apollo's 940
- Jun 12, 2006
240 1991 stock
car wont start due to the safety thingy majingy sensor on the transmission lever., even when in park or neutral
I replaced it with a spare. same thing, no start even when on neutral or park.
not even a click
anything else I should check underneath that area?
what is the most common problem if this is the suspected problem ? I know the issue is in this area because it was running fine. after usual parking, it wont start. I wiggled that area then it started . this has happened more than once already.
any advice?
thanks in advance,
andrew
not even a click
any advice?
thanks in advance,
andrew
