mike.volvo.240
- Mar 22, 2014
- Herndon, VA
Background
Back in the early 80s my parents had a silver 240 wagon. I remember this car because I loved riding around in the 3rd row, rear facing seat.
Last year I started looking for a project. I already have a 2008 STI which I run HPDEs and auto crosses with. Fun car. Easy to work on. Huge aftermarket. Love it. I could talk about the STI for days, but I won't because this is a Volvo forum. More on my STI here: http://www.iwsti.com/forums/gr-members-journals/148959-hokies-2008-ssm-sti.html
For the new "project", I looked around at some classic Porsches and BMWs. I couldn't find anything with good "bones" in my budget. I've always had a thing for 240s, so when I had the opportunity to scoop up a '93 240 Wagon, I did just that. Bought it with 141K on the odometer. Automatic. Slick top! I would've preferred the manual 5 speed, but I can satisfy my "rowing" needs in the STI (6 speed manual).
My goal with the 240 is to have a ridiculously clean and reliable commuter car with some style.
Latest Picture
Mod List
Suspension and Chassis
- IPD GT strut tower braces
- IPD 25/22 sway bars.
Wheels and Tires
- Virgo wheels (15x6, ET20 with 205/60R15 Falken Ziex 912s)
Brakes
- Hawk HPS
Interior
- Pioneer MVH-X560BT Digital Media Receiver
- Vaccum gauge
- OEM tach + 52mm clock
- OEM center armrest
- OEM headrest inserts (front)
Exterior
- Dave Barton Prancing Moose decals
- Thule gutter style roof rack (1050?)
And so it began...
Here she is the day I picked her up. The exterior was fairly clean, but I took it a step further and clay-bar'd and waxed the whole car.
I also spent a fair amount of time cleaning up the engine bay....
Engine bay before:
Engine bay after:
Interior was thoroughly cleaned. Recently I pulled the carpets and vacuumed (I might have OCD). At this time I also cleaned out the rockers of debris from the last 21 years. ZERO rust! I was quite happy about that.
And then I started the "modding" (I can't help myself). So I grabbed a tach and 52 mm clock on ebay. I also installed a broken boost gauge (which only reads vacuum) from my STI. After installing the tach the odometer gear broke when I was resetting the trip mileage, so I pulled the cluster again to replace with an IPD odometer gear.
Then I really dug into refreshing the engine. Refreshments include:
- new intake manifold gasket (Volvo OEM)
- new injector caps and seals
- cleaned AMM and ICV
- new O2 sensor (Bosch OEM)
- new cap and rotor (Bosch)
- new plugs and wires (Volvo OEM plugs, Bosch wires)
- cleaned Throttle Body + new gasket
- new vacuum hoses
- new Fuel Pressure Regulator (Bosch)
- new Fuel Pump relay
- new flame trap (PCV) system to include all hoses and the oil trap box bolted to the block
- new center muffler and over-axel exhaust pieces (Starla)
- new front end links and bushings (Myele)
- new front ball joints (Lemfoerder)
- new rear wiper nozzle (Volvo OEM)
- new belts (A/C, alternator, power steering)
- new Hawk HPS pads + new clips and retainers (run the same street pads on the STI!)
- new air filter
- new intake accordion hose
- new airbox thermostat + airbox door cleaning and lubrication
- new slash guard / under tray + hardware (was missing when I purchased car)
- new IPD oil cap seal
- new oil cap
- new gas cap
- new oil dipstick tube o-ring
- seafoam'd and oil changes
Here's the engine apart during intake manifold gasket change. Also changed the PCV system and some other misc items due to the easy access!
I've picked up some random goodies from various junk yard trips:
- side trim replacements
- missing nuts and bolts
- used center armrest from junk yard
- used headrest inserts from ebay
- spare AMM and ICV
- replacement door and trunk open/closed sensors
- almost new turn signal lens to replace cracked one
Within the last month I've picked up a set of 240 turbo wheels and mounted new 205/60/15 Falken Ziex 912s.
I'm currently awaiting a shipment from IPD with some more maintenance replacements and GT strut tower braces.
That brings us to today. The 240 was dropped off at a shop this morning to pull the windshield and install a new windshield + seal.
Future plans
Maybe IPD springs and sways. Maybe an "A" cam. The brake booster seems to have a very slight leak when below 40 degrees, so I'll need to replace that before the fall.
Latest Picture
Mod List
Wheels and Tires
Brakes
- Hawk HPS
Interior
- Vaccum gauge
Exterior
And so it began...
Engine bay before:
Engine bay after:
- new vacuum hoses
- new air filter
- new oil cap
- new gas cap
- spare AMM and ICV
Future plans
