Old 11-15-2017, 11:00 AM   #376
kodja
kodja's Avatar
Originally Posted by nitroboie View Post
Yes, however the earlier diagrams in this thread show the tach hooked to TAC.
Maybe people were having issues with it powering the tach and that's why the updated picture shows the relay method?
well thanks for posting my How to Wire it up guide
you wont need any relay when using the Mazda Ignitor module. so the edited picture further up is just wasted time if you are using the parts listed on the picture this have worked like a charm on my 242 8V but now i am going t use it along with COP instead of the 2x2 coil on my new 16V Turbo
so...
WHAT is the correct Coil on Plug i should buy to make it work with the Wasted Spark board on a 16V head? i have no patience for reading all pages to backread on that question and i need to get them soon thanks
98' 945 LT RF stereo, aprx. 2600watt RMS Dynamic bodykit, 18" rims, Black leather 965 interior, bilstein + ipd swaybars +++
82' 242 (Turboproject) C70 two-coloured leather and alcantara seats (electical adjusted), Harman/Kardon amps++
kodja is offline   Reply With Quote
Old 11-25-2017, 04:38 PM   #377
nitroboie
Just finished my install. Followed DET17s footsteps and went from a gold cold chipped ezk to stock blackbox.
I used a 203 powerstage, 407 coil, relay running the tach, and the BTI valve cover mounting bracket.
Btw, the spark board from cflo still appears to have the spark outputs reversed. No big deal, just make sure you do a test start/run before you make the final crimp/solder.
nitroboie is offline   Reply With Quote
Old 11-26-2017, 01:28 PM   #378
Duder
His Dudeness, El Duderino
Duder's Avatar
Yes, we've verified that this whole batch has the outputs reversed. So until further notice, please swap the 1-4 and 2-3 outputs when you do your wiring. It has to do with how the boards were programmed. Everything still functions as normal though.
Old 12-03-2017, 04:37 AM   #379
Flexter
Flexter's Avatar
Anyone ever tried running alfa romeo 155 coil? is there any problems with it
Flexter is offline   Reply With Quote
Old 12-05-2017, 09:16 PM   #380
nitroboie
After almost two weeks of running the new spark, I like it. The car definitely pulls hard in the upper rev range. A lot of people don't give the T cam enough credit, it'll pull to redline in 3rd. My car doesn't have much mods other than running 12psi on a 13c and the obx 2.5 catback. Can't judge any mpg differences as I've been too busy enjoying the new power vs. driving like I normally do.
This weekend I plan to finally have enough time to install the do88 intercooler and B or ipd cam to complement the new spark.
Old 01-04-2018, 12:12 PM   #381
Venlonaer
Venlonaer's Avatar
About the relay driving the tach. You just take the redwhite (1) and blue (15) wire that normally are connected to the ignition coil and connect these to the 85 and 86 connectors on a relay, after taking out the flapping mechanism ofc.
I saw this post from Karl and I thought the relay needed a resistor soldered in?
Originally Posted by Karl Buchka View Post
I just put this "tach driver" together for a local guy with a spark board. It's just a standard relay with the flapper and spring tossed out and a transistor/resistor stuck inside.
Or is it just that easy by connecting those 2 wires together?
Confusement
Interested to see what you have done.
Edit: already figured it out, easier than I thought lul
Venlonaer is offline   Reply With Quote
Old 01-06-2018, 09:58 AM   #382
nitroboie
My relay is still intact
Old 01-22-2018, 06:50 PM   #383
MrKrabs
MrKrabs's Avatar
Sorry in advance for what might be a stupid question, but can I test the 1+4 and 2+3 wires coming out of my EZK on my wasted spark install for voltage with a multimeter or test lamp?
I suspect I damaged the EZK mother board after going back in and re-soldering all the wires for the wasted spark board as one came undone from vibrations.
It's not a big deal, I can get my hands on a new EZK box easily; it's just to check that that actually is the cause of no spark.
Edit: Got it to work. My wasted spark board wasn't wired up correctly hehe.
MrKrabs is offline   Reply With Quote
Old 03-01-2018, 04:39 PM   #384
Sjeng
Hello,
I installed wasted spark last week on my 940. Works like a charm, many thanks for the development and clear instructions.
However, my tach is not yet working unfortunately.
I have a Mitsu J702T power stage with tacho output.
I connected the red/white wire which was originally on the 1 terminal of the coil to this tach output terminal (I assume this is the tach wire).
No tach unfortunately. Am I overlooking something?
Edit: Appears the wiring is correct. Tomorrow I will measure the output voltage at the "tach" terminal.
Old 04-12-2018, 03:46 PM   #385
bugjam1999
Hi all,
Just a couple of questions before I launch into this...
Do stock leads work with the Bosch 2x2 coil from the front page? Apologies if I’ve missed the answer...
Also- mounting the coil- I’ve seen plates added over the top of
The rocker cover on long nuts and I’ve seen coils bolted to the firewall... has anyone got anything good or bad to say about either? Might as well ask before making a plate or drilling holes...
Cheers
bugjam1999 is offline   Reply With Quote
Old 04-13-2018, 10:46 AM   #386
nitroboie
Stock leads work with the 2x2.
I have my coil and powerstage mounted above the valve cover. Works fine, but I'm not sure how the the heat from the valve cover will affect the life of them, mainly the powerstage.
Old 04-13-2018, 11:05 AM   #387
bugjam1999
Cool thanks, Iíll order that coil then...
Yes, that was my concern too- perhaps Iíll go with the same approach and keep a spare powerstage in the car.
Cheers
Old 04-13-2018, 09:53 PM   #388
Duder
Duder's Avatar
Originally Posted by bugjam1999 View Post
Hi all,
Do stock leads work with the Bosch 2x2 coil from the front page? Apologies if Iíve missed the answer...
Also- mounting the coil- Iíve seen plates added over the top of
The rocker cover on long nuts and Iíve seen coils bolted to the firewall... has anyone got anything good or bad to say about either? Might as well ask before making a plate or drilling holes...
Cheers
Depends on which car you're talking about. 740/940: yes. 240: no.
The coil end of the plug wires are different between the two. The Bosch 2x2 coil uses the 740/940 type, meaning the post on the coil is the same as what's on a 740/940 distributor.
If you have a 240 with wasted spark (as I do), you can use a set of 240 wires if you change the coil end connectors to the 740/940 style.
Old 04-14-2018, 02:27 AM   #389
bugjam1999
Ah, my question didnít say- Iíve got a 240.
Thanks for noticing that potential hiccup, Iíll get hold of plug ends/new leads from a 940 in amongst the collection of other parts.
Cheers
Old 04-14-2018, 04:36 PM   #390
nitroboie
Good catch Duder.
I installed the 2nd chip from you Thursday afternoon into a gold ezk, didn't have to dig through someone else's mailbox this time. Had a no start this morning before work. No spark to ws or through the stock setup... Weird that it suddenly stopped this morning. Ran fine for the last 100 miles, let it idle and parked it before going to bed.
Running on the black box for now. Hope I didn't fry/short the box somehow.
Edit: put it back in and it fired on the stock coil. Plugged in the ws connector and swapped the plug wires, she runs like it never quit... Shrug
Old 04-14-2018, 07:45 PM   #391
bugjam1999
Hmmm- ive read a few threads where people have had problems with gold ezk boxes and the wasted spark board. Iíve got a a gold ezk with a changed chip in it in place currently, Iím very keen not to brick it as theyíre getting rare and expensive here in the Uk. Should I get hold of a unchippable Black ezk (much cheaper) and put the wasted spark board in that?
Cheers
Old 04-17-2018, 12:41 PM   #392
bugjam1999
Ok, to put it another way- will the wasted spark module work with an unchippable ezk and if I went down that route would there any disadvantage over my current chipped ezk?
Cheers
Old 04-17-2018, 12:49 PM   #393
Duder
Duder's Avatar
Cheers
I don't have any direct experience with the unchippable EZK, but I'll look into this for you.
-Chris
Old 04-17-2018, 12:59 PM   #394
bugjam1999
Ok thanks- but really the question is how to avoid bricking my in use and working chippable ezk. Perhaps there havenít been that many threads with people saying that has happened, but I seem to recall a few.
Cheers
Old 04-17-2018, 04:30 PM   #395
nitroboie
Cheers
Yes, the module works with the non chippable ezks. The install is the same, somewhat easier as the daughter board doesn't get in the way of running the outputs to the opposite side of the box.
My first install was on a non chippable box, because they're easy to find and very cheap. My 2nd install was to my original gold/chippable box. Det17 is/was also running a non chippable install.
The only disadvantage is you won't be able to have custom maps without adding the daughter board with the chip socket.
If you don't feel comfortable doing it, practice on a non chippable box first.
Old 04-18-2018, 09:56 AM   #396
bugjam1999
Ok cool - thanks for the advice. I've done quite a lot of soldering etc. so i'll add the board to the chippable ezk and then report back.
cheers
Old 04-21-2018, 08:55 PM   #397
satanburns1
Satanburns2
satanburns1's Avatar
I posted in wanted because earlier today i couldnt see the images in this thread. I fixed that but still have a few questions. Can i remove the original volvo power stage and associated unused wiring? Does anyone know if an Autometer tach will work directly of the j702T?
Originally Posted by zdriver123 View Post
If you want to do it right the first time why the hell you on Turbobricks?
But please, ask me again if I even race bro.
Originally Posted by Justin View Post
Try peeing on your feet - it is what everyone suggest when I had issues with mine and it seemed to go away after a few months of peeing on my feet =)
satanburns1 is offline   Reply With Quote
Old 04-22-2018, 09:15 PM   #398
Mbeas96
Mbeas96's Avatar
Deleted post...
Old 04-28-2018, 09:03 PM   #399
Mbeas96
Mbeas96's Avatar
I'm very close to going thru with the wasted spark install. I have the bosch 2x2 coil and miata power stage, im a few days away from ordering the wasted spark board.
A few questions first,
I deleted my last post on here because I see it was answered earlier, but just to be sure...
Using a gold chippable ezk with a custom chip installed should not have any adverse effects, correct? I have access to a ezk that does not have the daughter chip, but I would like to keep the option to adjust/have other people adjust my ezk tune.
Plus, while helping with my brothers install, he used 18 gauge IIRC (tho it might have been 16) on the board to ezk connections and it would of been a lot easier if we went with a smaller wire. These are just signal wires right? So what's the smallest wire one could use, like 22 gauge?
Then, wires that go from the wasted spark board to the power stage and from power stage to coil? I would guess bigger gauge for those, but I'm no expert in wires.
Any help is appreciated!
Old 04-30-2018, 04:16 PM   #400
Mbeas96
Mbeas96's Avatar
Any thoughts?
