Old 05-09-2011, 05:41 AM   #501
Karl Buchka
Never go full retard.
Karl Buchka's Avatar
Originally Posted by Homer View Post
backwards
As a staunch proponent of the Forwards Turbo, I can't allow this to happen.
Fake Race Car
Old 05-09-2011, 10:32 AM   #502
Homer
OEMplus++
Homer's Avatar
Mine came with multiple springs and they all worked out to what they were claimed to be.
Bottom mount FTW.
Yeah it's not like its that hard to test.
-Jacob:
2006 A4 - Comfy DD
Old 05-15-2011, 04:15 PM   #503
Homer
OEMplus++
Homer's Avatar
Life has been in the way a bit recently.
Anyway, looked at the 2 year old starter i pulled off the 240 and the S70 one I had laying around. Noticed they are both 108 series bosch starters. Hmm the S70 one needed new brushes.
Well the 240 starter brush assembly is the same as the S70 one, as is the outer casing and the end cap. Freebie rebuild. Woot.
Old 05-18-2011, 09:41 AM   #504
The Aspirator
It's a girl!
The Aspirator's Avatar
You know I just had my S70 starter apart to replace that braided cable that goes from case to solenoid, and I was wondering how similar it was to a 240 starter. Good to know!
'83 242
'95 T5R
'98 S70
The Aspirator is offline   Reply With Quote
Old 05-18-2011, 09:42 AM   #505
Homer
OEMplus++
Homer's Avatar
That braided cable is a tad shorter, but bend the tab on the end and it fits fine.
Old 05-23-2011, 11:43 AM   #506
Homer
OEMplus++
Homer's Avatar
Sweetish box arrived.
Old 05-23-2011, 11:57 AM   #507
Turbosteen
I was born at a young age
Turbosteen's Avatar
Hornbach started selling those?
If so, I'm going to grab a few tonight...
Looking good!
Philip
Project '82 760 16vT | Amazon | B204GT | Feedback |
Husqvarna Nuda 900
Turbosteen is offline   Reply With Quote
Old 05-23-2011, 09:15 PM   #508
Homer
OEMplus++
Homer's Avatar
Engine out, oil pan on, trans on and back in.
The ribs on the pickup tube bump need a little trimming, otherwise the 2x4 plus chain whip clearance seems to be good with me :D
Depending on weather, i'll get the trans crossmember modified tues or wed.
Old 05-23-2011, 09:17 PM   #509
adrianpike
adrianpike's Avatar
i approve of this.
I'm looking to buy, PM me if you've got any of it: LS bits, 93 850 bumper, ford 8.8", T5 WC, T56, Mustang IRS
Adrian is omniscient, you will never escape his wrath. - 500dollar744ti
doug was here
adrianpike is offline   Reply With Quote
Old 05-23-2011, 09:32 PM   #510
Karl Buchka
I never approved of this.
Old 05-23-2011, 10:34 PM   #511
Homer
OEMplus++
Homer's Avatar
Originally Posted by Karl Buchka View Post
I never didn't approved of this.
Old 05-24-2011, 12:58 AM   #512
The Aspirator
It's a girl!
Wow that's quite an arc in the swaybar! No problem with the power steering rack being there? I seem to remember Karl complaining something about that, maybe it was that the oil filter doesn't clear?
Old 05-24-2011, 03:57 AM   #513
VQ
Not such a PRVert Anymore
VQ's Avatar
Just a V6 sway bar?
hellastock
Speed Bumps? No Problem.
264 GLE RIP
88 740T wagon
1964 122s
88 760GLE
Old 05-24-2011, 04:11 AM   #514
Mr.Borrie
The Sneaky F*ing Russian
Mr.Borrie's Avatar
Originally Posted by VQ View Post
Just a V6 sway bar?
only one that clears the whiteblock irrc
Old 05-24-2011, 09:16 AM   #515
Captain Bondo
Exklusiv Zubehör Klub
Captain Bondo's Avatar
Just a V6 sway bar?
I think he means the swaybar itself looks kinda bent in the middle section. Probably doesn't hurt anything, but yeah, quite the bow to it.
-Kenny
Old 05-24-2011, 09:18 AM   #516
Homer
OEMplus++
Homer's Avatar
Yeah I think it got a little damaged at some point, no worries. Still works.
You can see the ribs in the oil pickup bump that would create issues with the PS rack. I just need to grind those down a bit.
I've got a right angle filter adapter off a 960 so there won't be any clearance issues.
Just a V6 sway bar?
Yah
Mhm
Old 05-24-2011, 10:05 AM   #517
kildea
kildea's Avatar
Just a V6 sway bar?
It's one of those IPD V6 bars
kildea is offline   Reply With Quote
Old 05-31-2011, 11:05 PM   #518
Homer
OEMplus++
Homer's Avatar
Engine mount mockup. So these are yanked from a swede that did a 6cyl swap. They'll need some redesigning for my application but are good for hardpoints. They will be bolt in though. Only another hole through the x-member is needed. (as well as an insert spanning the x-member)
Trans x-member is 90% done. I need to lengthen the holes without the rubber isolators. I moved the x-member up 2 sets of holes in the frame rails.
0--x--x---0---*---*
0--x--x---0---*---*
x is new location, * is stock m47 location. (Left being the front of the car) Notice the spacing is slightly different. About a bolt width closer.
And with a large torqueing of the engine(almost an inch in engine mount compression/extension) the trans doesn't contact the tunnel.
Old 06-02-2011, 04:41 PM   #519
Sir Psycho
holstrich 2.0
Sir Psycho's Avatar
That's awesome, nice work!
Isaac
1995 940 Turbo:
531 head, Holset HE351 @ 20 psi, Emusa External Wastegate w/screamer, Mild Steel Header, 4" Downpipe, Ostrich Emulator, IPD Turbo Cam, TTR Cam Gear, Big Piping and Intercooler, 3" Exhaust, V8 T5 soon, Synapse Synchronic BOV, AEM Wideband, 18" Pegasus, B&G Springs, Billy HD's, Chassis Bracing, Sumimoto HTR ZIII 225/40/18
Sir Psycho is offline   Reply With Quote
Old 06-02-2011, 07:16 PM   #520
Homer
OEMplus++
Homer's Avatar
Well that works dandy.
Old 06-02-2011, 07:17 PM   #521
Karl Buchka
Good call on the bubble wrap. Should cut down on gear noise.
Old 06-02-2011, 07:21 PM   #522
Homer
OEMplus++
Homer's Avatar
Next step I think is filling the trans tunnel with great stuff.
Old 06-03-2011, 08:04 AM   #523
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
i'd recommend "bauschaum" ;)
Old 06-09-2011, 01:29 PM   #524
Homer
OEMplus++
Homer's Avatar
So this 740 M47 driveshaft might be the exact right goddamn length.
Possibly switching the output flange on the M90 to the 3 bolt guibo flange dealy. Anyone want to trade ?
Old 06-09-2011, 05:56 PM   #525
Captain Bondo
You're going to actually voluntarily change from a u-joint to a guibo?
Does that make sense?
