Old 10-28-2019, 07:37 PM   #76
soclosenotnear
Come pick up the welder anytime. We really need to get a move on before it gets cold. Here's to page 4 and getting some progress on it.
I think I'm down to pull the sedan to the front yard. You can strip the brakes and whatever else you might want. Wish you were down to whip some lights out and work after the kids go to sleep. That's when I could get the most progress done. I know this is the busiest time of year too, though..
check my feedback here
Old 11-16-2019, 04:31 PM   #77
Mbeas96
Mbeas96's Avatar
My heater core failed at the end of last winter, and with that I bypassed and ran until I could/wanted to change it. Which I have chosen to do now, after a couple of sub-freezing mornings, I'm ready to have heat again. It rained all day yesterday, I started at 8 this morning and made it till about 10 and I had access to the heater core door when I realized I didn't have a 7mm wrench of any kind.
20191116_094825
Drilled the rivet off the air distribution box and pulled that off, and found $2.17 in the ducts. Looks like working on these really does pay off...
20191116_095849
Took a break, went by my brothers to borrow a 7mm wrench...came back and found it very aggravating getting the 11 bolts off the door. Got the old one out around noon and rigged up a homemade pressure tester and immediately found the leak, spraying me in the face. Lower corner where it looks pretty crusty.
20191116_124451
My brother used this core for maybe a month, still is new
20191116_125042
Putting the new one in was easier, got 10 out of 11 bolts back on...along with the foam filler that is glued to the top. So many wires in the way and have been moved out of there natural spot so putting all the trim pieces back is annoying. But I'd say about 50% of the dash is back and it starts pouring.
20191116_143950
Looks like I'm probably gonna get pushed into tomorrow by the rain. Which is fine by me, only can take so much frustration for one day.
Sad thing is, after this is done, I have to figure out why my blower motor won't turn on now, after so many months of no use. I'm hoping I can remove and hopefully get it spinning again. If not, I guess a replacement is needed...2 weeks before the trip to Tennessee!!
Old 11-23-2019, 08:57 PM   #78
Mbeas96
Mbeas96's Avatar
After completing the heater core, I rode for a week with just the faint draft of heat coming from the vents as I drove. It was glorious. I left the under paneling off for the time, to have access the blower motor.
I picked up a VDO PM131 from my local auto zone, I posted a thread and was promptly given advice to buy this fan. $32.99, a 2 year warrenty, and a literal direct replacement to the stock fan. Only issue is the plastic covering leaves a gap where the wire runs up behind the heater box. Some duct tape and it should be fine living behind the under panel. The harness plugs in to the stock volvo connector
20191123_153444
20191122_122505
Along with the LED dash light coversion, this also was one of the best 30 minutes spent on the car
When reinstalling the ecu I noticed thsee brown wires leading to what looks like an ecu connector...I'm positive I didn't rup it out during any of this, it's obvious the harness has been opened up. Probably by me a while back? Car runs fine and no issues, what is this?
20191122_124916
With only 3 days till my family trip, I tried to button up some small things that could potentially ruin the trip...like the leaking soft line from the trans cooler. Reseting the rubber hoses and retightening hose clamps fixed that. Topped off the trans fluid.
Finally decided to brace the radiator, just drilling a new hole to move it forward an inch and it fits. I need to grab another bracket soon, I seem to have lost it.
20191123_130945
And the finished engine bay for the time being, I did have a 3.8bar dodge fpr installed, but just put the 3 bar back on and lowered the boost for the road trip. I'm trying my hardest to not have any problems.
20191123_130937
Old 11-23-2019, 09:04 PM   #79
Mbeas96
Mbeas96's Avatar
Wasn't sure if TB would let me post more than 5 pics so double post it is.
Preparing for the trip, I detailed the dash and interior pretty decently. I will finish it up tomorrow with a vacuuming.
I haven't shown any love to the interior in this thread, well the seats are trash, completely blown out leather. The dash is cracked is several places, and the carpets show the years of young children in the back seats.
She cleans up pretty well.
20191123_153356
Gotta live my boost guage mounting...when I eventually buy the triple gauge pillar, it'll move there
20191123_153005
20191123_152942
New rear tires and clean car. I can't wait for the trip.
Old 11-23-2019, 10:19 PM   #80
Vol242vo
Keep it clean...
Vol242vo's Avatar
Looking good. Good luck on the trip, hopefully no surprises. I’d load the trunk with everything you can just incase you need to do a quick fix.
Derek
1 Owner - 85k mile 1980 242
-Project Thread-
Follow on IG: @vol242vo
Old 11-25-2019, 11:09 AM   #81
Mbeas96
Mbeas96's Avatar
Thanks! And I'll come up with a list of things to bring along...including stands, don't want another trans line blowing up on the interstate and end up laying under a jacked up car.
Old 12-15-2019, 07:16 PM   #82
Mbeas96
Mbeas96's Avatar
Trip went great, no unexpected failures. It wasn't until a week after I returned that issues started popping up
Hard cold start and intermittent driving problems started occurring. Diag happened and I'm hoping it's the ECT. We will see what happens.
I got an early Christmas present from my girlfriend.
20191215_095047
So I went to my brothers and we hooked them up.
20191215_133147
20191215_154550
20191215_151552
The water temp gauge is not currently reading anything. The kit came with an 1/8" NPT temp sensor.
Is the 'petcock' drain, i think it's called, 1/8"? That would be convenient, or if it's possible to tap into the stock wiring for the gauge.
I'm very pleased with the fit of the triple gauge pod. The paint is a little cheap and it seemed to be tacky still when I received it. Some minor paint chips found, but okay for the money.
http://www.gaugepods.com/volvo.html
I'm also liking the glowshift gauges. 7 different colors and auto dimming when headlights turn on.
I'm loving it honestly
Old 12-18-2019, 09:14 PM   #83
Vol242vo
Keep it clean...
Vol242vo's Avatar
Looks good!
Old 12-20-2019, 09:16 AM   #84
Mbeas96
Mbeas96's Avatar
Thanks!
I need to track down my long forgotten about vent pod and click buy on a 3/8 - 1/4 adapter plug for the petcock drain. Seems like the perfect spot for my temp sensor.
But before that happens, starting issues have been driving me insane, gonna track down a replacement CPS and try my luck. Change my oil, plugs and gonna try and "big 3" my battery and alternator. Eventually I'll post pictures of the subwoofer my brother and I installed.
300 watt Alpine (model number here) single channel amp with a 300 watt rms, 12" Powerbass DVC sub wired to 2ohm, in a home built box. I originally had 2 12''s in a huge ported box in my jeep, but after doing some research, building a sealed box within spec and matching the ohms to the amp (not sure if I'm saying that right) it sounds awesome. Some rattling from the 30 year old sh#tbox, but coupled with the Polk audio speakers in all doors, it's the best sound I've ever had in a vehicle...and it all fits underneath the trunk floorboard. (I lose my spare, but a can of fix a flat, or a free tow might have to suffice.)
I'm really enjoying having this car and learning so much. I'm ready to fix my issues and start enjoying this awesome boost weather.
Old 04-13-2020, 08:08 PM   #85
Mbeas96
Mbeas96's Avatar
During this while COVID19....pandemic? I ended up getting sick with a regular, run of the mill baterial infection of some sort. Since, coughing and sore throat are covid symptoms, I had to get tested and miss a week of work till the results came back a very suprising, negative.
So, while I was at home, I did a lot of nothing, but I got some pictures...
DSCN1342
DSCN1343
DSCN1344
I bought a 19t compressor housing with a 58mm wheel. So that means I have to get the CHRA housing machined slightly, oh well.
Plus a "genuine" Mitsu rebuild kit for the tdo4 turbos from Kinugawa.
Along with that...here comes the angled housing that originally came on the 16T.
DSCN1331
DSCN1341
The known issue...almost done
DSCN1340
DSCN1339
Now the downpipe...
DSCN1345
DSCN1347
DSCN1350
The turbo and WGA I bought from TRITDT turbos through ebay...same with the rebuild kit, the downpipe came from JT tuning and i asked them to place a second o2 bung roughly 32" from the flange. It looks really nice imo, way better than I could do. Price wasn't to shabby either considering shipping.
I also acquired these from board members here
DSCN1352
DSCN1353
012 am and some s60r green giant injectors.
My vacation was at the end of the month, but I have been asked to wait a couple weeks and I happily obliged. Maybe it'll give me some time to think about pulling the trigger on an ostrich. At least for fueling purposes.
My wasted spark install failed...I'm not exactly sure what happened, but it starter with no start when cold, then I swapped to stock ignition with the distributor and coil. Then weeks later, same symptoms, but worse to the point the car wouldnt start for an hour, then start next minute, then die 100 yards down the road...it came down to the gold box ezk. I swapped the ezk with a random black box my brother had laying around and all issues were gone.
With that said, I'll leave the ignition alone as long as possible...until there is a reason to upgrade.
Old 04-14-2020, 09:27 PM   #86
Mbeas96
Mbeas96's Avatar
And just to note...for reference down the road...54,363 miles since the engine swap, 255,613 is the total mileage on the rest of the car and trans. Still going strong. Hopefully faster soon too.
Old 04-15-2020, 07:48 AM   #87
DET17
Reformed SAABaholic
That 19t will blow your mind. Mine (ARD kit) spools damn near instantly and pulls fabulously. Goodluck with that exhaust! I bought an ancient 3" DP, rumoured to be built by JAO or TLAO..... got it used on TB. It is quite tight, especially if you run an under chasis brace on your wagon. I should have the pics documenting it's fitment in my build thread. Take care in setting up your WG properly.
Old 04-17-2020, 07:03 PM   #88
Mbeas96
Mbeas96's Avatar
I'm very excited about it. As of now I am just waiting to have a few days to not be bothered that t he volvo is apart. Hopefully the machine shop can have it turned around rather quickly.
The fitment of the dp has been on my mind since I bought it. Especially since it's for the angled flange housing, let's hope it clears nicely. I do have under chasis bracing going on as well..
With the WGA, the compressor housing has multiple holes to pick from so the WGA is solid. Aa of now, my crude ac bracket is most likely flexing, or my current WGA is being pushed beyond its limits.
It came with a 17psi spring. My goal will be 23-24psi with the 19T. do you recommend getting a different psi spring or just slab a MBC on?
I also need to make a list and place an order for some small bits...exhaust mani gaskets, crush washers, oil filter arm seals. I used some cheap stainless braided hose for my oil frain, so that's probably cooked now and will be ruined when i try to remove. So another one of those and a way to stop the heat from getting to it.
Old 04-17-2020, 08:42 PM   #89
DET17
Reformed SAABaholic
I run a 4.5 psi WG spring, and Hallman MBC. That low opening pressure WG was recommended by ARD Tuning for use with a 19t. The low opening pressure sure hasn’t hurt my spool response of the 19t !
Old 05-08-2020, 07:20 PM   #90
Mbeas96
Mbeas96's Avatar
One week left until vacation, which will consist of fixing a power steering leak/adjusting the steering box on the Jeep, timing belt/water pump (hopefully) on the Honda, and last but certainly not least, completing the 19t/angled hot side combo with the 3" dp.
I did manage to acquire some not so blown out seats from my brothers wagon. I'd give a combined score a 5/10, while mine were definitely a 1.
DSCN1355
Old
940 seats in 740
New
I started with the passenger seat, so if things went south I could still drive the car...4 bolts are easily accessible with some extensions. The tracks have a metal knub on the bottom that fits into a keyhole that makes it a little bit of a PITA. Once you do it once it's pretty easy.
It was real nasty under there. Years of spilt drinks, food, trash and change. All in the most inaccessible area. Cleaned up the best that I could with what I had on hand.
940 seats in 740
Also gave me a good chance to run the rcas and power for the amp under the carpet/seats.
While removing the old seat, I realized the seat belt spools from the bottom on a 740, but on a 940 it spools from the top. So the cubby tray attatched to the seat is thinner and needs to be swapped.
940 seats in 740
940 seats in 740
Easy enough, until I let the seat belt spool up all the way and it somehow locked itself. So a fun 30 or so minutes taking this apart and figuring out how a seat belt locks.
940 seats in 740
With that figured out I bolted the new seat in.
940 seats in 740
Now for the driver side seat, the new one is powered. Hoping that the plug would already be under there....I took the seat out, cleaned up, and figured out my manual seat cubby would not work off my 740, if I wanted to maintain the adjustment panel.
For now, I swapped cubbies, installed the seat, power seat connections are not there unfortunately, removed the panel from the old seat cubby. I will need to look up the wiring diagrams for the relay/fuse panel so I wire it up right, but for now a 20v drill battery moved the seat to my preffered driving position and I shoved the adjust panel under the seat. We'll get to that later...
940 seats in 740
940 seats in 740
I have yet to drive, but sitting in them. They are higher, no doubt from the better support, and more comfortable. The bolstering on the sides are more pronounced and the headrests look more modern and match the rear. Overall happy for now. Maybe I can find a manual drivers seat in good condition eventually.
Old 05-14-2020, 11:06 PM   #91
Mbeas96
Mbeas96's Avatar
DSCN1366
Finally getting time to start ripping everything apart. Started first thing after work, after a beer and the car cooled off.
DSCN1401
DSCN1402
I love how fast things can come apart.
The conical housing outlet is dwarfed by the angled. I'll get a comparison shot tomorrow.
DSCN1404
DSCN1405
Tomorrow will be separating and tearing down the 16T, hopefully making it to the machine shop with the CHRA and new 58mm compressor wheel, "ceramic" high temp paint on the turbine housing, wrapping the downpipe, swapping injectors and figuring a way to put the 3" AMM in place. I love working on go fast stuff, so much more exciting than a heater core...
Old 05-15-2020, 09:20 PM   #92
Mbeas96
Mbeas96's Avatar
I didn't get as much done today as I wanted, but I ended up running around all day with the family. I did get to break down the 16T and drop it off to a local machine shop.
DSCN1414
DSCN1413
Crusty crusty crusty and oily.
DSCN1417
DSCN1418
All clean and ready to be machined.
My brother and I are planning on doing the same process at the same time, turbo wise. So we watched through the ARD tuning YouTube video a couples time and went ahead and tore it down. Very dirty, definitely could see the turbo being the cause of my smokey exhaust and oil loss.
Old compressor wheel with turbine shaft/wheel
DSCN1410
Does anyone know what these notches are in the compressor wheel? Balancing? It clearly was notched on purpose...the new wheel does not have these notches.
DSCN1412
Otoh, CHRA is at the machine shop. Looking at early next week is what I was told before I get it back. That's fine, I can do everything else in the meantime.
Old 05-16-2020, 07:41 PM   #93
Mbeas96
Mbeas96's Avatar
Keep working along...wrapped the top half of the downpipe in titanium fiber glass exhaust wrap. I hate that stuff. But it's done.
DSCN1426
Got some comparison pics of the exhaust housing and of the AMMs.
DSCN1422
DSCN1427
The angled has a nice factory port, unlike the straight and conical housing. The outlet flanges are no doubt way bigger
Same with the AMM
DSCN1424
The bigger AMM does not really matter at this pointf for airflow, I'll be reducing it back to stock so I can continue using the 2.5" do88 inlet hose my brother gave me back when.
DSCN1425
I just need a hard connecting pipe, probably will be pvc out the plumbing section if I'm gonna be honest. Painted black, cause white would look cheap....
Did some other odds and ends, cleaned up the studs and washers for the manifold. Used pb blaster and mineral spirits in a water bottle and let them soak all day. Wire brush and cloth to dry and they look 100x better than before. Ill be using new volvo locknuts for the manifild amd exhaust housing, but studs and washers completely slipped my mind.
I Installed the green giant injectors with some new o-rings. I also finished grinding away at my ported/non-egr manifold to fit the nut on the angled housing and started the ceramic coating.
Until tomorrow....
Old 05-18-2020, 10:28 PM   #94
Mbeas96
Mbeas96's Avatar
Cured the manifold and exhaust housing in the oven last night. Hopefully this stuff actually sticks, I used VHT header paint. It's supposed to be a ceramic coating that can withstand intermittent temps of 2000F.
DSCN1428
New volvo locknuts on the exhaust housing and manifold. I ordered a jam nut to use for the stud on the angled housing, after alot of grinding, it works nice.
DSCN1429
DSCN1432
So the adapter I ordered for my temp sensor was wrong...I accidentally ordered 1/4" instead of 1/8". So a trip to the hardware store and another adapter, I should have a working temp gauge...
DSCN1430
DSCN1431
Check out that bright red engine paint still holding up after 60k miles!
I went to fit the downpipe from JT tuning....and it fits! Almost....it is a tad tight on the top of the pipe under the car, right next to the Trans crossmember. A bfh will give some love tomorrow to make some room. They definitely made it tight to the body.
DSCN1433
DSCN1434
One issue that will need to be addressed...
DSCN1442
Too good to be true...I asked for the o2 bung to be placed at a slight angle upward on the passenger side. Well, I guess they assumed I had a rhd car, because they put it on the drivers side at a hard angle. Right on top of the Trans crossmember. Luckily I have a o2 plug handy...I'm taking it to get a new bung welded in tomorrow, in a spot I'll choose.
Times like these makes me want to learn how to weld. My old exhaust should make nice practice material.
Old 05-19-2020, 08:23 AM   #95
deNs
deNs's Avatar
I doubt they would've assumed you had a RHD vehicle, but more likely they may not have had a reference to check the location of where the sensor might foul on something. I bought a full JT tuning exhaust minus the downpipe for my RHD 940, because I knew it required a far more complicated series of bends than LHD cars require to avoid hitting the column.
You could take it to an exhaust shop and get them to cut the pipe, rotate slightly and re-weld if that will allow the bung to be positioned somewhere that will suit, or just plug it up like you said and have another somewhere else. I did a night course for welding so I could do jobs like that by myself and would highly recommend teaching yourself or doing a course. Opens up so many possibilities when you can do it. Good luck!
deNs is offline   Reply With Quote
Old 05-19-2020, 10:07 AM   #96
Mbeas96
Mbeas96's Avatar
The only reason I say they assumed I had a rhd car is because it's on the drivers side. I agree with not having a reference to see where it would clear, but LHD drivers side has really no room anywhere for it be wi th out hitting the crossmember, Trans cooler lines (for an auto) or bellhousing. Maybe it'd be more open in a manual.
I also thought about cutting and rotating, but that would leave the eyelet brace to be on the passenger side as well, with nothing close to brace it on.
Don't get me wrong, it's a very nicely made piece, I'm considering buying the rest of the system so my car doesn't sound like a turbo tractor.
Old 05-19-2020, 09:19 PM   #97
Mbeas96
Mbeas96's Avatar
I used a bfh to gain some clearance at the end of the downpipe. Here's a better picture.
DSCN1445
There's a black X marked where the new o2 bung will be. I just plugged the other hole, a little MORE beating for that to not rub...
DSCN1456
And it's done, 25 bucks including a bung. Not bad.
Also got the CHRA back today. A local machine shop, Davidson machine shop in North Charleston, was more than happy to ensure it back to me early this week. The prior one I went to told me it'd be 2 weeks before he could touch it. Looks great!
DSCN1452
DSCN1453
And with that comes the rebuild. Again watching an ARD tuning video on youtube...the process went smoothly enough.
DSCN1451
It is cat approved.
DSCN1454
DSCN1455
There is zero shaft play that I can feel. Side to side or in and out. It's pretty awesome. I'll let the locktight dry overnight and slap it all together tomorrow at some point.
Loctite says cures in 24 hours. Should I wait till say, 8pm tomorrow night to start the car? Idk if I want to risk it loosening...
Old 05-20-2020, 07:24 PM   #98
Mbeas96
Mbeas96's Avatar
Okay, so back to the turbo rebuild...I say it went smoothly, but in the end I thought the wheels didn't turn freely enough. They spun without hitting or rubbing anything, but as soon as I let go they would stop pretty immediately. I confirmed it was wrong by comparing to the 13c I had in my shed...tear it apart I go. Actually, only till I took the compressor nut back off did I realize the compressor wheel is ****ing tight on the shaft. Not wanting to pry with a screwdriver....I just tapped the turbine shaft down towards the exhaust side with the back of a screwdriver. It must have moved barely, because now I have a smidge of in/out play, but the wheels spin effortlessly now. Smoother than the 13c (high miles). So back down the compressor nut goes with some more loctite. This time it's all good.
Something must of pinched or binded as I put it back together. Glad I decided to take it apart...a couple online forums from google were trying to lead me to believe it would loosen up after break in. No sir.
It was pouring all morning, so I really didn't expect to do much today, but instead I put everything back together...without taking a single picture.
It lives! It drives! It does not leak! And best of all, NO OIL SMOKE OUT THE EXHAUST. Ah, that's a great feeling.
I haven't boosted at all, some Google searches say to break in the "new" turbo for 100-150 miles before boosting. That's fine with me, I'd rather give the computers time to learn this crazy far from stock setup.
Glowshift temp gauge works! Which is great. It seems to either be slow or it is actually correct and the factory gauge has a "faker" in it.
Factory gauge took approximately 8 minutes to reach operating temp at idle. The glowshift gauge, with the temp sensor in the petcock location took 10 minutes of idling and 2 miles at 45mph to reach 180F.
Anybody think the glowshift is right? Or maybe just a sensor location that heats up slower than the stock location?
I'll get pics tomorrow!
Old 05-20-2020, 07:46 PM   #99
Mbeas96
Mbeas96's Avatar
Ya know i forgot to mention. It's loud as ****. A throaty turbo tractor. I wonder what WOT sounds like. I almost died laughing when i first started it.
For the time being I'll get a long 3" pipe and band clamp it on. I'll cut it right before the rear axle, hopefully that will push all the tractor noises behind my ears.
Old 05-20-2020, 08:20 PM   #100
Mbeas96
Mbeas96's Avatar
And just so pictures show on page 5....I had a difficult time getting number 4 injector to seal against the fuel rail. Brand new o rings, so I'm not sure why, but regardless, I recieved 5 s60r injectors, so the extra, plus the new orings went on and the leak stopped.
Also, looking for advice on installing an o2 sensor...seriously though. Since mine is original and there is no disconnect, how would you go about twisting the sensor into the bung?
I tried to compensate by twisting the opposite direction before installing, but there were alot more turns than I anticipated and the wires are left twisted.
