Help me find my leak ... don't want to start another thread for it
1990 740 b230ft
The leak is from the rear of the engine, at idle 2-3 drops of oil every minute, quite a lot. After rubbing all the oil from the bottom of the car the first couple drops of oil come from these bolts on the bellhousing support piece. As you can see, it's not the lowest bolt which leads me to believe it's not the rms. These are the bolts on the oil filter side. After a few minutes, the oil begins dropping from the lowest bolt on the bellhousing, but not right away.
Background: During a recent transmission swap, I replaced the rear main with an OEM Volvo seal. I thoroughly cleaned the seal housing prior to installing the new seal. I covered the new seal in oil before pressing it in. I pushed it in no further than 6mm which is within spec according to Hanes. I didn't put it on the grooves from the previous seal and I pushed it in as evenly as I could according to my eye. On the next sunny day, I will remove the bellhousing bracket to take a look and see if it's dry or not.
Next, I replaced the distributor with a good used one with very little play and installed it with two new seals. After running the car for a little while the back of the distributor seems dry.
The two oil filter lines looked very wet, so I replaced the washers on the lines, which also didn't solve the leak.
During a recent cam swap, I removed the harmonic balancer to take a look at the front main seal. I know when they leak they can run oil to the back of the engine making it confusing. I'm going to replace this seal in a few days but I don't think it's leaking this badly.
The oil filter housing seal would be more obvious if it was leaking badly right? I'm thinking it's either this or my oil pan. Any advice would be great on where to go next. Thanks
