sloopy
2-digit whp
- May 25, 2020
- North Texas
hello. ive ordered coilovers from ben and im trying to decide which spring rates i want to go with. i want to do some ride frequency calculations to help me choose a spring which will give the car sporty handling while remaining reasonably comfortable for the street.
i found this formula for ride frequency:
f = sqrt(k / m) / 2pi
where k is wheel rate in newtons per meter and m is mass in kilograms
to do this, i need the motion ratios of the front and rear axles and i need the weight over each axle. i know the rear motion ratio is 1.5 * spring rate. for the front, ive heard it is about 0.9 * spring rate. that would mean the steering axis is leaning at a considering im using ben's offset strut mounts which add 3 degrees of caster, this should increase that motion ratio slightly as will any positive adjustment of the camber. im also using ben's quick steer roll correctors, but since im lowering the car the recommended 1.5-2", this should have practically no impact on the motion ratio i believe.
as for the weight over each axle, i wasnt able to find much info besides hearing weight figures from 2900 lbs to 3100 lbs and a supposed 55/45 front to rear split. this might mean about 1650 lbs for the front axle, or 825 lbs for a front wheel, and 1350 lbs for the rear axle, or 675 lbs for a rear wheel.
given the factory front springs from lesjofors are 87.4 lbs/in and a motion ratio of 0.9, that would be a 78.66 lb/in wheel rate. using the ride frequency formula (and converting the units), that comes out to an estimated 0.97 hz front ride frequency. if we do the same for the rear given a 121lb/in spring rate, the wheel rate would be 181.5 and the ride frequency 1.62 hz. the numbers seem a bit weird to me.
as for a target ride frequency, i found this chart which shows:
an e46 m3 coupe has a ride frequency of 1.27 and 1.53 front to rear
an e46 m3 convertible has a ride frequency of 1.77 and 1.75 front to rear
https://www.fatcatmotorsports.com/FCM_Ride_Harmony_BMW_E46_M3_Online/FCM_Ride_Harmony_BMW_E46_M3_Online.htm
for the 240, a front spring rate of 150 lbs/in should produce a ride frequency of 1.27 hz assuming the 0.9 motion ratio and 825 lb corner weight. a front spring rate of 175 lbs/in would produce a ride frequency of 1.37 hz. and a front spring rate of 200 lbs/in would produce a ride frequency of 1.46 hz.
has anyone measured the front motion ratios for their modified cars? and does anyone have alternative weights i might use? i have a 1992 240 wagon naturally aspirated, ive replaced the battery with a 5 lb lithium, and ive replaced the really heavy factory exhaust header with a very light tubular one. also, is there really such a huge difference in ride frequency between an e46 m3 coupe and convertible? are they trying to compensate for the more flexible chassis in the convertible and they wanted to maintain the same performance as the coupe?
