JerryJS8
der Junge
- Sep 12, 2004
- Normal Saxony
Heyo Brick Peeps!
Got an annoying problem that I can't figure out for the life of me... About 50% of the time when I'm out and about running errands I'll get into the car, drive off and notice a high idle around 1,000 rpms at the next red light. I'll turn off the car and start it back up to have a nice solid idle at 750 rpms for the rest of the drive. ECU and EZK only show 1-1-1
About the car - 1991 740 b230ft + 16v
984 ECU and Gold box EZK with Hituning chips
3" MAF
Delphi 42lbs injectors
do88 Intercooler and no leaks between the air filter and the tailpipe
Rebuild turbo
Rebuilt motor with new pistons, valves, etc. with ca 3,000 Miles on it
Spark plugs Bosch WR5DC+
Red Top battery about 5 years old
80A Alternator and charging system good with a solid ~14v at idle
Preventative maintenance:
All harness grounds renewed/new connectors
ECU and EZK pin voltages/signal/ohms checked between boxes and sensors/actuators (that includes voltages at the MAF and Idle control valve as well as the TPS open/close signal)
Firewall bulk connectors removed and wires soldered and heatshrinked
Relay/fuse panel removed and all crusty or suspicious wires/connectors replaced
Relays checked - all good
And the following things have been done:
NEW Bosch parts, not junkyard or refurbs
Coolant temp
Crank position
Idle control
O2
012 MAF
Fuel Filter
Fuel pressure regulator
110 Porsche CBV
Other goodies
New Deatschworks DW200 Fuel pump
All fuel lines replaced
All vaccum lines replaced
New oil seperator box
Fuel tank cap like new
As far as the weather is concerned, don't matter if rain or shine, cold or hot. When the motor is warm it's a 50/50 chance it'll idle high till restart then be fine for the rest of the trip. So help me out ya'll! What is going on here?
3" MAF
Rebuild turbo
Coolant temp
Crank position
Idle control
O2
012 MAF
Fuel Filter
110 Porsche CBV
Other goodies
