Old 04-22-2013, 08:21 PM   #351
jamesinc
WD-40 Enthusiast
jamesinc's Avatar
Originally Posted by volvobrage View Post
Hahaha I live in a narrow valley, and the "lake" is a "fjord"
Or actually, Im only there in the weekends..My mother and father lives there but I moved to get a decent job..
Love the place, the nature is INCREDIBLE!
Isn't Norway the country that does a lot of logging, but plants so many new trees that the amount of forest is actually increasing?
1985 240GL, 1989 740 Turbo wagon, 1992 240, 1977 244DL, 1980 244GL, 1996 850R wagon, 1985 360GLT
Founder of the Australian Volvo fourms, http://ozvolvo.org
jamesinc is offline   Reply With Quote
Old 04-26-2013, 03:49 PM   #352
volvobrage
Not quite sure, but it sure looks like its true!
26.04.13
Pics from last sunday..Got the last reinforcement out from the rear fender
Much easier to protect from rust now
Made a thread pipe for the windowcleaner tank drainplug
volvobrage is offline   Reply With Quote
Old 05-07-2013, 02:17 AM   #353
volvobrage
Got a new stearingwheel!Havent recived it yet, but a friend of me have it at his placeTraded it for some welding
Old 05-07-2013, 02:20 AM   #354
volvobrage
Mounted the waterpipe to make the last bracket for it..Looks like there will be smale space for exhaust manifold
WeldedWelded the underside after dismounting again
Dynamo/servobracket was splitted
MountedWill use a electric powerstearing pump, thats why I did like this
The stick is mounted with new gasket
Mounted this again, someone know what this is?
Old 05-07-2013, 02:36 AM   #355
volvobrage
Been looking at this, need to get them bolted togheter
Must take out the bolt and make a new longer that fits through the thermostat and connect with the filter
Made a connection for the watercleaner tank
Made "brakets" for attaching the pump with M6 threads
Cutted out this plates on the plasma..Will be wattlink rotor when its finished
Spotted them togheter and grinded them
Marked and drilled
Seen some people have problems with space on the oilpan, so I cutted the crosssupport
Spotted
Turned the ends for a nice transaction
These plates I dont need anymoore
Grinded away the weldings and removed them
Got the first piece spotted on
And the secondNow it only needs full welding and blasting before I mount the new reinforcmentplate
Old 05-07-2013, 02:59 AM   #356
2fast242gt
Do you have a cobalt?
thats how i did my cross member too with the v8, i cut reliefs like that and pushed the middle in with a vise and welded it back up. nice work as always!
1983 242dl
*6.0 lq4 swaped* Build thread
Old 05-07-2013, 03:26 AM   #357
volvobrage
So you had spacetrouble there also?I dont think the oilpan is touching on my car, but better safe than sorry!And if I some day want to put a 2jz or something in there it can be nice with some extra space
05.05.13
Did some more work on the wattlink..Will weld it to the shaft before I make the hole inside
Made spacers to keep the right distance
Also welded the last pipe to my friends 960 with turboWill be really cool with so little hoses!Welded a pipe for dumpvalve on the pipe I welded last time also..Will try to get a picture of the engine bay later
Old 05-07-2013, 03:33 AM   #358
volvobrage
A friend at work helped me make the hole in the wattlinkShould be H7 inside so I dont have the skills to make that..Big guy, 119 kilos and size 49 shoes
Welded the first rotor, will make one for a friend also
Got it in the lathe and made the end straight
He drilled with 24mm drill, finish hole should be 28
Finish insideCould be maximum 20 hundreds over 28 with the H7 measurment, this was 7 hundreds over
Didnt manage to cut it of in the lathe after I welded the rotor, so we cut it with grinder and put it to the fres after
Finish straightend out
Totaly finished after removing some sharp edges..The other one is ready for inside hole
Old 05-07-2013, 04:15 AM   #359
Funkee
Funkee's Avatar
Nice work man
Old 05-07-2013, 07:34 AM   #360
volvobrage
Originally Posted by Funkee View Post
Nice work man
Thanks!
But the work in the lathe was not so nice, should be +21 thousands and not hundreds:p So 7 hundreds is way to much..
I will make a new one first and then make the inside hole on both one evening
Old 05-07-2013, 09:48 AM   #361
Funkee
Funkee's Avatar
Same here, love to work on the lathe but sometimes you just fck sht up when you're almost done.. part of the game
How is the mount on the axle gonna look like ?
Old 05-10-2013, 04:47 PM   #362
volvobrage
Its very nice to work with the lathe indeed, but sometimes **** happens Buts that some of the reasons its so fun, you can always improve your skills
The mount on the axel Im not quite sure on yet, but I might have a planHard for me to explain in english so you will see!
10.05.13
Finish welding the front bar, only grinding left
Welded the old engine mount holes also
And bought this from a friend, from 960 automat
Old 05-10-2013, 11:51 PM   #363
Homer
OEMplus++
Homer's Avatar
That'd be the cam position sensor. (Thing you asked about on the back of the head)
-Jacob:
2006 A4 - Comfy DD
Old 05-11-2013, 04:51 AM   #364
volvobrage
Thanks Homer!
Old 05-13-2013, 09:17 AM   #365
volvobrage
Welded this for fluid out
Welded the mounts for the pump..****ed up and got som melting inside the treads:(So welded the hole and drilled new with new treads..As you can see its not in the middle..
Tested the pump
Grinded to mounts I cutted on the plasma some days ago
In the car
Roughfly cutted two pipes..Was really unsure if I should go for one pipe(looks cleaner I think) or two pipes(looks much stronger)
But now I have decided for two
Old 05-13-2013, 09:18 AM   #366
volvobrage
Took of the intake manifold again, will test the engine and try to spot togheter the new intake manifold so I can weld it
Spotted togheter the fillingpipe with correct length
Should be tilted little bit to the back of the car and the tank will go 20mm down
Old 05-13-2013, 07:38 PM   #367
Ex850R
Ex850R's Avatar
Default Washer pump
Looking great ! The battery is going in the other side in the back?
This is a little late for you and your washer tank to change to an 850 rear wash pump but my 245 pump just failed and i have an 850 one sitting around and am sorting out fittings to use it instead as it was the rear washer pump it has the guts to push lots of water.
Great build!:cheers
Ex850R is offline   Reply With Quote
Old 05-13-2013, 09:09 PM   #368
Jerd
Jerd's Avatar
did you end up using these? http://i300.photobucket.com/albums/n...t/DSC05969.jpg
If not, why?
Your build is ****ing awesome.
Old 05-14-2013, 02:53 AM   #369
volvobrage
Great build!:cheers
YepWill be a homemade batteri mount, have a cool idea for itWill see how it turns out!Will make the same "frame" as that one for the battery to stay on so I will make one more identical, but for the other side
To bad I didnt know that before:(But thanks for letting me know, if there will be a problem with too little power I will rebuild with a 850 pumo
If not, why?
No I didnt..I didnt like the look of it too much..I was thinking about doing a group a style reinforcement, but I decided to make it easyWhant to build some badass ones with adjusteble pipe and spring so I can make it lower without changing the spring pressureIf that was understandable
And thanks alot!!Really cool that you think so!
Old 05-20-2013, 02:15 AM   #370
Hemily
Inspiring read, makes me want to work on my car... too bad i'm a completely incompetent mechanic :P
Min 240 rusta isondt, så an leve et par månedar, før an blir spiker... sko hadd dine sveisekunskaper, hadde eg sloppe å hiva bilen :P
motorplanen e 5 sylindra me turbo? onna 220hk då?
Hemily is offline   Reply With Quote
Old 05-22-2013, 05:28 AM   #371
volvobrage
Hehe, rust er nåke dritt!
Blir 2,0l 5 sylindra turbo ja, 180hkSå blir det litt meir gamp etter godkjenning;)
17.05.13
Took the car out to spot the mounts for the windowcleaner tank
One in place
And the second
Welded the fillerpipe
Fully welded the mount
Made one brakett to weld on the tank
And the water pipe have gotten some temporary paint
Old 05-22-2013, 05:28 AM   #372
volvobrage
Drilled holes
And spotted
Old 06-03-2013, 08:41 AM   #373
volvobrage
Welded the filling pipe on the tank
The lid is just placed on top of the pipe, but you can see about how it will turn out
Spotted the mount in the other end
Found three rubberthings I will use under the tank to keep noice away
Got a new intercooler, 600x350x102 cells..Also oilcooler, its 25 cells
For the gear mount I will make when I get the gearbox
Old 06-03-2013, 08:46 AM   #374
volvobrage
Tested the plates for strutbar a friend of me madeFits perfect!
Got my stearing wheel the other day..Its in really good condition!
Grinded the "frontbar", needs some small detailing with the sandpaper machine still
Adjusted the new plate and welded it on
Think it will be much better space for the oilpan now
The plate ended up like thisDidnt like the end where I had to cut after the modifying on the frontbar, but its good enough to stay under the car
Old 06-05-2013, 06:17 AM   #375
volvobrage
Bought this from a Nissan Micra K10
The 240 brakepump fits right onOnly need to shorten the pin so I can get it all the way in
Welded the orginal holes
Marked and drilled new ones
Tested!Think I will save some space with this
Need to make 4 spacers in the lathe since the bolts doesnt have threads all the way in
