Old 06-15-2017, 01:10 PM   #2926
Homer
OEMplus++
Homer's Avatar
Yeah I'm going to have to do something.
I've been fiddling around with the fuel map and it looks like I gained 1k RPM in spool right off the bat. Haven't touched the boost control yet. ~3k rpm now.
-Jacob:
2006 A4 - Comfy DD
Homer is online now   Reply With Quote
Old 06-15-2017, 10:44 PM   #2927
Texas240
Prius Owner
Texas240's Avatar
Not to shabby
93 245 LS Engine Swap Project
Old 06-16-2017, 10:16 AM   #2928
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
I bet you see good usable torque as low as 2k rpm once you get it tuned more. I'm so glad that turbo worked out! Makes me excited for mine some day ��
Old 06-19-2017, 01:29 PM   #2929
Homer
OEMplus++
Homer's Avatar
Most definitely already do. Get to work!
For pointless comparison the holset weighs 25 lbs and the GTX is ~14
Old 06-19-2017, 04:06 PM   #2930
Quin
ಠ_ಠ
Old 06-19-2017, 05:12 PM   #2931
Stiggy Pop
Stiggy Pop's Avatar
Hey ~11lbs off the front is nothing to sneeze at. Plus think of the sigh of relief your header will breath!
'79 242
943 pickup
Old 06-19-2017, 11:53 PM   #2932
Homer
OEMplus++
Homer's Avatar
good point!
Had Alex pilot the 240 while I fiddled with the boost control. It's currently connected to just the lower port of the wastegate. 40%-95% DC is 150 kpa to 200 kpa. 96% is 220kpa and 97% gets me in boost cut at 250kpa.
Definitely explains the overshoot.
I'm going to need to replumb it for a dual port setup.
Old 08-10-2017, 02:00 PM   #2933
Homer
OEMplus++
Homer's Avatar
Update. Replumbed it for a dual port setup and recalibrated the boost control. Holy moly.
Makes positive pressure at 2k rpm and 5psi by 2300 rpm at part throttle. Full boost at 3k rpm. Time to torque is ~ 1 second. (time from opening throttle to full boost in a rev range that makes full boost) Duder informed me that's quite good, OEMs specify 0.5s on factory setups.
It's so much more fun now. Even putting around town is better.
I'll get it dynoed soon
Old 08-10-2017, 04:20 PM   #2934
Pro Sneaker Peddler
Neat
Old 08-10-2017, 04:23 PM   #2935
t8fanning
8v are still cool, right?
t8fanning's Avatar
Have you ever taken it to a drag strip?
1982 242 Turbo.
Old 08-11-2017, 01:09 PM   #2936
Homer
OEMplus++
Homer's Avatar
Neat
Nope. The M90 hates fast shifting but more importantly I don't want to.
Old 08-11-2017, 02:27 PM   #2937
BillyMaysHere
BillyMaysHere's Avatar
sounds like its a whole new beast! when you say dual port are you talking about a new EBC vac set up?
Old 08-12-2017, 09:20 PM   #2938
Homer
OEMplus++
Homer's Avatar
VEMS has been handling the boost control since the get go. I was running a single port setup on the EWG.
Now it's a dual port so the wastegate solenoid bleeds positive pressure in to the top of the actuator to hold it closed.
Old 08-12-2017, 09:44 PM   #2939
Pro Sneaker Peddler
Huh. I figured this routing would yield better responsiveness:
Old 08-13-2017, 10:52 AM   #2940
Homer
OEMplus++
Homer's Avatar
Didn't bother with it. The pierburg valve seating isn't made to do that.
Old 09-30-2017, 01:17 PM   #2941
DET17
Reformed SAABaholic
Do we have dyno data update? Looking forward to the new standard after your KAIZEN activity.
Old 09-30-2017, 01:34 PM   #2942
Pro Sneaker Peddler
Oooo I love it when you talk Lean
Old 03-11-2018, 07:03 PM   #2943
Homer
OEMplus++
Homer's Avatar
Been a bit since anything has happened. Had ben modify the QSRC spacers for ackermann adjustment. Made a hell of a difference.
Got tired of the tarmacs and it was time for new tires anyway. Sooooo
17x9 ET22 RPF1
245/40/17 Michelin Pilot Sport 4S
I can't put them on the car yet, waiting on adapters from motorsport tech. I'm also putting new pads and rotors on.
New wheels will drop 15 lbs per corner if you include the adapters.
Old 03-11-2018, 07:59 PM   #2944
MoCounselor
MoCounselor's Avatar
Oh Lordy!!! Favorite wheel of all time, definitely in for pics of this!!!
MoCounselor is offline   Reply With Quote
Old 03-12-2018, 11:39 AM   #2945
Stiggy Pop
Stiggy Pop's Avatar
that should be appreciable
Old 03-12-2018, 01:32 PM   #2946
SquareD
An Anomaly
SquareD's Avatar
I was expecting to see a lighter wheel choice this time around... and I'm a fan of rpf1s, but I'm kinda surprised by the lack of euro flavor. Should be a nice upgrade from the tarmacs.
Old 03-12-2018, 01:55 PM   #2947
The Full Banana
not yet good enough
The Full Banana's Avatar
I'm pretty excited for some anodized purple accents.
-Tom 1980 242 T5
Old 03-12-2018, 03:27 PM   #2948
Duder
His Dudeness, El Duderino
Duder's Avatar
Homer asked me not to say anything, but I've been working on turbine-powered whistle tips for this car. The T5 exhaust pulses make scavenging a real bear. There was almost insufficient energy to drive the Wisselator in off-peak transients but by developing an integrated MGU we have conquered this.
Old 03-12-2018, 05:00 PM   #2949
Pro Sneaker Peddler
Toes tingle at the thought.
Old 03-13-2018, 12:50 AM   #2950
Homer
OEMplus++
Homer's Avatar
Thought I'd mix it up a little. It was between the RPF1s and BBS RKs. The 17x8.5s weren't going to clear my brakes, made the decision easy. My ultimate wheel choice will remain in my back pocket/cad for a while.
Only Megan Racing's finest
I hope for an auspicious final product release.
