LC4CARL
Aero challenged
- Sep 8, 2008
- Vancouver, WA
Status:
Windshield washers. Put a wire in the nozzles, but nary a dribble with the old pumps. Installed the IPD pumps and things improved only slightly. Drilled out the nozzles with my smallest bit (yeah, I know) and the stream only goes 6-12". SwiftJustice to set me up with a clean used set.
Strut mounts. Saved up a bit for those sweet basic mounts from Ben only to realize that, with the good bearings and drilling them for my big springs, they were out of reach. Harold set me up with a clean used set of OE mounts and I just ordered the 15A plates OldSchool recommended.
Trans output seal. Ran down to the Volvo dealer today. All the microfiche (?) showed was a complete gasket set for $75. HiperFauto came to my rescue with a part number that IPD has for cheap. So I bought a fancy shift boot from him. Love that guy.
Driver's seat back cushion. On going.
Rear lower control arm bushings. Planned to grab OE bushings at the dealer today but they were too much. Will grab some from IPD. May swap the poly torque rod bushings for rubber at some point. They're a little noisy in the wagon. Other that a small leak at the rack pressure line banjo and an alignment, my steering and suspension should be approaching perfection. LOL.
Put in as set of diesel motor mounts because, well, I'm not sure actually. Even grabbed the little "bell" from my B21FT for the oil filter side. I know what I have.
Can't recall the last time I drove this thing.
