wyatt8740
- Mar 17, 2017
- Fort Wayne, Indiana
Does the ABS system in the '93 240 wagon I'm picking up complicate automatic-to-manual swaps when using a non-ABS car for the driveshaft? I'd really rather have the less-torquey manual-car gearing ratio for purposes of fuel economy, but am concerned about losing or having malfunctioning ABS as a result.
This will be one of my first times doing anything major in the drivetrain of one of these cars, and I don't want to end up with the transmissions/driveshafts out and no way to finish the swap.
Also, why do the wagons have a stronger driveshaft than sedans? Is it just for towing and heavy loads? Or is there some other factor I'm not taking into account? I've previously been told here that my sedan driveshaft should work in a wagon, but again I'm wondering if ABS throws a wrench into things or if it "just works" for light loads.
So, does ABS play into the swap at all? Do I need to find an ABS manual or buy some part to comp,ete the swap and keep ABS?
The exact cars are a '91 244 with M47 II transmission and no ABS, and a '93 Classic automatic 245, which I am en route to pick up in around 3 hours time.
I have a few other questions I'll ask later about other little things, but getting rid of the slushbox is high priority for me.
