Hello all
I finally got around to repairing the parking brake in my 91 240. I Installed new rear caliper brake pads, new brake rotors, new parking brake shoes, (old ones were metal-to-metal and ruined the inside of the rotor drum, and also barely worked) and new disk and parking brake hardware. (pins, springs, etc.)
My problem is the exact same as before the replaced components, I can lift the parking brake handle almost all the way up before it actually puts tension on the cables and drums. It is lifted past the maximum of the ratcheting mechanism, so I cannot lock the back wheels without manually holding the handle.
If I crank the adjusting nuts near the handle all they way down, it barely holds the car at the top of the ratchet. They shouldn't need to be that tight, and the handle shouldn't need to rise that high. Have the cables themselves stretched? or is there some gotcha I missed when firing the parts cannon?
thanks,
Ethan
edit) i ordered all the parts from FCP, except for the rotors which came from the local oreilly's. Is it possible the rotors have too big of an internal diameter?
thanks,
Ethan
