Old 07-11-2018, 12:26 PM   #1
swedishK
Design by Beefsma
swedishK's Avatar
Default Penta 2.5L B21ft?
I might have a line on a cheap aq151 possibly two, and was wondering if I’d run into any issues swapping the 2.5 block into my turbo kjet wagon. I’ve seen b230 heads on 2.1 blocks, so I’m assuming they’d go the other way as well? Will a mildly modified turbo kjet fuel system be adequate to keep up with 400 extra CCs? The motors have been sitting outside on a pallet for a bit, and will probably need a full rebuild. Is the extra displacement worth the effort?
Now I’m unsure if they’re actually 2.5 blocks. One has a 531 head and the other has what appears to be a 405. Both single carb. I did not see any AQ designation on the ID tag by the starter, however both tags start with the prefix 250A.
grand luxe touring til i die.
Prof. Dr. Dr. Andrew Schaafsma
...weld the diff, and proceed to everywhere.
swedishK is offline   Reply With Quote
Old 07-11-2018, 05:24 PM   #2
Can play the blues
Single carb penta will have the A cam. The AQ151 is the 16V penta. You are looking at two types probably a pre B230 block one with the 405 head and a B230 based one with the 531 head. I think they may have also called them AQ130 or AQ131.
You may have to drill some holes for a sensor or two. But the block and head would work for a buildup. Or you could use the heads if they aren't engines with the longer crank throw. Make sure you check that number four exhaust port. My penta sourced 531 needed a good bit of welding to repair it from corrosion.
Old 07-11-2018, 05:52 PM   #3
77volvo245
77volvo245's Avatar
aq250 are b230 blocks and are 8v 2.5l
aq251 are b230 blocks with 16v heads
they started numbering aq250 after 92 i think
STSmachining
Old 07-11-2018, 09:02 PM   #4
swedishK
Design by Beefsma
swedishK's Avatar
so if i can get one for $100 i should go for it eh?
Old 07-11-2018, 11:52 PM   #5
Can play the blues
That's a very fair price just for parts. Have fun with it.
Old 07-12-2018, 12:42 AM   #6
apachechef
Burnt Sierra Madre
AQ171?
Dammit, Lummert.
Old 07-12-2018, 12:57 AM   #7
mark244turbo
mark244turbo's Avatar
Buy it before someone else does!
1994 960 B204FT, full options, leather interior.
1991 745 B204GT (Swede Sixteen VT) M90 conversion.
1986 745 B230FT, 302mm V70 brakes, camber mod. (sold)
1983 244 turbo B21FT/AW71 - leather /airconditioning
1987 244 GLT - Polaris, Strutbar, viking motorsport lower chassis brace, k-cam, gaz strut/shocks, pu-bushings
mark244turbo is offline   Reply With Quote
Old 07-12-2018, 01:41 AM   #8
Jack
Banned
Jack's Avatar
You buy that **** when you see it
Old 07-12-2018, 02:21 AM   #9
122power
dude
122power's Avatar
Fair? Thats a steal at that price.
Old 07-12-2018, 02:36 AM   #10
swedishK
Design by Beefsma
swedishK's Avatar
picking up two 250a motors on friday. $100 a piece. will update on condition when i can dig into them.
Old 07-12-2018, 03:26 AM   #11
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
AQ151 is the 8 valve 2.5 liter stroker engine, essentially an early 250A. The AQ171 is the 16 valve 2.5 liter stroker, which became the 251A. In the early years, the number was the horsepower the engine provided. Case in point, the AQ255 V8 engine was not a 4.2 liter V8, but a Chevy 350 smallblock.
Old 07-13-2018, 06:41 PM   #12
swedishK
Design by Beefsma
swedishK's Avatar
Any helpful tips for working with a probably saltwater motor that’s been sitting outside on a pallet for a while?
Old 07-13-2018, 08:48 PM   #13
sbabbs
sbabbs's Avatar
Drop it in a big cattle watering tank that is full of oil and let it soak for a week. Or just spray WD all over and in it every day for a few weeks.
Old 07-13-2018, 10:02 PM   #14
Harry Tuttle
Marvel Mystery Oil! You might be able to get 10 or 20 gal of it without maxing out your credit card...
who cares, push start it if you have a man tranny.
Old 07-14-2018, 01:09 PM   #15
sbabbs
sbabbs's Avatar
Probably the most valuable part on those is the crankshaft, they would both be rear thrust and forged steel and stroking on the shaft rods are stock, pistons have shorter crown for longer stroke. Should be able to get the crank out easily enough. Hard parts can be the boat exhaust manifold, but even if you break the bolts, still will come off. Basically you need to get the head off if you wanna put the short block in your car. All the boat motors I've ever had where like new inside, real clean. I've never seen a volvo penta redblock boat motor that had salt water running through it. They use a closed coolant system with a heat exchanger. The salt water would run through the exhaust manifold. That is the hardest part to take off, but if you don't need head, you can take off the head with the manifold still attached and just toss it. Cam should be a V cam, but all 250's I've seen had dual carbs and you said these only had single carbs, might be A cam then.
Old 07-18-2018, 09:02 PM   #16
77volvo245
77volvo245's Avatar
250c and 251c are all late rear thrust engines
Old 07-19-2018, 12:14 PM   #17
Lord_Athlon
Just damn
Just send it
84 242 turbo msII
My build https://forums.tbforums.com/showthread.php?t=8675309
