
940wagon
Thanks, I sent him a PM but looks like he's not active on here.
Old 07-03-2018, 09:56 PM   #4
arsenix
I'm building one right now. 1UZ, 80lb Deka injectors, custom microsquirt based ECU, E85, single ebay turbo. Hooked to BMW 420G 6 speed. Have the motor (actually several of them), fabbed the trans adapter. Need to rip the car apart and stuff it in there
If you are just going to stuff it in there with the factory ECU and trans... what else do you need to know? The oil pan won't work since 1UZ from LS400 is front sump. You can buy a steel rear sump pan on ebay for $350. Should work. Are you staying autotragic?
88' 740 GLE Wagon - B230FT, T5 Trans, MSII-extra, G80, 3" T->T Exhaust
- - > Project Thread < - -
My new project - 1990 740 SE Wagon
arsenix is offline   Reply With Quote
Old 07-04-2018, 04:02 PM   #5
940wagon
Hey there.
It will stay a stock motor, and will be mated to a 5 speed trans out of a KA 240sx. What vehicle is yours going into? I can get a rear sump sc400 pan for free locally, but was curious about how it may fit even with the rear sump pan.
Old 07-05-2018, 08:11 PM   #6
arsenix
The SC400 pan is really more of a "mid sump". Def won't work without serious mods (ie probably fabbing a new sump). If you cut the sump in half it might fit. I have one in the garage. This was the direction I was going to go before I decided to just make a custom steel pan. Buy this: https://www.ebay.com/itm/Toyota-Lexu...YAAOSwCxdaroCk
Mine is going into my 740 SE.
Old 07-05-2018, 10:50 PM   #7
S70T5fivespeed
S70T5fivespeed's Avatar
Mine is going into my 740 SE.[/QUOTE]
Where da pics at
99 S70T5M black on graphite suede
91 740SE white on black
90 740TI oe aero kit black
In the barn: 67 123GT
S70T5fivespeed is offline   Reply With Quote
Old 07-06-2018, 05:54 PM   #8
940wagon
Darn, was hoping to get away with the SC pan. Any interest in making me a pan? Have you got motor mounts made yet?
