Old 06-18-2012, 03:59 AM   #51
volvobrage
Originally Posted by M.H. Yount View Post
That piece 'with no name' -- I think we'd call it a rocker panel extension.
Okay, thank you!:D Nice to learn some new english words about the car
Originally Posted by 550 View Post
Lookin awesome!! Keep it up
Originally Posted by Mueller View Post
Very impressive...looking forward to seeing how this turns out!
Originally Posted by 2fast242gt View Post
nice clean job on the widening!
Thanks guysI will post some more pictures today, but i need a new side because my computer is almost chrasing with all the pictures
volvobrage is offline   Reply With Quote
Old 06-18-2012, 04:10 AM   #52
volvobrage
And here was the new page
30.12.2011
The car is up in the rotation device again
After I saw a 242 on the norwegian volvo forum who had alot of rust under the side window I got scared and pulled mine out. It looked very good!But maybe to you guys in USA this is quite normal:p
Here I had done a mistake so i cutted the end and made the right angel on it
Here I was going to make i plate that fitted over and weld it all..
But I decided to do different..Cutted away a bit more and grinded
Putted some welding spray everywhere the plate was going to cover eachother and made a new peace
Made the peace for the rear fender
And put in on the car and cutted out for it..ALso cutted out a little more for the sparewheels house..But Ican not put in the new parts before I have the new peace that should go under the talelight
So I started on the other side..At first it was like this
And then it was like this
Old 06-18-2012, 04:56 AM   #53
volvobrage
Tryed to take a better picture of finish wheelhousing(exept grinding)
Then I continued on the other side making it ready for work..straitened this edge out
Took the reinforcement away
Took away the old **** from inside the rear fender
Started putting in the sparewheel house..Finally it starts to look like a car again on this side
Here it will be fittedf well togheter, I have a plan
Here you can see roughfly how much I need to widen this
Old 06-18-2012, 05:01 AM   #54
volvobrage
Finished the torque rods!Took a reducer and grinded it so it fitted against the ring..It looked so much stronger and nicer then!
Old 06-18-2012, 05:41 AM   #55
Cojones
Cojones's Avatar
You don't screw around sir. Nice job!
S90 Executive
Cojones is offline   Reply With Quote
Old 06-18-2012, 10:59 AM   #56
volvobrage
No I dontHaha
08.01.2012
Started with this + one nut more
After some work with the grinder and lathe
The extra welding is because of a little misunderstanding:p
And finishThe treads are not normal but inches and not 2,5 but 1,5 in the "niceness" of the threads
Old 06-18-2012, 11:17 AM   #57
volvobrage
Started on the peace under the taillight!Cutted it out from a partcar and removed the "plateonplate" part and welded it togheter..
Support so the fender wouldnt go in when i cutted out the old peace
The old ****..Dismembered it when I got it out and there was alot of rust under!
And in with the newAlso rebuild the edge under since it was ****ed!
Spotted this on place
Spotted on the rest of the pieces and widened the sparewheel house!
The new parts are from a company called Veng, not known for its nice fittings
And this is how it looked like when I went home
Did like this here..The small peace should have been togheter with the big peace, but how could I now where it all would end up..But I think it looks okey, espesally after welding and grindigYou will see
Old 06-20-2012, 02:38 AM   #58
volvobrage
Picked up one rim from a set I consider to buy..Boltpattern is 5x120 so I need spacers to put it on..This is a rear rim, its 18x10 the front is 18x8,5ASA 3 piece rims!
255 rear tire, I want to have 265!
Old 06-20-2012, 02:42 AM   #59
volvobrage
Finished the rear fender!
And the problem with the "rocker panel extension"
Finished the sparewheel house
Some temporary paint..The white spots are the shape of the inner fenderRoom for some fat rims!
Tested the rims!
Bur with no spacer I had to put on these nice rims again
Old 06-20-2012, 02:44 AM   #60
volvobrage
Made reinforcement plates for the front suspensionThe parts will be sandblasted and primed before I weld in the reinforcement!
Old 06-20-2012, 02:50 AM   #61
volvobrage
I want to put these on the 5 sylinder I'm going to put in the car!
Will cut of the first and make a new place for the tps sensor..
Got a polish guy at work to do this for me, I'm not so steady on tolerances in the lathe..The new is in black steel and not stainless since I'll be making a black steel header eventually
Some pictures of the car when I took it back to the workshop!
Out with the front window and some more parts
Will be blasted here
Rear window and some more parts there
Under the rear window it looked good!
Started on the "plates" inside the car..**** work!
Almost finish with the car, but I need to make the last finsih here
Planning to make a new one in aluminium, will make the connections in the lathe some day I have time
Old 06-23-2012, 07:13 AM   #62
volvobrage
Pulled out the headliner..Will be new skin with black color there!
Took out more **** inside
Finished the mats and took out some parts that were left for the heater
Cutted away the batteri box..Not sure if i will change the rusted peace or just sandblast it yet
Some parts for the exhaust, 3,5" bends and a reducer that is going on the turbo..There its 3" so in need a peace from 3" - 3,5" from the reducer there
Old 06-23-2012, 07:16 AM   #63
volvobrage
Got the parts form blasting and priming!
Started on the last reinforcement in the rear
And a new coat of primer..Another type of primer the painter recomanded me..Used for ships!The grey was zinkprimer..
Took these of the car and cleaned them and grinded them
Put some more primer on them to
Old 06-23-2012, 07:19 AM   #64
volvobrage
Polyrethan busnings!
Masked the bushnings and painted with the blue top color
The picture that shows the color best
Put them in my warm bedroom so the paint would dry..Woke up with a headake the next day
Old 06-23-2012, 07:21 AM   #65
volvobrage
Got a front rims home to test also
Not so wide edge in the front but I think thats cool on 240's..
Good space with 8,5" wide brock rim
Up
Front
And marked up for the new headlights, going to cut it out soon
Old 06-23-2012, 07:24 AM   #66
volvobrage
Cutted out for new taillights!
Finished the big mat in the trunk
Here I made a mistake when I removed the reinforcement so i need a new plate here..
Took it from an extra front fender I had
Removed the plate on the torpedowall
And the brake"thing"
Old 06-26-2012, 03:07 AM   #67
volvobrage
Both these to, they will go for sandblasting next time I send something..
The plate on the way out!
And its out
Looks good but here I need to blast or maybe weld in new peace..
Glad I took it out, because here it needs blasting and some welding..
Welding
Old 06-26-2012, 03:09 AM   #68
volvobrage
Started a little bit on the doors..
And finished the trunkJust wait a little bit before I take the glue so it will go easier
This looked like ****..So I tought it was because of the widening:(But I took it of, oiled it and bender a little bit so now its flush again
Old 06-26-2012, 03:11 AM   #69
volvobrage
Cutted this on the cnc plasma at workIt will go from the crossmember in the front to the rear bushning for front "arms" to support..Not my design, a guy on volvoforum was so kind to give me the drawings
Old 06-26-2012, 03:13 AM   #70
volvobrage
Prepared for blasting
Cutted out the old rusty peace and started on the new one!Put some welding paint under the plate against the crossmember and let i dry the rest of the day..
Started on removing the antenna!
And finished this..I am not satisfied with what I did here, it looks bad..So I will fix it, but dont now how yet
Old 06-26-2012, 03:21 AM   #71
volvobrage
Finish welding..Looks okey, but the finish will be under the carThere I will grind the weldings all down, thats why I keep it on the inside..Anyway, will be a carpet there
Wide and goodReally excited to see how it turns out with the rims on!!
Old 06-26-2012, 07:34 AM   #72
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
really cool bodywork
Old 06-27-2012, 12:03 AM   #73
Kinked_Chrome
Awesome work. This thread literally makes me want to cut apart everything I own.
Kinked_Chrome is offline   Reply With Quote
Old 06-27-2012, 12:33 AM   #74
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
Norwegian volvo build thread checklist:
complete teardown, widening, seam welding of a volvo 240
modification for wide wheels and some extreme engine choices
check!
Old 06-27-2012, 03:28 AM   #75
Funkee
Funkee's Avatar
dont use a course sanding disk for getting the paint off! it takes off too much good material, just use paint stripper of 60 grit sandpaper and do it by hand or eccentric sander
