Old 07-10-2018, 04:47 PM   #1
TurboDenny
Why am I here?
Default Deleting Brake Distribution Block.
As I'm wrapping up the install on my ATS brake upgrade on my 244, I noticed the distribution block was damp. Upon attempting to break free one of the brake lines the entire port broke off the block. I sat there staring at it in frustration, but then realized this is a great time to delete this dreaded device.
https://imgur.com/EeFr4DE
What is the best way to replace it? Adjustable proportioning valves are fairly inexpensive.
https://www.summitracing.com/parts/sum-g3906/overview/
I assume the dual inlet, triple outlet setup on the one linked above is for both front calipers and a single line to the rear? Or is there a more simple setup?
Fairly new to the "performance braking" field. This is a street car that is driven spiritedly through long, twisty country roads.
Thanks.
Instagram: @itstotesdenny
Old 07-10-2018, 09:01 PM   #2
Marvelous3
Who engineered this?
Marvelous3's Avatar
Put a block from a 91 or newer block in. You can probably delete the portioning valves if yoyleft the stock 240 calipers in the rear. I did not on mine but probably should have.
Old 07-12-2018, 02:30 PM   #3
Wren
Porkchop Sandwiches
Wren's Avatar
It has to be a '91 only, non-ABS junction block. No sensor to leak, but it still has all of the ports for the 2-line front calipers.
Old 07-12-2018, 02:48 PM   #4
You can still get them new and they aren't that expensive.
http://212.247.61.152/us/main.aspx?p...084&searchfld=
Old 07-12-2018, 10:35 PM   #5
dbarton
Dejected by Volvo
dbarton's Avatar
I'm thinking probably not. I'm seeing it as NLA at every usual Volvo part source.
Dave B
Old 07-12-2018, 10:58 PM   #6
We've had to get Volvo to reinstate several part numbers that were discontinued even though they still have stock in Sweden. GCP shows that there's 90 of them currently in stock.
Old 07-13-2018, 08:21 PM   #7
dbarton
Dejected by Volvo
dbarton's Avatar
Thanks. I ordered one from VP just to have it in case I need it someday before the go extinct.
Dave
Old 07-15-2018, 09:23 AM   #8
freevolvos
freevolvos's Avatar
wow broke of like that with a wrench? guess you know why it was damp! it's amazing it took 2000 p.s.i. of hydralic pressure lol
