Old 03-24-2012, 03:15 AM   #226
Matts87-244
Matts87-244's Avatar
looking to +tee. need all parts, labor, and tools for free. you bring beer and bud. if you can help i'll give you lots of gum.....it's stride so it's def worth it....
should be asleep, instead i'm being a smartass for no reason.
1995 855 5 speed glt 360k, replaced engine 160k http://forums.turbobricks.com/showth...90#post4719490
1987 244 w/ aw-70 90k orig. http://forums.turbobricks.com/showthread.php?t=254816
1989 244 w/ m47 265k crushed
Feedback:
http://forums.turbobricks.com/showthread.php?t=251592
Matts87-244 is offline   Reply With Quote
Old 04-04-2012, 01:58 AM   #227
242GT-R
242GT-R's Avatar
Horray! serious question tho, how much boost, right now im at 6psi turbo ecu inter cooler and exhaust.
79 242-GT+Hx35 and NX on LH2.2
04 S60R 314 Awhp
81 244 DD 2.1+2.3=Blueblock
242GT-R is offline   Reply With Quote
Old 04-10-2012, 01:29 PM   #228
Thecorker
Hi, I'm new to this site. Looking for anyone who took the 2.4i and added a turbo to it. Just starting the project, so any input is helpful at this point.
Thecorker is offline   Reply With Quote
Old 04-30-2012, 11:17 PM   #229
redlinegw
redlinegw's Avatar
I have a clean low mileage 85 245 and would really like to do a turbo swap or add a turbo to the original engine. I can get a very good running 90 740 turbo sedan with 200k on it for $900 maybe cheaper. I really want to make it look stock under the hood so is it better/easier to do a swap or just get the correct parts from the junk yard and add a turbo to the stock engine. The engine in the wagon runs great it is just a turd. I am very mechanical and have built a few Mopar muscle cars from the ground up, so I am not a total noobie.
redlinegw is offline   Reply With Quote
Old 04-30-2012, 11:35 PM   #230
redlinegw
redlinegw's Avatar
Or should I just sell the 245 and get a 740/940 or 850 turbo wagon?
Old 04-30-2012, 11:44 PM   #231
Buy a stacked 93+ 940 T parts car, and find a 240D airbox in the JY or in wanted / for sale.
Old 09-02-2012, 06:20 PM   #232
IRMB
IRMB's Avatar
hey, is there somewhere that shows what I would need to poach from a 940?
There's quite a few of these at pick n pull...
yes, I tried searching - but no go.
IRMB is offline   Reply With Quote
Old 10-22-2012, 04:10 AM   #233
Volvo240BLUE
"turbos run 3.0 bar fuel pressure. NA cars run 2.5bar. you want the 3bar if it is in good shape. 2 bolts and an oring is all that holds it in."
In response to this.... does this mean I could replace my FPR with say.... one from IPD for a 90's turbo car, which would be a brand new part? What exactly is 2.5 vs 3bar.... just the cut-off point? Can I add that to get ahead of the game before I replace injectors and pumps just to get something simple done?
Volvo240BLUE is offline   Reply With Quote
Old 02-27-2013, 09:59 PM   #234
swedish-rocket
Is there a difference in the fpr in the stock na volvo 240 1990 and 1991 turbo 740?
swedish-rocket is offline   Reply With Quote
Old 02-27-2013, 10:10 PM   #235
Lord_Athlon
Just damn
No
84 242 turbo msII
My build https://forums.tbforums.com/showthread.php?t=8675309
Old 03-28-2013, 12:37 AM   #236
Hoggster
Hoggster's Avatar
Here is my successful +T build thread. I added a turbo to a '87 240 with LH 2.2. It cost me $640 including the car but I was able so scrounge up a lot of parts from cars I've parted out.
Hoggster is offline   Reply With Quote
Old 04-12-2013, 10:19 PM   #237
calvintibia001
Bench-Race Fanatic
calvintibia001's Avatar
I hate to bump up a old post, but i am planning to do a +T, I have a B230F in a 1994 Volvo 940 (Built at Sep 1993) and a B230FT out of a Volvo 740, I wonder if I have the thicker Crank and thicker Rods on my B230F, is there anyway to tell except pulling the whole engine out and look inside, I have a 531 head does it help identifying the block ? Thanks Guys
calvintibia001 is offline   Reply With Quote
Old 07-25-2013, 08:07 AM   #238
volvo740b234/531
volvo740b234/531's Avatar
Bump somebody should update a lot of old dead links.
1989 740 gle:
Roller/ project
2008 dodge nitro r/t:
Daily
1976 wheelhouse c-101:
Predator 412+t project/build
volvo740b234/531 is offline   Reply With Quote
Old 07-26-2013, 03:03 PM   #239
volvowagoon
Unslammed. Cry about it.
volvowagoon's Avatar
http://forums.turbobricks.com/showpo...7&postcount=37
This one has been helping me a lot. It's old, so lot of links and pics are missing. However it still has a ton of info and goes into deep specifics I haven't seen here.
Old 12-01-2013, 05:13 AM   #240
jaygracie2
Default 1988 Volvo 760 turbo
Please Help!
I just purchased a 1988 Volvo 760 turbo with 227k miles. I want to upgrade the turbo, but I don't know much about cars. Engine size? Current stock turbo? Can I tweak it? What is the biggest, cheapest, fastest and easiest way to make this thing a horsepower freak show? Please help, all suggestions are welcome. Thanks, Jay.
jaygracie2 is offline   Reply With Quote
Old 12-01-2013, 07:02 AM   #241
centason
Knipex=welfare queen
centason's Avatar
Have you done all the maintenance to bring the engine up to normal operation? Compression test? Horsepower freak show would require forged internals, and quite a few other parts. 250 to 300 is easily attainable on a budget once maintenance is done. 90+ manifold, bigger injectors, bigger Volvo turbo (15g or 16t), and a chipped ecu. That will net close to 300, but again maintenance first above all else. The gremlins tend to rear their heads if not tended to.
Member: TBCCS
"The kind of man who wants the government to adopt and enforce his ideas is always the kind of man whose ideas are idiotic." -H. L. Mencken
Old 12-19-2013, 06:15 PM   #242
NikoHK
Hey guys I'm new to this forum and I'm really wanting to do work on my 98 volvo s70 I wanna start by putting in a turbo with new performance fuel injectors and even an upgraded fuel pump. I need help like bad! Hahah I have no clue where to start! Everything on my s70 is stock!
NikoHK is offline   Reply With Quote
Old 12-19-2013, 06:57 PM   #243
Mueller
Mueller's Avatar
Classifieds>sell your car>buy a S70 T5
You need to read more and do more research....
Why "performance injectors"? The stock turbo injectors work fine....
Why an upgraded fuel pump? Have you run the part numbers to see if an n/a and a turbo run the same pump?
Old 01-22-2014, 10:21 PM   #244
dkrause
Hi, What is the horse power expected when you install "+t" on a NA B230F using all stock turbo parts and ecu from a 91 740 Turbo Intercooled which is factory rated at 168 HP?
Thanks
dkrause is offline   Reply With Quote
Old 02-03-2014, 01:21 PM   #245
740nut
Guest
Thanks
I would think that is all depending on if you have done a 'Stage 0' on the project car. It's fair to assume that some may think when you do the conversion you could be putting out close to that 168hp, but your car may but putting out much less than stock due to its age. I think whilst everyone has different opinions and methods to go about doing a +T, we can all agree on the fact that each project is different and can result in a wide range of results. Best to probably first give us a run down on what you have currently done to your project car to give the guys a better idea of where you stand with possible power outcomes.
Even better, if you start a new thread dedicated to your own project (with pictures if you have them are always welcome) you will find the people here are very helpful and friendly and the replies will be more direct. All the best and keep us up to date about your project
Old 03-14-2014, 04:58 PM   #246
nordmaschine
forced instruction
nordmaschine's Avatar
My question sounds like something that's been chewed over and over so I wouldn't open a new thread, but instead ask here, since I really couldn't find it via search.
If it hasn't been answered yet, perhaps it could be split into a new thread...
Anyway, here it goes...
I'd turbocharge an '89 B234F. Is it a good idea? I'd go with 16v block because of, IMHO, better oil pump and less rattle with timing belt.
But, doesn't the '89 have 9mm con-rods and no squirters. Or?
If not, I'd put 13mm rods and squirters.
But, how much power/boost would stock pistons hold?
What about lowering compression? Greenbooks say pistons are only 0.2mm lower than B204FT units, so I guess that's not where they got it there... Is it combustion chamber? Can it be milled? Or should I find a B204FT head?
What about cams? Are NA cams good for anything, if adjusted for less overlap?
Thanks.....
Jetronic is romantic.
Whiteblocks
Old 07-23-2014, 09:21 PM   #247
skunkman
Default Write up
Originally Posted by kyle242gt View Post
That was a good write up. Thanks!
skunkman is offline   Reply With Quote
Old 10-05-2014, 05:51 AM   #248
slovo240
slovo240's Avatar
I really like that you matched your valve cover to your wd can
the areo dynamics of a brick .. i get it ,hahaha
1980 Volvo 244 b230ft k-jet
1989 Volvo 740 turbo just the body. hmm body lift?
old beat up short bed truck. good frame.
slovo240 is offline   Reply With Quote
Old 10-16-2015, 05:07 AM   #249
Edit-crap. Realized this was a year old question, but it got answered!
Thanks.....
I have assembled about 4 or 5 B234F+T's. They all ran very well on LH2.4. The powerband was very high so it was mostly for screaming down the freeway. I was just a little slower than STI's and EVO's, but faster than say Mustangs. at the 8th mile drag strip I went just about the same speed as 8v stuff I have built, but that being said, it was just a greentop injector B234F+T at 10 psi. I don't like breaking my stuff, so I set realistic goals and I achieve them.
16vt 2010 album link:
http://s796.photobucket.com/user/ZVO...?sort=3&page=1
Old 02-01-2016, 03:03 PM   #250
noahhas240fever
I have a question, I'm looking to buy a 240 , swap a 740 turbo engine, now for when it comes to tuning, I'm planning on swapping the turbo and cooling system , what would I need to get in addition so I could bring it to a tuner and get a proper tune, do I need a piggy back system for my ecu with new sensors?
noahhas240fever is offline   Reply With Quote
