Old 07-12-2018, 02:22 AM   #1
Arewethereyet
Default Holset oil feed size?
Iíve had a good look fo info on what size oil line people are running on B230/ Holset combinations and itís very conflicting. Iím putting an hx52 on a 16v conversion and need to size the feed not the drain so your advise/ actual experience is appreciated. Bear in mind Iím in the UK so parts availability is somewhat different from you guys in the states.
Arewethereyet is offline   Reply With Quote
Old 07-12-2018, 03:40 AM   #2
Sweep
I think I'm running a -4 line to my HY35, if memory serves me right you'll need an M12x1.5 adapter. I'm also in the UK, parts are easy enough to come by.
Old 07-12-2018, 06:11 AM   #3
Arewethereyet
Where did you find spares from, if you donít mind me asking?
Old 07-12-2018, 01:17 PM   #4
Stiggy Pop
Stiggy Pop's Avatar
-6 in, -12 out
'79 242
943 pickup
Old 07-12-2018, 02:49 PM   #5
Arewethereyet
Whatís -12an in old money?
Old 07-12-2018, 02:52 PM   #6
AN size are in 16ths of an inch. -12 = 12/16 = ĺ"
