vwblue1967
- Apr 3, 2010
- NC
I found a good set of heated seats (well a nice set of used 240 seats) to swap in my 93 240. I could try to fix my AC but id rather have heated seats to I can really be miserable. I have the switches and the harness that connects the switches. I found that the switch harness has a connector on the driver side of the console near the flasher relay.
I wasn't sure it the 240's were pre-wired for everything but does anyone know if the harness that goes from the plug towards the dash, is tucked away under the carpet or dash somewhere? The set up is pretty simple and it wouldn't be hard to make a new harness but if I can find the original harness to complete the setup I would rather do that.
its pretty simple....one power wire from fuse 13 to the driver switch that then runs to the pass side, a ground wire that connects to both seats and switches and each seat getting a hot wire from the switch once turned on. I was just wondering why the power wire didn't go to a connection that then spread out to the switches and seats. instead the connections go from the switches to the connector then under the dash and back to the seats.
If anyone has done this and found the remaining part of the harness please let me know where its hiding..thanks
