morsing
- Jul 20, 2007
- Aylesbury, UK
Hi,
I have got IPD spring on my car and last time I had a wheel alignment done, the rear wheel weren't quite straight.
I've bought an adjustable panhard rod also because the bushings are gone on the orignal. In the instructions it says Volvo's design off-sets the body slightly, but the instructions then say to install it so it's centered... How can that be right? Were the original Volvo set-up not tracking correctly? Will it drive straight if the body is centered?
I've measured the current set-up and the wheels are exactly centered under the body, so assume this gives it the off-straight alignment?
Thanks
Thanks
