Old 06-19-2018, 03:53 PM   #3001
Stiggy Pop
Stiggy Pop's Avatar
Originally Posted by Homer View Post
Just installed a set of the Kaplhenke Hybrid Torque Arms. The adjustable poly torque rods had to go. No more poly bushings on this car.
Thoroughly impressed with the change.
-Noticeable improvement in axle articulation
-Driveline judder is gone (when disengaging the clutch under load)
-More smootherer
-Driveline is smoother under load
this is really shaking my tree... might have to try these!
'79 242
943 pickup
Old 06-19-2018, 04:05 PM   #3002
doucheNozzle
doucheNozzle's Avatar
All rubber for the other bushings?
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
Old 06-19-2018, 04:06 PM   #3003
Homer
OEMplus++
Homer's Avatar
Yep
-Jacob:
2006 A4 - Comfy DD
Need something TIG welded? Give me a shout.
Old 06-19-2018, 04:53 PM   #3004
JW240
All idiot, no savant
JW240's Avatar
Yes. Hybrid is the way to go.
Rest rubber, good, curious how 'hybrid' trailing arms would do on your 240. I'm happy with them but came from worn out aftermarket rubber. So no fair comparison.
240 | 1991 | 334K Km | B230F+T | Cosworth T3 60/63 | M90 | TrueTrack
Old 05-07-2019, 11:29 PM   #3005
Homer
OEMplus++
Homer's Avatar
More updates. Living in the bay area now. Still haven't quite adjusted to the lack of seasons.
240 just ticked over 50k miles on the whiteblock swap.
Rear brakes have been making noise at low speed since uh, ever. Tried everything under the sun except a rebuild. Sticky piston.
The rebuild escalated rather quickly in to powdercoating all the calipers and rebuilding the fronts too. Whoops.
While bleeding the brakes the cap on my power bleeder let go and dumped brake fluid everywhere. Turns out the threads on the aftermarket reservoir are ****. I improvised.
The original coolant reservoir was kinda bulbous and the cap was leaking so I went with retrofitting a 960 tank. OEM++ of course.
Just cut the mounting bracket off a car in the junkyard, used some simple spacers and bolted it to the strut tower. Almost like it was made for a 240.
The 940 turbo hose fit pretty well after a bit of trimming!
Aftermarket vs Genuine
Provent is doing its job even at 21 psis
Got the engine bay cleaned up and ready for Davis
Davis!
Won 1st place in the 240 group!
Most importantly, built a real workbench for the garage.
Old 05-08-2019, 08:28 AM   #3006
Jerd
Jerd's Avatar
Congrats on 1st place, engine bay looks great man. Did you stumble upon that benchtop or did you make it/have it made? When I power bleed I will be placing some c-clamps on the brake res cap for extra security! Thanks for the tip.
Jerd is offline   Reply With Quote
Old 05-08-2019, 02:38 PM   #3007
Homer
OEMplus++
Homer's Avatar
Thanks! It was a drop from a sheetmetal supplier. Had a bend put in it for the front edge
Old 05-08-2019, 02:58 PM   #3008
propav8r
F*ck Edgar
propav8r's Avatar
Car looks great as always, 50k on any swap is awesome.
easiest way to run 11's is to build a 9 second car and turn it down a little.
K-Jet to Megasquirt Article
The Departed: 1981 245, 1983 245 Turbo, 1983 244 Turbo, 1983 242 Turbo, 1984 244, 1985 245 Turbo, 1989 244, 1989 765, 1990 245 Turbo, 1991 244, 1992 245, 1997 855
Old 05-08-2019, 03:45 PM   #3009
Vol242vo
Vol242vo's Avatar
Such a clean swap. What strut brace is that? I notice the Buchka 242 has the same one, I like it!
Derek - 1980 242
Old 05-08-2019, 05:29 PM   #3010
Duder
His Dudeness, El Duderino
Duder's Avatar
Homer said something about the brace being bespoke Boeing Spec, Offizielles Zubehör! OEM+++
Old 05-08-2019, 10:14 PM   #3011
Texas240
Prius Owner
Texas240's Avatar
At this point, what 3-5 years no hiccups on the swap? I cant remember when you did the swap?
93 245 LS Engine Swap Project
Old 05-08-2019, 10:40 PM   #3012
propav8r
F*ck Edgar
propav8r's Avatar
Longer than that. It was complete when I stayed with him in 2013 and he drove it to IPD that year.
Old 05-08-2019, 11:34 PM   #3013
Texas240
Prius Owner
Texas240's Avatar
Anything over 3 years and no issues is great to me. 6 years. Impressive.
Old 05-09-2019, 12:58 AM   #3014
Homer
OEMplus++
Homer's Avatar
What Chris said. It's a combo of Deeworks strut plates and brackets. Tubing developed for the 240 strut brace that later made it on to the 787 overhead compartment support struts. (okay maybe the other way around). I designed and my personal Buchka machine shop made the bond in inserts.
Thanks! but don't forget there was that thing in the fall of 2014 where I burnt up a few exhaust valves because I didn't use genuine Volvo valve stem seals. Otherwise it's been super solid. I'll make a list of the more minor issues sometime
Old 05-09-2019, 09:36 AM   #3015
Texas240
Prius Owner
Texas240's Avatar
I completely forgot about that. Now its time to upgrade that window washer reservoir
Old 05-10-2019, 09:48 PM   #3016
Homer
OEMplus++
Homer's Avatar
Yeah looks like garbage. It'll go away whenever i get around to making an airbox.
Old 05-10-2019, 11:50 PM   #3017
Texas240
Prius Owner
Texas240's Avatar
Its one thing at a time. Next thing you know, your whole car has been rebuilt by oem parts.
