Reworking the A/C in my '87 745T. I've replaced everything I was readily able to find replacement parts for, but was unable to find a high pressure pipe from condenser to the evaporator. This is the hard-line with female O-Ring ports on each end. Of course after vacuuming down and putting a charge on the system, I found a leak on that hard line.
I ordered one from Swedishautoparts.com, but later got an email saying it's back ordered 4-6 weeks. I can't find one anywhere else that looks like the one in the car, used or new. Thinking through my options I'm considering buying some Aeroquip A/C hose and fittings, but I'm not sure what size those fittings are.
Does anyone know the dimensions of these fittings and what they are called? Are they just Female O-ring fittings? What size are they? I just need to make the assembly from the condenser to the evaporator, so just those two fitting sizes.
