As far as I'm aware, only the RS500 had the "big" (i.e. .63 A/R) cossie exhaust housing. I think both 2wd and 4x4 cossies has the smaller housing...but I could be wrong. It's still a kick-ass turbo, either way. I thought maybe you were going for something larger...I wouldn't worry so much about the cossie. It's a great turbo, though. I'm almost certainly going to end up running one myself.
Keep the boost down and you should be fine. Or monitor AFR with a wideband. Just don't crank it up without knowing what's going on. We also gained quite a bit of extra power when we ditched Motronic. Also, before, boost was stable at 10psi. With MS...mad boost creep. More exhaust gas energy...more timing, I presume.
I'm not trying to be an a-hole or take the piss if that's how I'm coming across...I just really don't want to see you blow your **** up, as I know how much that sucks. I was laughing at the image of the smile on your face during the first drive.
When Damo had Ozzy's "2.0 kit" (SSAC header, Cossie T3, A-cam, exhaust, chips, 18psi, etc) fitted, he went straight away from 155bhp to 250+. I think he had fun on that first drive! Maybe you'll not be so impressed, I don't know, but I think you'll find it's a really nice upgrade.
cheers
James
