Coupid
- Sep 24, 2003
- Santa Barbara, CA
This is fantastic news! way to stick with it. I had been checking for updates and I'm thrilled to see it heading towards a resolution.
Update:
We may very well have found the culprit of all of the non-starting/running rough issues:
That's a resistor on the circuit board of the ecu and it's obviously bad. We traced this down after discovering that if we grounded pin 17 on the ecu harness with the harness unplugged from the ecu, the car would fire up and run, (albeit running REALLY rich.) But, the moment you we plugged the harness back into the ecu, the car would go back to cranking, but not starting.
Ordered a 5-pack of resistors from digipack in the same value today. Thankfully, I have an electronics friend who can desolder the old resistor and solder in the new one. Should have the parts here and have it replaced by next Saturday. Fingers crossed that this fixes the no start issue, and we can move on to timing, tuning, etc.
Also, I spent some time after my friend Gray, whom I have now deemed "The Car Wizard," left on body wiring. I got all lights working except the turn signals/hazards, and the passenger headlight. As someone evidently cut the passenger wiring and some point and "fixed it" via wire nuts. *shakes head*
Pic of the car semi-lit up just to prove it's working, and because it makes me happy to see it getting closer to being road worthy...
