Old 07-03-2018, 06:33 PM   #1
Tfrasca
Tfrasca's Avatar
Default 140 Pinion Angle
My brand new T5z has all the same vibrations at cruise and decel that my old WC T5 did. The transmission is angled 5 degrees downward, and the differential is at 0 degrees. I have the stock 2 piece drive shaft.
Am I oversimplifying things to say that if I adjust my diff to point up 5 degrees (opposite the transmission) that my vibration issues will get better?
Or is there more to it with a 2 piece drive shaft?
Old 07-03-2018, 06:52 PM   #2
Spicer has an online calculator to determine the correct drive line angles.
https://spicerparts.com/calculators/...gle-calculator
Tremec has an app for that.
http://www.tremec.com/menu/tremec-toolbox-app/
Old 07-03-2018, 07:03 PM   #3
Tfrasca
Tfrasca's Avatar
Thanks Ian. I'll try the Spicer calculator tonight. The Tremec one is designed for a one piece driveline, so it's not super helpful to me.
Old 07-03-2018, 08:52 PM   #4
AndrewNance
Amateur hour!
AndrewNance's Avatar
The Tremec app is pretty neat. I used it to set up the 8.8 and one piece driveshaft in the 122. No vibrations at all. I was under the impression that you wanted your pinion angle to point up as much as your tailshaft points down. Maybe that’s for one-piece driveshafts. Pretty sure I set mine up at 4* and all is good.
Its been a while since I set up the 142 but I think I measured the downward angle of the rear section of the driveshaft and pulled the pinion angle up to match.
'71 142
'80 245
Feedback
Old 07-03-2018, 09:50 PM   #5
oldschoolvolvo
oldschoolvolvo's Avatar
This may be helpful.
File Type: gif 92D444D4-BBBC-4CAA-A0D5-6851336D7EEC.gif (20.1 KB, 67 views)
-Mike
1998 V70 T5
|Feedback|
Old 07-03-2018, 09:50 PM   #6
Tfrasca
Tfrasca's Avatar
That's what I was thinking of doing for this, but the 2-piece changes that, I think. I'm going to go measure the angles of both sections of driveline, then plug it all into the Spicer app and see how it looks.
Do you have T5s in either of those cars?
Old 07-03-2018, 11:38 PM   #7
Tfrasca
Tfrasca's Avatar
I took some measurements.
-Trans output points down 4.4*
-First driveline points down 1.7*
-Second points down .7*
-Pinion is at 0*
My operating angles are, from trans to pinion: 2.7, 1, and .7*
Spicer wants each end of a driveshaft to be within 1* of each other. If I can shim my trans mount to get the output shaft close to 3*, then make some adjustable torque rods and set my pinion to to around 2*, that should get all three operating angles pretty close to each other.
Unfortunately, the center support can't really be moved, so I'm stuck with the factory position.
Old 07-04-2018, 01:06 AM   #8
If you're adjusting the pinion angle, consider dropping it down 1°-2° from the spec's to compensate for axle twist under acceleration.
Old 07-04-2018, 02:49 PM   #9
gsellstr
gsellstr's Avatar
For test purposes on the trans, you can shim it up via a spacer under the mount, down via spacers between the crossmember and frame, depending on what crossmember setup you have. I used the SN95 crossmember, so it's 4 vertical bolts. Might be a bit more hassle if you kept the 140 crossmember though.
Definitely need to get that front section addressed, probably a good bit of your vibration there.
Also take into account horizontal angles as well. Those angles are probably off on the front section, since the T5 doesn't sit centered in the tunnel like the M41's do.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 07-04-2018, 06:10 PM   #10
Tfrasca
Tfrasca's Avatar
Yeah, I plan to give it a bit of room to rotate up. I have no vibration under hard acceleration, so it's probably rotating up to a better angle under load as is.
Yup, stock 140 crossmember, so I can't shim that down. But it seems like the trans would want to come up anyway. I already have a 10mm shim pushing the trans up, but any further and it'll probably start hitting the tunnel. I think my horizontal angles should be pretty good. My T5 slip yoke is pretty much dead center in the tunnel. I'll try to figure out how to measure that though.
My next move is adjustable torque rods. Does anyone know if the 240 ones are the same, just a different length? I'd rather not pull mine, cut them, measure the ID, then have to wait a week while I order the parts to weld up.
Old 07-04-2018, 06:22 PM   #11
planetman
planetman's Avatar
The 240 torque rods are different.
FYI, new torque rods are available for $66.00 each.
Although ride quality would suffer, you could make your own and use heim joint ends and spacers to center the heim joints. Both of the stock bolts for attaching the torque rods are 1/2" diameter.
I have good used torque rods too.
Eric
Torrance, CA 90502
Old 07-04-2018, 08:10 PM   #12
142 guy
Check Yoshifab. They are now offering adjustable torque rods for the 140 / 164. A little pricey; but, very trick looking. As mentioned, you could fabricate similar rods by using components from somebody like Speedway or you could modify your own rods to make them adjustable.
Be aware that heim / spherical joints are not the be all and end all. Unless sealed in a bellows, they can become noisy once they accumulate dust leading to some interesting noises during suspension movement.
Old 07-04-2018, 08:38 PM   #13
gsellstr
gsellstr's Avatar
I'd lengthen your stock ones personally, but that's just me.
For checking centerline, drop a string from the center of the crank pulley, another from the center of the pinion, then see where everything lines up along the way. I did that, put tape on the garage floor with a mark, then ran a string along that. I bet you will find your trans sits off to the passenger side a good bit compared to the center bearing.
Old 07-04-2018, 10:42 PM   #14
AndrewNance
Amateur hour!
T5 in the 122. M41 in the 142.
I made some adjustable torque rods out of stock 122 rods after my heim joints left me wanting something...better. I actually used some adjusters I had bought for 240 torque rods but the ID was the same on the 122 ones. So I’m guessing they never changed that. I’m almost positive it’s 3/4” ID and accepts a 1/2x20 adjuster. I’m pretty sure I bought two of these pairs:
http://www.barnes4wd.com/Threaded-Tu...TPI_c_181.html
Old 07-05-2018, 09:45 AM   #15
gsellstr
gsellstr's Avatar
I went with the tractor pin route since they are fine thread, but also because I like the safety of knowing nothing can adjust itself unless one end of the arm comes completely off.
Old 07-05-2018, 11:01 AM   #16
Tfrasca
Tfrasca's Avatar
Yeah, I like those, but I'm not going to use any heim joints on this car. Too much NVH. I'll modify my stock ones and keep the rubber bushings.
