Old 05-07-2017, 03:36 PM   #1
VolvoPrince
Default 1998 V70R Low Boost
Differing from my redblocks, I just picked up a 98 V70R. Right now I can't get it to boost past 4psi. It has the ARD Green tune as well as a full stage zero. New TCV, Bypass Valve and spring, vacuum tested wastegate, adjusted WG actuator, all new vacuum lines, and tested for boost leaks. I found a small crack in my intercooler which is now fixed, but it hasn't helped my boost problem at all. The only leak I hear is from the intake hose going to the turbo, but this won't affect my boost, right? Intake sucks, not pushes.
The turbo shaft feels fine, not too much play and spins freely. Sometimes when I reset the ECU I can get it to boost around 5-6psi, but it stops doing that after a few minuets of driving. What do I do now?! I'm getting so fed up.
1984 245 (400K Miles and counting)
1998 V70R AWD
VolvoPrince is offline   Reply With Quote
Old 05-07-2017, 10:27 PM   #2
ovlov760
ovlov760's Avatar
Have you checked for fault codes? Are you sure the TCV hoses plugged into the correct ports?
Though I never had any issues with ARD tunes, I'm aware that others did have issues with them. Do you have a factory stock ECU you could pop in for comparison of boost levels?
2009 XC70 T6
2011 XC90 R-design
1998 V70 AWD
1966 M-B 230
2006 V70R GT
2011 C30 T5M
2006 XC70
1997 850 T5
1988 760 Turbo
Old 05-07-2017, 11:50 PM   #3
doucheNozzle
doucheNozzle's Avatar
Yes, you can't have any vacuum leaks on a maf based car. So fix those. And get rid of that ARD ****.
'99 V70 NAA - So Slow
'04 V70 T5A - Feels Fast
Old 05-08-2017, 11:57 PM   #4
VolvoPrince
So I have fixed the leaks from the intake. I don't have a stock ECU to test further but I do believe it is an ECU issue. I rest it and it will boost 5-6. If I let it go a bit I drops to 4. If I mess with the TCV and other connections involving boost it drops to 2 psi. And then I can't get it back up to 5-6 without resetting. Very strange. Does anyone have a stock Ecu I can buy?
Old 05-09-2017, 12:01 AM   #5
VolvoPrince
And all TCV ports have been right. As far as codes go I'm throwing P0505, which I can't get to go away. I replaced the idle control valve twice and cleaned the throttle body. It idles kind of high (1100-1250 it seems). I wonder if this has anything to do with my boost issue... I'm a massive noob when it comes to turbos.... It's my first one, so excuse my ingnorance.
Old 05-09-2017, 09:12 AM   #6
kampman
dunning-krugersquirt
Yeah, that's not right. The idle should be around 850RPM. Is the throttle cable adjusted properly? There might be other vacuum leaks too. Are all of the intercooler couplings good? How's the one that connects to the throttle body? Those are notorious for cracking where the IAC hose is molded into the coupler.
1966 220 wagon: dormant resto project
1999 S70 manual: #base, 192K
2000 V70R: 135K, deer victim/just a flesh wound
2006 V50 T5 AWD 6MT: 135K
Feedback Thread
kampman is offline   Reply With Quote
Old 05-09-2017, 09:42 AM   #7
Janspeed
the boost is controlled by the ECU, to do this it needs to be able to control the wastegate. For this it uses a (Pierburg) boost solenoid valve.
Is that thing present in the enginebay and hooked up correctly? (hoses, connector), no leaking/ dry rotted/ torn hoses? and is that solenoid valve actually opening and closing if you put 12V on it?
If it is stuck in the open position the engine will only use the base boostlevel that is allowed by the weak spring inside the wastegate actuator. Result: low boost.
another well known issue on older mitsubishi turbo's is cracking of the wastegate port, i have seen it on tdo-13, 15 and 16 turbo's, if left for to long eventually the wastegate valve and valve-seat area will get damaged as well and the turbo will no longer be able to make boost at lower and mid revs because a lot of exhaust gasses go through the wastegate instead of through the turbine. End result: low boost on all but high revs.
Old 05-09-2017, 10:02 AM   #8
ovlov760
ovlov760's Avatar
The tcv will wear out over time as well though he says it's new. In fact, nearly every rubber or plastic turbo related part is probably worn out on a '98 Volvo R.
Old 05-09-2017, 01:42 PM   #9
VolvoPrince
Thanks for more info guys. As far as the idle goes I have replaced a few hoses that were soft, not split or cracked. This included one intercooler hose. I have checked the rest multiple times; I've been getting go fed up that I have been taking apart all of the hoses, inspecting them, and making sure they are all put on right and tight. TCV is good, I have replaced it with a new OEM and and IPD one. Right now it has the OEM on it. All of the other hoses to it are new. ALL of my vacuum hoses are new, in fact. I replaced them all. As far as the wastegate goes, I pressure tested it a few time and got it to open around 4 psi. I know for a fact that the wastegate isn't the problem since I have taken off the hose to it and let it run. This should result in boost spikes and high boost. Yes, I know it's dangerous to do, but it hasn't made any difference. I'm still staying in the 4psi range.
Old 05-09-2017, 01:45 PM   #10
VolvoPrince
And even at high revs I'm only making 4psi. It's the same in all gears and all rev ranges. I can not find any more boost leaks either. Bypass valve holds vacuum as well. I let it sit over right and it hasn't let any go.
Old 05-09-2017, 02:09 PM   #11
VolvoPrince
Also, can someone confirm my routing to the TCV? Red to compressor, blue to intake hose, yellow to wastegate, right?
Old 05-09-2017, 03:07 PM   #12
oldschoolvolvo
oldschoolvolvo's Avatar
Confirm CBV diaphragm is not torn.
-Mike
1998 V70 T5
Old 05-09-2017, 03:18 PM   #13
ovlov760
ovlov760's Avatar
How did you fix the crack in your intercooler? Any chance it's still somehow leaking?
Old 05-09-2017, 03:18 PM   #14
VolvoPrince
It's not, it's brand new.
Old 05-09-2017, 03:18 PM   #15
VolvoPrince
I used some very good glue, and it's not leaking at all anymore. For sure.
Old 05-09-2017, 03:40 PM   #16
cwdodson88
exhaust leak?
The Build Thread
SVEA - PUSHROD TURBO!
Old 05-09-2017, 03:53 PM   #17
VolvoPrince
How could I identify an exhaust leak? And where's a common place they could leak from?
Old 05-09-2017, 04:00 PM   #18
doucheNozzle
How do you know? You pressure tested it?
Old 05-09-2017, 04:09 PM   #19
KeizerBrickGuy
Sh*t pot stirrer
KeizerBrickGuy's Avatar
Most people either take their intercoolers to a shop to be brazed/TIG'd and then be pressure tested. There's no way of knowing for sure unless you have directly pressure tested it and the intake tract. Assuming usually creates more problems. Have you checked the wastegate actuator?
-Stephen
#mclovethesenuts
Old 05-09-2017, 04:45 PM   #20
VolvoPrince
I have pressure tested it up to 20psi by blocking the bottom and hooking my boost tester to the top, intercooler is not leaking anymore for sure. I have checked the actuator, yes.
Old 05-09-2017, 07:26 PM   #21
ovlov760
ovlov760's Avatar
Long-term I'd be tempted to ditch that intercooler for an aftermarket unit or a good looking example from the JY.
Old 05-09-2017, 09:09 PM   #22
doucheNozzle
You should do that with the rest of the system.
Old 05-10-2017, 02:18 AM   #23
VolvoPrince
I have a few times now; I have not been able to identify any more leaks.
Also, a little update. I got in the car a few moments ago after it was sitting for a few hours and for some reason, the first time I got on the gas hard, it boosted to 6psi. After hitting the gas again, it was right back to 3-4.
Old 05-10-2017, 08:09 AM   #24
chevy_dude97
With minimal boost do you get a fluctuation in the rpms, uncommon to throttle position?
1989 740GLE 8V 250K miles in Survivor mode
1951 Buick Super
1980 MG MBG GT Sebring
2001 Seat Alhambra 1.9TDI
chevy_dude97 is offline   Reply With Quote
Old 05-10-2017, 01:11 PM   #25
VolvoPrince
No change in the rev range, it's 4psi constantly. Soon as I floor it, it'll go to 4 and stay there until the gear change, then go back to 4.
Something else also just kind of hit me last night. My car has the resistor mod done for the secondary air pump system in the ECU, as I found out when I went to go do it myself last week. Since I saw the resistor I just put the ECU back in. Last night I was getting a code pertaining to the secondary air pump... Which I shouldn't be getting with the mod done. Part of me wonders if the mod could somehow be affecting my ARD tune. If it wasn't accounted for when the tune was made wouldn't it mess with my system? Possibly limiting boost?
