Old 10-03-2012, 05:26 AM   #201
volvobrage
Rear panels in good condition!
Did some cuttting with the plasmaAny guess on what it is?
volvobrage is offline   Reply With Quote
Old 10-03-2012, 08:29 AM   #202
2fast242gt
Do you have a cobalt?
Front crossmember bottom skid plate?
1983 242dl
*6.0 lq4 swaped* Build thread
Old 10-03-2012, 11:56 AM   #203
volvobrage
Fantastic!Nobody in the norwegian forum made the correct guess:p
Old 10-03-2012, 09:15 PM   #204
2fast242gt
First guess *cough... I'm a genius.*
Old 10-05-2012, 07:16 AM   #205
volvobrage
Yes you are!
04.10.2012
Doorpanels..The passanger side is very good, the driver side is little bit "loose"..Will see what I do
Bad "wood"
Finished the throttlebody after work..Made a square and welded it on
Finish
Original it was like this
Old 10-08-2012, 01:26 PM   #206
2fast242gt
nice! so why exactly are you replacing the skid plate? is yours bent up like most are?
Old 10-08-2012, 02:10 PM   #207
volvobrage
Exactly..And because the new one is much cooler!:p The old one also have giant holes to reach the engine mounts, I dont need that anymoore..But need to make some holes to reach the stearing bolts tough
Edit: I also want to put an aluminium plate under the engine so tought it would be a good idea to make a little bit thicker plate so it will be strong!
Old 10-10-2012, 07:06 AM   #208
volvobrage
Before
And after:p
08.10.12
Cutted parts for the intake
Drilled and made threads
Ready for weldingHomer style!
09.10.12
Welded more on my friend intake manifold yesterdaySome welds was nice and some not so nice..Would help if I trained more on other things inbetween my welding assignmenst:p
Crack here after bending the pipe so cutted and welded
Spotted this togheter
[/QUOTE]
Old 10-10-2012, 07:09 AM   #209
towz-T
EL hipo explosive
towz-T's Avatar
nice work
'00 V70 2.5TDI <= stored until i sell it
'04 V70 2.4TDI <= exploded in norway
'10 V70 2.0TDI <= DD
'89 745 B204GT <= project moneypit
my introduction thread that i am desperately trying to keep alive
cuz on turbobricks, posting about something and not doing it counts as quitting a project halfway through. Quitting a project halfway through counts as finishing it.
Yay you finished it!
towz-T is offline   Reply With Quote
Old 10-15-2012, 04:47 AM   #210
volvobrage
Picked up some parts!
Only temporary ic and radiator;)
Wheelarch, want to redo mine..
From B230ET
Bushnings for the wattlink
Need to trim the parts I made littlebit:p
Diameter was okey
Old 10-15-2012, 12:14 PM   #211
2fast242gt
where the intake cracked did you drill out the end? also crater fill the end of the weld thats really important on aluminum, i think i see a small crater maybe im just seeing things but it will prevent further cracking.
Old 10-18-2012, 09:15 AM   #212
volvobrage
I didnt drill out the end, but grinden 10mm longer then the crack..Should be the same deal??
Crater filling was a good tipI wasnt aware that it is so imporant on aluminium..Never tought about it before since my weldings always goes all the way around..Thanks for the tips!!
Old 10-18-2012, 06:30 PM   #213
Hodginsa
Always
Hodginsa's Avatar
How much to make me an intake like that? haha
http://idlehandsproject.com - Keep me busy.
Hodginsa is offline   Reply With Quote
Old 10-18-2012, 11:52 PM   #214
BoostIt
BoostIt's Avatar
me too haha
'83 244tic - Ipd bars, Ipd adj. panhard, Noltec v1 camber plates, front coilovers with 300# springs and Koni Yellows, rear cut wagon springs and Koni Yellows
'65 122 S - B20 bored .010 over, D cam, E head, M41 J-type, IPD poly all around, Bilstein HD's, tons of other goodies...
'91 245SE - Sold
'82 244tic - Sold
Originally Posted by Stephen View Post
At full compression, there's enough room for a credit card to slide in.
BoostIt is offline   Reply With Quote
Old 10-18-2012, 11:57 PM   #215
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
I would like to see the finished product there.
Old 10-19-2012, 01:55 AM   #216
volvobrage
Originally Posted by BoostIt View Post
me too haha
I'm not quite sure since Im only welding it..Its my friend that makes the parts..But Im guessing around 800 dollars for the parts
18.10.2012
Here are some more pics of the intake
Spotted together
Plate for flange during welding
Welded the throttle flange
And welded..just missing the fuelrail attachment and speedvaier(?) attachmentI also made engine mounts and plates for the front end to a friend of mine..
Old 10-19-2012, 11:43 AM   #217
DNAsEqUeNcE
†John3:16
looks good. I like the billet flange too. don't forget to flatten the throttle body flange.
Old 10-20-2012, 05:39 AM   #218
Arn02
Arn02's Avatar
Are these a lower chassis brace? If so, do you have some dimensions of it? I'd like to fabricate one as well because stiffer than GT lower chassis brace.
Ambitious but rubbish.
The 245 GT
The Euromurican
Arn02 is offline   Reply With Quote
Old 10-23-2012, 07:52 AM   #219
volvobrage
If its nessesary it will not be my jobIm only welding!The billet flange is really niceSave alot of work and welding with it also!
Yes it isI have the drawing somewhere, can post it in this thread later this week when I find it!
22.10.12
Welder injectorpipes on a E engine intake this weekend..No finish pic
And finished the other intake..Plate for "speedvaier"
And plates for the fuelrailMounted togheter, looks awesome!
Last pic before it went in the mailbox on the way till its new owner
Old 10-23-2012, 05:00 PM   #220
Arn02
Arn02's Avatar
Please do!
I wish I could tig. What made you decide to go for those long intake runners? Looks good.
Old 11-15-2012, 05:40 AM   #221
volvobrage
Long time since update here..The deer hunting season have taken alot of my time lately!But I manadge to do something with the old Volvo
23.10.12
Spotted
And welded
Working execellent!
Testing
Pipe for the thing that makes the motor run without throttle
Old 11-15-2012, 05:41 AM   #222
volvobrage
Last peace for the throttle wheel
Welded
Mounted
Old 11-15-2012, 05:43 AM   #223
volvobrage
Finished an E intake for a guy on vccn
Pressed the pipe in a hose press to get it from 18mm inside to 14mm
Finish
Drilled hole and welded
For the vaierholder
Finish
Fixing a intake for a guy at vccn also
Old 11-15-2012, 05:44 AM   #224
volvobrage
Made a piece for vacum
Drilled and made 1/8npt threads
Pulled the engine out on the floor again
Mounted
Didnt fit, but got a new one from a friend
Started looking on the water pipe..Will be something like this!
Old 11-15-2012, 05:45 AM   #225
volvobrage
Oh luck, same threads as the old one
