Old 01-03-2019, 07:36 PM   #26
Tfrasca
Tfrasca's Avatar
Originally Posted by Dangerkitty View Post
What size tire you running?
Are you using adaptors to fit them?
205/50r16 on those wheels. No adapters, I had them redrilled to 108. I also have a set of 15x7 with 5.25 backspacing, and I am running 225/50 on those with no rubbing. But, like Ken said, my rear axle is in a different spot than yours.
Old 01-03-2019, 07:39 PM   #27
Dangerkitty
Bored Member
Dangerkitty's Avatar
That's the size tire I'd like to run on the 15's
Any chance I could try bolting those 15 x 7s on my car and see if they fit?
I'm more visual, than mathematical...
just a bunch of bicycles and a 71 145 GT project
+ a 1982 Dodge Xplorer 221
Dangerkitty is offline   Reply With Quote
Old 01-03-2019, 07:51 PM   #28
Tfrasca
Tfrasca's Avatar
Definitely. They're brand new Corsa Steelies I had custom made, and they have essentially new Toyo Proxes r888r. I bought them with the intent on autocrossing the car a bit, but I doubt that'll happen now that other life stuff has come up. I'd happily sell them, but I'm sure you don't want r compound tires to drive around on the street...
Old 01-03-2019, 08:00 PM   #29
Dangerkitty
Bored Member
Ha! LOL. I just talked with Arman and he was telling me about your wheels, but he said they were 5.0 backspacing???
I'd be interested. Are they black???.
I'll pm you my phone #
Thanks!
Old 01-16-2019, 06:32 PM   #30
TESLA X Unique Series 83 Black Wheels 83-7714
Old 01-16-2019, 06:44 PM   #31
Dangerkitty
Bored Member
Nice, but I think 5.5 is a tad too much backspacing.
The Corsa wheels I bought from Tyler are 5.25 backspacking (15 x 7) and they fit fine.
I would actually like them to be out a tad closer to the wheel openings actually - which would require rolling the openings, but would get them more flush.
If I can find a set of the shorter early trailing arms I won't have to do any modifications to run them with the 225/50/15 tires.
Even with the 71 trailing arms they are not rubbing, but are a bit too close for comfort around the rear of the wheel openings, so I may end up trimming a small amount out of the way if I can't find a set of the early trailing arms.
Old 01-16-2019, 07:00 PM   #32
Dangerkitty
Bored Member
https://www.jegs.com/i/Cragar/260/83-7714/10002/-1
This looks like a similar wheel (fewer holes) for a bit less cost ($6/wheel less)?
Old 01-16-2019, 07:15 PM   #33
Good offset for 140 on both of those choices yes.
[2mm off]
Old 01-17-2019, 11:45 AM   #34
jwernerny
jwernerny's Avatar
Buy the stock RWD 15x5.5" Volvo steel rims then have a 1.5" band added on the outside. Worked perfectly on my 145, 245, 744T, 964, 965. The set I had made (by a stock car wheel builder) now wears 225/50 R15 race rubber.
John Werner
* 1992 944T * 1988 764 GLE V6 * 2002 WRX Wagon (needs motor) * 2006 Honda Odyssey *
jwernerny is offline   Reply With Quote
Old 01-17-2019, 11:59 AM   #35
Now to find a 75 164 in the junkyard with 4 good wheels on it.
