Old 07-09-2018, 11:44 AM   #1
jvluntzel
Default Rex Regina + T Completed
Hello everyone!
I just wanted to start a thread for those out there with the Rex Regina EFI in their volvos who need more power.
As detailed in this thread:
http://forums.turbobricks.com/showthread.php?t=342889
My stock motor was toast and I found a nice healthy 95 year B230FT and grabbed it and the transmission.
I decided to keep the Rex Regina EFI for multiple reasons.
  1. 1 MAP based over MAF based for ease of intake installation and less problematic
  2. 2 Very similar to EFI used on jeep 4.0 and there is a ton of documentation on turbocharging those
  3. 3 A CHALLENGEEEEE
The stock map sensor is good for up to .483 BAR (7 psi) so staying under that for now is critical.
► I utilized OEM Volvo Bosch Orange injectors (315 cc from 850 turbo) As they are high impedance (no injector resistors needed) and have a better spray pattern than the factory 940 turbo injectors. Along with this I used the 3 bar FPR from the 940 turbo.
► The reason for the 315cc injectors is the following equation:
Est HP: 190.00 (non turbo hp 115 + 10/ psi = 185 ish)
BSFC: 0.60
Duty Cycle: 0.80
The 315 injectors rating is a@ 2.5 bar. So at 3 bar I am getting 378 cc/min
Injector size = (Hp * BSFC) / (# of injectors * duty cycle)
Injector size = 35.625 lb/hr = 374.1 (only 1.04%) from my chosen injectors.
► I used the Rex Regina intake manifold as it has a provision for the cold start injector and there is no hole for the now non existent EGR (I took the fitting from the exhaust manifold and welded it shut)
Ok now for the turbo I have the Mitsu 13C. Running stock boost pressure (7 psi) I also have a wideband and I am using the emulated narrowband output being fed to the ECU. Stock timing as well.
The car runs amazing and is pretty dang fast. I am using Lambda for the Air fuels and under boost It holds at .8-.83 (11.76-12.20) which is very safe. At idle and off throttle it targets and holds 1.00 (14.7)
I am confident that the Rex Regina is an excellent choice for those looking for lower boost pressures, and I will be experimenting with different map sensors to see how it handles it (and if any tuning is needed)
Let me know if you have any questions
jvluntzel is offline   Reply With Quote
Old 07-09-2018, 12:14 PM   #2
rwb
Did you have any trouble getting the ECU to work with the wideband sensor / narrowband simulation? Is this still using the Regina NGK 02 sensors?
rwb is online now   Reply With Quote
Old 07-09-2018, 12:24 PM   #3
iLoveBeingTeaBagged
Awesome, but those injectors should be high impedance, not low. High impedance do not need the resistor pack.
Feedback Thread
Current:
93' 244T m47
93' 245 m47
90' 744 AW70
94' M-Edition Miata, 93k
95' Camry auto, 246k
93' Camry auto, 278k
Past:
80' 242gt m46
88' 245T m47
92' 940 turbo AW71
94' 945T AW71(L?)
iLoveBeingTeaBagged is offline   Reply With Quote
Old 07-09-2018, 12:52 PM   #4
jvluntzel
Fixed lol I was thinking about low while writing
I used a single wideband sensor with a controller from 14point7 (SLC Free 2) and that controller has a narrowband output. Runs great.
Old 07-09-2018, 12:58 PM   #5
iLoveBeingTeaBagged
You should post some videos of some pulls!
Old 07-09-2018, 01:31 PM   #6
bmdubya1198
Very nice job! Great to see how quickly you got it all done!
Makes me want to get off my ass and get a new M46 for mine.
1998 V70 GLT Black/Beige
2000 V70R Venetian Red/Black M56 swapped
1988 744 TI M46 "Goldilocks" Still kicking myself for selling this one
bmdubya1198 is offline   Reply With Quote
Old 07-09-2018, 01:41 PM   #7
jvluntzel
I will soon!
Do it man! its awesome!
Old 07-09-2018, 01:44 PM   #8
poulrais
poulrais's Avatar
Nice job!
I still have that Regina dog dish flywheel if either one of you ever decide to go manual!
1990, Volvo 740 16v +T
poulrais is online now   Reply With Quote
Old 07-09-2018, 02:02 PM   #9
jvluntzel
Originally Posted by poulrais View Post
Nice job!
Thanks for letting me know!
Old 07-10-2018, 05:40 PM   #10
jvluntzel
I need more boost.... Lol
Old 07-10-2018, 05:45 PM   #11
iLoveBeingTeaBagged
Old 07-10-2018, 07:53 PM   #12
bmdubya1198
I know I'll outgrow my stock turbo pretty quickly once my 740 is going!
Old 09-05-2018, 07:31 PM   #13
jvluntzel
Hey y'all! Update time!
I've put a few thousand miles on the car since it's been turbo swapped and the Regina turbo setup is running great!!! I have been running wastegate pressure (5-6) psi and my afrs have bee great. This is on the 315cc orange (@3.5 bar) injectors but my fpr is 3.0 bar so they are more like 270cc.
I got a set of v70 400cc blues (which at 3.0 bar is more like 340cc) and a nice MBC (turbonetics style)
I did some testing watching the afrs and have it set at 12 psi and she runs awesome!!!! This is on completely STOCK Regina EFI. No piggyback or anything with an safc I could easily crank the duty cycle up and run more boost
Happy turboing and have a great day!!!
Old 09-08-2018, 10:54 AM   #14
esmth
dirty swede
esmth's Avatar
How does regina handle ignition timing in boost?
Old 09-08-2018, 03:10 PM   #15
sbabbs
sbabbs's Avatar
The Rex part of the regina does the timing. It is an ignition box that runs the timing. Never been cracked. I did take the top off one here a few weeks ago and posted a picture of it and it's Motorolla chip.
To answer your question it probably advances the timing as the revs go up just like any other non turbo ignition curve.
Old 09-08-2018, 03:20 PM   #16
esmth
dirty swede
esmth's Avatar
Ah, so not really ideal. Happy it works well for OP though
Old 09-10-2018, 09:39 AM   #17
jvluntzel
Yeah I have a knock box to record counts and havent had any issues yet..but I dont like it.
I am looking into a system like the MSD boost retard for safety. Ill let you know how it goes.
