Old 03-11-2015, 02:51 PM   #126
Pro Sneaker Peddler
Originally Posted by gsellstr View Post
IAC hoses good? Saw you plugged them on the first part. I split one of those a few months ago, car was way gutless, and that split only showed up around 12-15psi. WG sounds about right.
Fuel pressure good under heavy throttle/boost?
the way I've done mine (and some folks will try to seal it up and let it sit over night, that's a bit excessive imo) is plug the exhaust to catch any potential cylinder blow through, put a cap on the compressor inlet and air the whole thing up to like 25psi or so and listen for leaks. you will hear some escaping into the breather system, but if you're looking for leaks I've found that soapy water in a spray bottle goes a long way to identifying leaks. the first time I did it on my 940 I discovered that:
1) idle air hose split on the backside down at the bottom, and only opened up in boost
2) the blow off valve was leaking around the seal (vband was loose and it needed some rtv encouragement)
3) the charcoal canister lines were shot
the idle air hose I would have eventually figured out, but the other two would have probably persisted
I too had a split idle air hose. It's easy enough to spot it when the car idles well enough but the boost performance (and very rich mixture) suffers significantly and gets progressively worse.
Old 03-11-2015, 03:03 PM   #127
Duder
His Dudeness, El Duderino
Duder's Avatar
Originally Posted by qwkswede View Post
I did not pressurize the turbocharger itself. And I'm a bit suspicious of that. I did a better job sealing and tightening the clamp at the compressor housing outlet when I replaced that connection. And there might have been some gain there. It does seem to be running slightly better. But I still hear a hissing while driving under boost that I can't hear while pressure testing, or revving idling. Maybe I'll work on plugs and pressure for that section tonight.
MAYBE A LEAK
I tugged at the wastegate rod, and there is some preload on the gate. I remember putting about 1/2 of the hole diameter preload on it when I was working there. It seems the same still.
Careful with pressurizing the turbo's compressor side - there will always be some leakage past the internal piston ring seal (behind the compressor wheel). Unless you have a carbon-faced seal turbo but that's unlikely since they are normally only needed when used with a draw-through carb setup.
Still, might be valuable to pressurize the compressor housing to check for leaks at the backplate which should be easy to fix by tightening the clamp bolts. Or replacing the o-ring there, if this turbo has one.
To check wastegate preload, if you have a mityvac or other regulated air pressure source with a gauge, pump the wastegate actuator up to your peak boost pressure. Put a dial indicator on the end of the actuator rod right where it connects to the crank, lined up parallel to the actuator rod. You should see ~1mm (0.040") of actuator movement at your desired boost pressure. Just a rule of thumb but works well on most old-school internally wastegated setups.
If you see more than 1mm of movement, you should adjust the rodend inwards to increase preload on the actuator.
Old 03-11-2015, 03:37 PM   #128
RoadRacer4Life
Owner: DeathWagon
RoadRacer4Life's Avatar
I think its cam timing. Verify that your crank pulley has not slipped. Then re-verify that your cam timing is right. Just my two cents
-sam
90 245GL Build thread 2JZ coming soon...
91 245GL Dumpin Doughnuts Battle Wagon Chumpcar
93 245GL Street Beater
Old 03-11-2015, 03:39 PM   #129
qwkswede
faster than you think
I never did run this car with an open downpipe. It has always had a cat and muffler in the exhaust.
The IAC hoses seemed OK at 10 psi when I had the entire intake system pressurized. Though I'm running slightly higher boost in real life. Seeing about 11-12 psi on the data logs. So maybe I'll give that another go tonight with higher pressure and a tailpipe plug and pressurizing at the compressor inlet. That should get the entire system full of air. I have never had to be quite so meticulous about small leaks, its not usually that critical.
But if I have my hands in there, I may as well replace hoses and clamps until it is sealed up tight.
-Ken
1967 Volvo 122S
1992 Volvo 745 driver
Old 03-11-2015, 03:43 PM   #130
qwkswede
I am still suspicious of this too. I'll get to it this weekend, just one thing at a time.
Though with LH2.4 running the engine, the idle IGNITION timing was about 10-12 degrees. And thats triggered from the rear of the crankshft. So if it has slipped, it is only a tiny bit. Ignition timing was at least in the ballpark.
Should I just knock the crank pulley and balancer loose to get a look at the timing belt cog pulley and the crank shaft key?
-sam
Old 03-11-2015, 04:06 PM   #131
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
^yeah may not be a bad idea, and it's easy enough to do.
Megasquirt Tuning!
Old 03-11-2015, 04:07 PM   #132
RoadRacer4Life
Owner: DeathWagon
I would pull the spark plugs and stick a long skinny screwdriver in the #1 spark plug hole. Gently turn the crank by hand till you get the screw driver all the way to the top. Rock it back and fourth till you find the middle and it should be obvious then check your mark on the crankshaft
-Sam
Old 03-11-2015, 04:34 PM   #133
gsellstr
gsellstr's Avatar
^^^ and check the mark on the crank gear as well, make sure it hasn't slipped on the crank, if the nub snapped off.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 03-12-2015, 12:14 AM   #134
Volvorules
Has a Built Trans!
Volvorules's Avatar
Don't forget that the outer section of the crank pulley can spin on the inner if the rubber damper part is worn out. This can cause wrong readings off of the crank pulley.
Rob
Volvoless
how psi a stock can support?
Originally Posted by MrBill View Post
not even thieves like 7/9 series.
Volvorules is offline   Reply With Quote
Old 03-12-2015, 11:39 AM   #135
qwkswede
I'm not finding much wrong, but eliminating things is good I suppose.
I ran a more thorough pressure test last night with the tail pipe plugged, and applying pressure into the compressor inlet. I did find some small leaks around the IAC hoses. I tightened the clamps up and those stopped. The turbo was nicely sealed everywhere. I'm not sure how much those tiny leaks affect performance at 11-12psi that I'm running, but the car does feel a bit better. It might be placebo though.
On to the camshaft timing. I tried to locate TDC on the crankshaft as close as possible by touching the #1 piston through the spark plug hole. It seems my error to feel that is about + or - 1 crank degree. That seems close enough for this exercise. And with that accuracy the camshaft timing mark is lined up on the cover nub. Its close, definitely not off by a whole tooth, or even 5 degrees. The camshaft roll pin was in good shape too. I checked that when I did the cam swap. So that seems to be set up as advertised.
One other thing that came to mind is valve lash. When I installed the cam, I checked the lifter clearances and they were all at the tighter end of the recommended range. Could my lash be too tight and bleeding cylinder pressure? I'm stretching here and nothing was way out of range. But maybe just some valve seat wear allowing the valves to settle deeper into the pockets. I might have my friends the local Volvo shop go through the valve lash. They have the collection of shims needed to make small adjustments.
I will post up some datalogs I recorded last night too. You can clearly see the slow boost ramp up. So I'm starting to think I might start looking for things there again. Maybe this is just a big lazy Garrett on an automatic car with a tight converter.
Old 03-12-2015, 12:02 PM   #136
qwkswede
Full boost at 3600 rpm. . .
This is a 2nd gear pull where boost has a time to build. If I open the throttle in 1st gear, I don't hit full boost until I'm into 2nd gear. Does this seem weak to anyone else?
Old 03-12-2015, 12:52 PM   #137
Pro Sneaker Peddler
Is that with a .48 turbine housing?
Old 03-12-2015, 12:58 PM   #138
qwkswede
I haven't been able to confirm that. Did these turbos ever come on Volvos with a .63? I assume it is a .48.
Anyone know their Volvo turbos from this angle?
Old 03-12-2015, 01:17 PM   #139
gsellstr
gsellstr's Avatar
There was a larger hotside on some of the 7's. Even so, I'm rocking a .63 on my 2871r and it's damn quick to spool.
Something definitely doesn't seem right.
How does it respond to the wastegate line being unhooked and rolling into it?
Valve clearances can have a little affect on things. How's the vacuum at idle? Stable?
Old 03-12-2015, 01:40 PM   #140
Duder
Duder's Avatar
Apples and oranges...an old journal bearing T3 and a ball bearing GT28R are two totally different animals. Wheel dimensions and aero design are totally different. Bearing system is completely and fundamentally different. Turbine housing gas passage design is unrelated.
Think of A/R as a ratio (because it is one ). Area over radius. It's a measure of a housing's "nozzleness" - the smaller the value, the more nozzling action it performs - and a smaller nozzle will increase gas velocity, all else being equal.
You can have two turbines with identical A/R ratios but if the turbine wheels are different dimensionally or in aero design, or if the turbine housing cross sectional area at the beginning of the volute (scroll) is not equal, then you can't necessarily draw any correlation in performance. Without talking about two housings in the same family on the same turbine wheel it's pretty much futile to compare A/R.
Old 03-12-2015, 01:44 PM   #141
Pro Sneaker Peddler
Just by eyeballing it looks like a .48. I'll take a pic of my .63 for you to compare while I'm at lunch. Definitely slow-spooling. My engine sees max boost at that RPM but that's with less compression, a smaller engine, and a bigger turbine housing on an inferior EMS. You are way up in the thin air though.
Can you do a leakdown test? Maybe your rings are fried
Old 03-12-2015, 01:59 PM   #142
LloydDobler
LloydDobler's Avatar
Any chance of a clogged intercooler? Can you measure charge air temp and is it nice and low?
Just trying to think of things nobody's mentioned yet.
'66 122 - Collectible project
Old 03-12-2015, 02:08 PM   #143
linuxman51
linuxman51's Avatar
are you using a boost controller? maybe use more preload and less mbc.
Old 03-12-2015, 02:37 PM   #144
gsellstr
gsellstr's Avatar
I know they are way different Chris...glad they are as well. Even my brothers 242t with a custom t3 from turbo power with a 60-trim has full boost pretty quick though,
Old 03-12-2015, 02:39 PM   #145
RoadRacer4Life
Owner: DeathWagon
Very weak.. I've had 50 trim turbos with stage 3 turbine wheels in .63 housing make 16+ before second gear. Maybe the turbo has some damage? Jacked up turbin wheel? something binding in the wastegate linkage or a cracked turbine housing holding the wastegate open?
-Sam
Old 03-12-2015, 03:19 PM   #146
qwkswede
I will do some more looking at turbo related stuff next. Maybe more preload on the WG rod is in order. I am using a G valve boost controller. The turbo makes about 6-8 psi without.
It has been a while since I sold my old 740 sedan DD. But it had a t3/t04e 60 trim. I remember it building boost way faster too. I actually have a china made "50 trim" on the shelf I thought about using. It needs bearings now, but it spooled faster too. I originally was thinking it would be too much for an automatic car with low stall speed. But if this turbo is knackered, maybe I'll give it a try.
- Intake air temperature isn't shown here but I can pull it out of the datalogs. I haven't looked at it during boost much yet. The GM open element sensors are not typically very fast to respond. So a 3 second long pull isn't really enough to get an accurate temp measurement. They drift up and down as the intercooler heat soaks and cools, but its not really an instant measurement of the air coming into the intake. They lag behind the temp changes quite a bit. I used to think you could tune using that as an input and adjust timing with hotter high boost charge temps, but when you start looking at the sensor output in the datalogs, you realize it just isn't responding fast enough.
I have driven these cars enough to know that it should lay some rubber when the boost hits in 1st gear. And it doesn't do that .
Thanks for the ideas gents. Its good to have the community to bounce ideas off of.
Old 03-12-2015, 04:42 PM   #147
Pro Sneaker Peddler
So this is what a .63 looks like. It does seem like you have the .48...
Old 03-16-2015, 02:45 AM   #148
qwkswede
I fixed the VR sensor input on my new Microsquirt unit this weekend. Now the engine will rev past 4800 and I can start to concentrate on the tune and lack of performance again.
I also installed the summer wheels. Which probably means we will have a blizzard in the next week. I got some pictures of the car with the new coilover stance and Eikers. I do think the front needs to be lowered 1/2" more.
Old 03-16-2015, 08:36 AM   #149
linuxman51
linuxman51's Avatar
I wouldn't say your old 740 spools fast, but it seemed to make 15psi in first gear without any issues. I'm going to break your hand next time I see you though, motor mount bolts are not supposed to be TTY.
Old 03-16-2015, 09:28 AM   #150
qwkswede
I'm sure I used a torque wrench on those, with the most precise calibration too. Now I'm going to have to come down there to defend myself. There must be more to this story that I should probably hear in person.
I never got to experience that car at sea level, and that turbo was a bit lazy. But I have to say this current tiny T3 vanilla is worse at the moment.
