Old 12-15-2010, 05:20 AM   #51
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Originally Posted by Turbosteen View Post
Still wondering why the IC would be a problem for the TüV and all the rest like the turbo, adapter plate etc. not..?
Especially the blue silicon hoses don't really make it look OEM style
Its not the IC itself.. and i dont know what your IC has got for fabbing tolerances.. but my wont fit under any circumstances... i have to fab a new mounting for it.. and sawing off some frameparts and weld something together is a "no go" for german tüv... ;)
Whats about the header brace ? must have ? the tubular headers normally dont have one?
Old 01-03-2011, 08:26 AM   #52
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Brakebooster for fitting the intakeheader and generator finishing done
Old 02-07-2011, 07:55 AM   #53
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Few Updates:
Got the problem with oilcooler sandwichplate not fitting the genuine filter fixed... All you guys should use the Mahle OC606 Filter.. app: for Chrysler PT Cruiser 2.4GT(and more)
So no more need to use external oilfilter applications ;)
pics say more than words.. look..
I think ill give this a try :D
Found this one morning in my garage :D my almost father in law also uses my garage sometimes.. he broke that engine on german Autobahn, added a patch to the windshield "engine broken, please dont start" and left for vacation
oh.. and i finally DeWalted my T3 flange to fit my china hairdryer ;)
Old 04-07-2011, 04:39 AM   #54
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
finally brought the pics back online.. they moved to another server, had to edit the links...
no more progress to this project since the last post.. had to deal with some serious spine, back, neck problem causing some neural disturbances.. but finally it started to get better i can do more stuff than walking between home-couch -> bed -> working-chair -> home-couch.. arrrr real **** those problems..
if you do IT as job ! Take care of your spine and things attached to it.. not funneh !
Old 04-08-2011, 04:15 PM   #55
Nordic Boost
Nordic Boost's Avatar
Well done, but I think there is too much colour... looks like a rainbow...
When is the next Workingparty???
Nordic Boost is offline   Reply With Quote
Old 04-11-2011, 11:32 AM   #56
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
ill give you rainbow.. ...slut !! :P
None of my motorparts is purple.. if i look in my dictionary for gay, a pic of your motor explains me the word..
Old 04-26-2011, 05:05 AM   #57
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
some updates...
Everything is now bolted up with new inhex, Exhaustheader crackwelded and installed..
BOV premounted.. TIG-Welder missing..
What do you think about the BOV ?
Its like T3 genuine style now right ? Will it work as expected or is there a better option out there ?
Old 04-26-2011, 05:20 AM   #58
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Oh... !! on CarFriday ;) i installed my TTV-Flywheel + 850R clutch cause i couldnt wait anymore and my old clutch was slipping :D
This Combo is non + ultra for M90 owners.. if you kick the Pedal you directly hit the limiter and it feels much more like a Hondamotor now instead of a roughredblock
And i crushed a 12.9 bolt in my crankshaft.. u would not believe how deep my heart sank in my arse in that moment :D.. justbefore heartattack and flying tools through my garage i noticed i could unscrew it with my little finger pheeeww :D
Old 04-30-2011, 04:11 AM   #59
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
no one about the BOV layout? :(
Old 04-30-2011, 10:33 AM   #60
nathaninwa
The Beloved Oarnge Juice
nathaninwa's Avatar
BOV looks fine. I would wait till it was in the car and finish that up. You might be able to rotate the compressor and get a better route on the hotside piping.
962j 815/692@27psi
THIS IS FORSALE V
Old 05-23-2011, 02:49 AM   #61
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
To Squirt or not to squirt.. thats the MEGA here...
Hey guys
I have the chance to get a MS board out of a 740 which is dynotuned for 230hp 360Nm with 8v Head on e85.
It is a MS 1 PCB V2.2
http://img152.imageshack.us/gal.php?g=1006945.jpg
Should i get this? and what do i have to look after? i will go pure e85 so my 630ccm injectors will be way too small? going 750ish or 850ish? does a walbro 255lpump do the job or should i get 044 Bosch? also looking on e85.. dont know if walbro supports e85
its also pretuned for flatshift and launchcontrol.. but i dont know if i should use this...
Problem is:
i dont have a f* clue about MS.. Is MS1 v2.2 a good option? all i know is: single coil full sequential injecting is only possible with MS3 and thats the way i would want to go when doing AEMS ;)
Old 06-17-2011, 05:55 AM   #62
Does it run yet?
Fire it on LH2.4 first and then upgrade later if needed!
Old 06-17-2011, 08:06 AM   #63
towz-T
EL hipo explosive
towz-T's Avatar
really nice work.
Any idea on the price of all those parts together? or does thinking of it makes you sad?
'00 V70 2.5TDI <= stored until i sell it
'04 V70 2.4TDI <= exploded in norway
'10 V70 2.0TDI <= DD
'89 745 B204GT <= project moneypit
my introduction thread that i am desperately trying to keep alive
cuz on turbobricks, posting about something and not doing it counts as quitting a project halfway through. Quitting a project halfway through counts as finishing it.
Yay you finished it!
towz-T is offline   Reply With Quote
Old 06-17-2011, 08:07 AM   #64
towz-T
EL hipo explosive
towz-T's Avatar
really nice work.
Old 06-17-2011, 08:31 AM   #65
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Originally Posted by towz-T View Post
really nice work.
It makes me sad.. yes.. but only thinking about what this would cost when living in the united states ;)
Look @ your hand.. if you hadnt any accident while handling saws or something every of your fingertips stands for two big €-notes... But that contains everything.. from machineshop to parts to whatev0r
@ ZVOLV
thats exactly what happens now But with ignitionmap from a b204FT chipped in a 219er goldiebox and an e85 dedicated map for LH
Im just fixing this (b6304 with a bent one ;) )
with my father when its done hes got a "brand"new 965 3.0 and i get his old one so i can start to strip my 945 ;) Need a DD for work and stuff...
I bought that enginesmasher for around 1150$ cause it looked so grandpa tended.. new engine (around 500$ in parts - block, sealing) -> worth 5000$ again.. in germany..
/edit
BTW that rodscrew was laying there before.. pls dont ask me how it made it there on its own.. :D
The preoener said it made a "bump" noise and the the motor stopped working.. bump.. yeah.. 4sure....
would be more precise in this case :D
Old 06-17-2011, 05:54 PM   #66
klr142
Turbo, what?
klr142's Avatar
What car is this engine going into, anyway? Will there be clearance between the turbo and the inner fender?
Old 06-17-2011, 07:12 PM   #67
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
i hope so ;)
this one goes into a '93 945.. i measured before.. it will definately be tight as a.. yeah..
if i am right there will be an inch from coldside to struttower...
Old 07-06-2011, 12:01 PM   #68
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
It's turning !!! :D
indeed... per hand.. with my wrench.. but all belts aligned and everything doing fine :D
seems i made a lot of stuff not wrong
compression by handturning is good..
2 weeks to go.. then it will go inside my enginebay ;)
Old 09-21-2011, 03:18 AM   #69
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
OOooohh... so slow progress :(
Bought a new ATP-Style V-Band Wastegate in 3"
Also i bought a steel beltdrive from KL-Racing similar to the one Knox is selling think @ Vallokra Bilsportmeeting.. also bought a Aluminumunderdrivepulley.. so sry JW.. he made me a perfect price
Also got the better fitting 60mm IC from KL.. looks like genuine but without plastic.. great stuff
made no pics.. sry.. forgotten..
slow progress cause we havent finished the car from my father yet and also i moved from an city appartment into a house...
heres some progress on fathers car instead ;)
Old 10-24-2011, 03:12 AM   #70
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Again.. not much progress :( but finally i managed to install the oilpan and got the belts aligned for the KLRacing underdrive pulley.. you need to use 10x960mm belts both for generator and servopump.. fits perfectly.
Also i decided to switch back to 2,5" V-Band cause the 3" vband from KL got a fabbing quality from "unter aller sau!!! to ach du scheisse, dass passt ja nie" i.e. brakecleaner tears out between the sealingsurfaces... also theres one part next to a bolthole which has only 2,5mm of thickness.. it's cast... ... Hello Mr Crack.. as i see you brought your Madame Mrs ExhaustLeak with you? nice...
oh.. and a buddy of mine switched to wintertyres which made me do a pic cause of its volvoawesomeness :D
Old 10-24-2011, 03:38 AM   #71
80/20 speed parts club
Na wie lange, bis er ins Auto???
Old 10-24-2011, 04:31 AM   #72
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
frag lieber nicht.. der grüne 960 blockiert die Bühne schon viel zu lange
Bin total genervt von dem Ding...
Old 10-24-2011, 04:56 AM   #73
Johann
Johann's Avatar
Immer mit der Ruhe.
Johann is offline   Reply With Quote
Old 10-24-2011, 05:57 AM   #74
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
Originally Posted by Johann View Post
Immer mit der Ruhe.
Old 11-02-2011, 05:10 AM   #75
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
bought a new FPR.. i think its Aeromotive Knockoff ?
Product Piracy? For Sure :D
