Old 05-01-2017, 09:13 PM   #51
sksmith
sksmith's Avatar
Luck of thre Irish, JohnMc!!
Old 05-14-2017, 11:32 AM   #52
blackbird939
blackbird939's Avatar
Thumbs up Update
Welp.. I THINK I got it. Exhaust leak. Can't be 100% sure yet. Ordered a ceramic coated patriot 4->1 from IPD. Reassembled head. New gaskets, etc. Fired up today. The patriot is still leaking from one of the 4 ports, can't nail it down just yet. BUT.. the stethoscope is showing no tapping from the head. Maybe I am just lucky and soon it will resume the tapping. But for the moment, it's looking good. The car is much zippier throttle response with the Patriot. That old cast iron thing was cracked almost in half.
One thing about the Patriot. The dual SU manifold did not fit up perfectly. Had to notch out the exhaust flange a bit. Not too bad. And the Patriot is making ever-so-slight contact with the oil filter. Not thrilled about it, but maybe I can clear it with a different filter make.
More later after first test drive.
Michael K.
1940 Zündapp KS 600
1942 Zündapp KS 750
1943 VW Typ 82
1967 Honda S90
1972 Volvo 144E
1973 Volvo P1800ES (sold)
1975 Volvo C303 TGBII
1977 Volvo 242 DL (gone but not forgotten)
blackbird939 is offline   Reply With Quote
Old 05-15-2017, 12:11 PM   #53
matt b
I can send you the P/N's needed to do a remote filter set up, all my parts came from Summit and Jegs. The 4>1 thing is great but fitment is approximate, at best. I remember having to grind, bend and cuss a lot to make it fit on my old B18 and then this B20. But it does help with performance, no doubt.
Old 05-15-2017, 01:52 PM   #54
Take a ball peen hammer to the header and clearance it as needed.
Don't worry about any performance loss, it's apparently an old wive's tail:
https://www.youtube.com/watch?v=azPKIjxmmdU
(Using a dyno and an SBC to see how much minor 'clearancing' on a header affects HP. They progressively bash the headers more and more with repeated dyno pulls)
Old 05-15-2017, 01:58 PM   #55
blackbird939
Haha.. wow. Turns out they lost 0.25 HP? I might actually do that.. Just ding it a tiny bit right there. It's probably 1MM-2MM of interference.
Old 05-15-2017, 02:36 PM   #56
gsellstr
Vintage anti-ricer
gsellstr's Avatar
Thanks for posting that one John...I was about to go digging for it, awesome episode.
RIP
74 144 B20
90 745Ti
Old 05-15-2017, 04:43 PM   #57
matt b
Mine fell off a shelf and has a dent in it. I added HP without knowing it!!
