#1 |
![]() Hi, symptoms are as follows:
- Car is fine when cold, runs normally, albeit poor MPG - Car is fine after even 15 - 20 minutes after starting from cold however shortly after this there is a misfire that seems to disappear under hard acceleration. average mpg is down from about 23 normally to 13/14. It appears to be over fueling, replaced the plugs today and the old ones that are about a year old were badly fouled with sooty deposits. Does anyone have any ideas what the problem is? There are no codes to be read. Compression is also good- was tested 4 or 5 months ago for an unrelated issue. |
#2 |
Indicating?
![]() Do you have access to something that can read sensor values? Friend of mine had similar symptoms and his coolant temp sensor was reading in the negative numbers.
#3 | |
Broad Member
![]() Quote:
"symptomology" your car is exhibiting...can't hurt to have a looksee!
In a closed society where everybody’s guilty, the only crime is getting caught. In a world of thieves, the only final sin is stupidity. |
#4 |
Bored Member
1990 245DL M47 LH3.1 - 344,000 Miles 1989 244DL AW71 LH2.4 - Sold 1998 V70XC - Sold |
#5 |
![]() So coolant temperature sensor is likely to be the issue.. Not sure if relevant but in-car temperature gauge appears to act normally? + Seems to start up OK when warm
#6 |
Indicating?
![]() I'm not 100% on this so make sure you double check before you start shotgunning parts at the car. Some models actually had 2 sensors. One was for the gauge, and the other actually sent the signal to the ECM. I don't know if this applies to the 850 or not however.
#7 | |
Broad Member
![]() Quote:
processes the info for the fuel management at the same time... CHECK THE CONNECTOR carefully before you get $pendy.... |
#8 | |
![]() Quote:
Apperantly it's a feature so the gauge doesn't freak out the driver when the engine gets a bit hotter under heavy load. |
Thread Tools | |
Display Modes | |
