Old 05-15-2018, 03:08 PM   #1
jvluntzel
Default 850 ATE calipers on 740
Hi all!
Does anyone know if this is doable? The 740 parts are getting harder to find and having a newer option would be nice.
I just want to know if the 850 ATE calipers will bolt onto a 740?
850 caliper (part # 19-1702/3/8/9):
740 caliper )part # 19-1108/9/12/13):
jvluntzel is offline   Reply With Quote
Old 05-15-2018, 07:09 PM   #2
lummert
lummert's Avatar
It appears to me that the bolt holes are not the same distance apart.
Old 05-15-2018, 09:15 PM   #3
300+hp on the shelf club
Sure are a lot of calipers available on Rockauto.
Old 05-15-2018, 09:56 PM   #4
The junkyards, Eeuro, FCP scrotum, IPD, all the usual suspects have them I don't see a problem.
Old 05-16-2018, 02:04 PM   #5
jvluntzel
Its just a picture. No reference on how far away it was taken. If anyone was actual dimensions that would be great
Thats all fine and dandy but having options is a good thing? right?
Old 05-17-2018, 01:31 AM   #6
Kjets On a Plane
Devoid of Luxury
Kjets On a Plane's Avatar
How PSI a stock can support?
Always Be Crushing!
Old 05-17-2018, 01:46 AM   #7
You seen one crappy sliding caliper you seen them all.
Old 05-17-2018, 05:29 AM   #8
Janspeed
why not convert to a 940 'big' brake setup?
Old 05-17-2018, 11:07 AM   #9
eabras
Up front the 850 calipers fit with longer bolts and a small spacer. Easy way to get bigger 305mm brakes
eabras is offline   Reply With Quote
Old 05-17-2018, 12:22 PM   #10
jvluntzel
I dont think anyone is understanding the point. Its simple. Do they bolt up or nah?
Old 05-17-2018, 02:37 PM   #11
tryingbe
Boosting along.
tryingbe's Avatar
Do they share the same part number? If so, yes. If not, no.
85 GLH 367whp
00 Insight mpg > yours.
Old 05-17-2018, 02:41 PM   #12
Those are not sliding, 2 piston fixed caliper.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 05-17-2018, 04:23 PM   #13
niquemarshall
They should fit. I just gave my buddy my 940 caliper off the rear for him to install onto his S70 since both mounted just fine.
niquemarshall is offline   Reply With Quote
Old 05-17-2018, 04:31 PM   #14
jvluntzel
part #s dont dictate bolt pattern...
Yeah i was just gonna let that SLIDE on by...but you got it
hell yeah thats good info
Old 05-25-2018, 01:55 PM   #15
mark244turbo
mark244turbo's Avatar
I have installed 850 front callipers and 305 mm rotors on my old 1986 740 turbo. You will need 850 brake calliper brackets, a spacer plate and longer bolts in the front.
1994 960 B204FT, full options, leather interior.
1991 745 B204GT (Swede Sixteen VT) M90 conversion.
1986 745 B230FT, 302mm V70 brakes, camber mod. (sold)
1983 244 turbo B21FT/AW71 - leather /airconditioning
1987 244 GLT - Polaris, Strutbar, viking motorsport lower chassis brace, k-cam, gaz strut/shocks, pu-bushings
mark244turbo is offline   Reply With Quote
Old 05-25-2018, 04:36 PM   #16
Lankku
Lankku's Avatar
850/x70I FWD rear calipers are a direct fit for a 740/940.
444 -55, 145 Express -71,
242 DL -80 (was 4.6l)sold, 245 -88 "B6284T" sold, 245 -90 "B6284T", 945 Classic, 965 -93 B6304T
Old 05-26-2018, 04:53 PM   #17
DET17
Reformed SAABaholic
There is a quite detailed thread in this section, explaining the 850 caliper (same piston diameter as the 9 series) and the 302/305 rotor conversion for the 7/9. Not quite a 4 pot Wilwood upgrade with big rotors.... but an upgrade none the less. You do need a custom abutment bracket to make this work..... mine came from Skandix.DE
If the OP just wants to repair, certainly there are parts in the supply chain.
Old 06-04-2018, 10:44 AM   #18
jvluntzel
Im all for upgrades over just repairs too (the while im in there rabbithole)
PERFECT! thanks!
